newdev.exe
B
bartjeuhn
when i start my computer, then always i see a windows that said to me
newdev.exe not found, would you instal it, looking for software or do
anything ...
i click 1 2 and 3 buth notthing help me
what should i do :(
U
usasma
Have you recently removed spyware or viruses from your system? The
newdev.exe file may be a virus that has been removed. Try locating it using
this free tool to disable it:
http://www.microsoft.com/technet/sysinternals/utilities/Autoruns.mspx
- John
> anything ...
> what should i do :(
M
marianzzy
i have the same prob with newdev.exe..
my pc is new .. but i did not have this problem .. i installed google
earth, then i found a trojan on google earth and after i deleted google
earth i have this problem. i downloaded autorun from
http://www.microsoft.com/technet/sys.../Autoruns.mspx
as you mentioned,
but i cannot find the file to disable it!
it doesnt apear with the find tool ..
( but i can find the file in the windows in my system32 files but i
didnt bother it because i do not know if i will damage anything!!! )
do i have to search it with another name with autorun?
i search as newdev.exe and plain newdev but nothing!!!!!!!!!!!!!!!!!!!!
marianzzy
Posted via http://www.vistaheads.com
