New window wont open on top....
2
Help!!! For some strange reason, My laptop using Vista Home 32bit started acting up.....when I have windows(pages) already open, and I open a new window, this new window opens below(behind) the current window. This happens with IE7, as well as ACeeDsee viewer. When I am viewing a JPEG thru ACeeDsee, and click on edit, the edit window also opens behind, and not on top....so frustrating....someone out there ....please help me!!! Thanks so much!!!
206
open up "computer" click on the organise button (top right) go to folder and search options.
press open each folder in same window, hit apply, then change back to your original (im guessing) open each folder in its own window. hit apply.
try it out.
if that doesnt work click restore defaults> apply.
if that doesnt work restart your pc as a process is running in the background (probably an update service that requires a restart in order to resolve itself)
tell me if it helped, if not, we'll go from there
    Self built
    Q9550 overclocked to 3.93Ghz
    XFX 790i Ultra SLI
    (8Gb) - 2x2GB DDR3 Corsair Dominator Ram 1600Mhz + 2x2GB DDR3 OCZ 1600Mhz
    Asus GTX 280 + Gigabyte GTX 280 (SLI)
    Creative Soundblaster Fatality1 TY ultra Titanium
    3x24" BenQ, 22"Viewsonic
    1920x1200, 1920x1080, 1920x1080, 1680x1050
    2x 750Gb Samsung Spinpoint Raid 1 array
    3x 1TB Western Digital
    Antec 1000W
    Gigabyte low end full-tower
    CoolerMaster V10 for CPU 7 120mm fans
    Logitech G9, G7
    Logitech Dinovo edge, dinovo mini
    24mb/s D/L 15mb/s upload - Telstra
    7 Fans - 3 fans integrated 4x case cut to fit and integrated into the case.
2
Hello d3aths3rver!!
Thanks for your help!......I just figured out that this problem only exist when I am using ACDsee.....not only does the edit ACDsee window open behind said image window...but I cannot maximize any bottom taskbar tab.....I have to minimize ACDsee in order to view any other open programs....so, it's an ACDsee problem....any ideas? I may have to re-install ACDsee.....Thanx again!!
206
maybe look for some updates for your software, this can help.
Actually no, look in the options tab, it will be somewhere where it will be ticked "show on top of all other windows" or something similar, untick it and your problem will go away
    Self built
    XFX 790i Ultra SLI
    Antec 1000W
    Logitech G9, G7
