No Administrator Account
S
Steve Midgley
No, this isn't another case of the administrator account being disabled
(well, yes it is but I have a bigger problem). The only administrator
account on the computer is the ASPNET account, which does me no good at all.
The Administrator account isn't a logon choice in Safe Mode.
I don't know why or when this happened, but the only logon account on this
computer is a member of "users" and "Debugger Users" only - it was a member
of administrators, as well, but something got changed. I can't elevate the
account at all, for any reason. Any attempt to "Run as Administrator"
results in "Access Denied"
Running "net user Administrator /Active:yes" from the command prompt gives
me access denied.
Booting from the Vista disk and running the same command as above "seems" to
work but I still have no administrator logon in safe mode, as I should.
I've done several searches and have found others that have the same problem
but no solutions.
Does anyone have any advice as to what I might try next. Remember, I can't
do anything that requires an administrative account, elevated from a user or
otherwise.
I could easily reinstall Vista but I work as a computer tech and would like
to have the solution in case it comes up again.
Thanks in advance for any assistance,
Steve Midgley
R
Ronnie Vernon MVP
Steve
We are trying to track down exactly why this problem is occurring. Can you
give us some history on the problem?
Was this an upgrade over XP or a clean install?
If an upgrade, what was the status of the user accounts in XP prior to the
upgrade?
Had any accounts been hidden in XP?
Were you using the built-in administrator account as your everyday account
in XP?
Did you ever rename the built-in administrator account in XP?
Did all of the user accounts on XP appear in Vista after the upgrade?
What was the first indication you saw that there was a problem with the user
accounts in Vista?
What happened just prior to this discovery?
Was User Account Control enabled or ever disabled?
Boot from the Vista DVD and access the command prompt option.
Type:
net user (press enter)
Post the results back here.
Thanks.
PS. If you would rather take this to email, replace invalid with mvps.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
"Steve Midgley" <smidgley@com.net> wrote in message
news:b6ydnTMsLZ0-hsPbnZ2dnUVZ_tunnZ2d@comcast.com...
> all. The Administrator account isn't a logon choice in Safe Mode.
> member of administrators, as well, but something got changed. I can't
> elevate the account at all, for any reason. Any attempt to "Run as
> Administrator" results in "Access Denied"
> me access denied.
> to work but I still have no administrator logon in safe mode, as I should.
> problem but no solutions.
> or otherwise.
> like to have the solution in case it comes up again.
> Steve Midgley
S
Steve Midgley
Thanks for getting back so quickly, Ronnie. I've answered your questions
inline and will keep checking back for updates or if to see if you need
anything further from me.
----- Original Message -----
Newsgroups: microsoft.public.windows.vista.administration_accounts_passwords
Sent: Wednesday, May 30, 2007 8:03 PM
Subject: Re: No Administrator Account
> Steve
Upgrade
> upgrade?
Everything was working normally
No
> in XP?
Yes
Yes
Yes, everything was working perfectly
> user accounts in Vista?
The first indication that something had changed was that I was being
required to enter my password at logon .
I can't identify any changes to the system right before this started
happening. This machine is seldom rebooted, so it could have been a while
before I noticed.
UAC was disabled
> Type:
"Administrator Guest
Command completed with one or more errors."
My everyday user account is not listed here.
> Thanks.
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
>> this computer is a member of "users" and "Debugger Users" only - it was a
>> gives me access denied.
>> should.
>> can't do anything that requires an administrative account, elevated from
>> a user or otherwise.
>> Steve Midgley
R
Ronnie Vernon MVP
Steve
Thanks.
2 more quick questions.
What name did you give to the built-in administrator account in XP when you
changed it?
Boot with the DVD again, access the command prompt and type:
net user administrator (press enter)
Post back the results.
Thanks.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
news:be2dnbCkifZgpcPbnZ2dnUVZ_sSmnZ2d@comcast.com...
> From: "Ronnie Vernon MVP" <rv@invalid.org>
> Newsgroups:
>> Steve
>> you give us some history on the problem?
> Upgrade
>> the upgrade?
> No
>> account in XP?
> Yes
> Yes
> before I noticed.
> UAC was disabled
>> Type:
>> Thanks.
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
>>> a member of administrators, as well, but something got changed. I can't
>>> "seems" to work but I still have no administrator logon in safe mode, as
>>> I should.
>>> Steve Midgley
S
Steve Midgley
The name I gave the XP administrator account was Steve Midgley
net user administrator:
User name Administrator
Full Name
Comment Built-in account for administering the
computer/dom
ain
User's comment
Country code 000 (System Default)
Account active Yes
Account expires Never
Password last set 5/30/2007 10:14:51 PM
Password expires Never
Password changeable 5/30/2007 10:14:51 PM
Password required Yes
User may change password Yes
Workstations allowed All
Logon script
User profile
Home directory
Last logon Never
Logon hours allowed All
Global Group memberships *None
The command completed successfully.
"Ronnie Vernon MVP" <rv@invalid.org> wrote in message
news:0BA51AF6-6A78-4A7E-83D8-6A11AB10F416@microsoft.com...
> Steve
> Thanks.
> you changed it?
> Thanks.
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
>> Newsgroups:
>>> Steve
>> Upgrade
>>> the upgrade?
>> No
>>> account in XP?
>> Yes
>> Yes
>> before I noticed.
>> UAC was disabled
>>> Type:
>>> Thanks.
>>> Ronnie Vernon
>>> Microsoft MVP
>>> Windows Shell/User
>>>> can't elevate the account at all, for any reason. Any attempt to "Run
>>>> as Administrator" results in "Access Denied"
>>>> as I should.
>>>> from a user or otherwise.
>>>> Steve Midgley
R
Ronnie Vernon MVP
Steve
Thanks.
Did the Steve Midgley account ever appear in Vista after the upgrade?
What account are you logging on with now?
Is the account you are logging on with now the same one that inexplicably
changed?
Getting late, we can continue tomorrow.
Thanks again.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
news:XsmdnaYaNpgCzcPbnZ2dnUVZ_gWdnZ2d@comcast.com...
> Full Name
> computer/dom
> ain
> User's comment
> Account active Yes
> Logon script
> User profile
> Home directory
> Last logon Never
>> Steve
>> Thanks.
>> you changed it?
>> Thanks.
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
>>> Newsgroups:
>>>> Steve
>>> Upgrade
>>>> the upgrade?
>>> No
>>>> account in XP?
>>> Yes
>>> Yes
>>> while
>>> before I noticed.
>>> UAC was disabled
>>>> Type:
>>>> Thanks.
>>>> Ronnie Vernon
>>>> Microsoft MVP
>>>> Windows Shell/User
>>>>> disabled (well, yes it is but I have a bigger problem). The only
>>>>> administrator account on the computer is the ASPNET account, which
>>>>> does me no good at all. The Administrator account isn't a logon choice
>>>>> in Safe Mode.
>>>>> was a member of administrators, as well, but something got changed. I
>>>>> as I should.
>>>>> Steve Midgley
S
Steve Midgley
news:3CCAD0B3-A562-4E97-848D-8CE98F670B3F@microsoft.com...
> Steve
> Thanks.
> changed?
> Thanks again.
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
Yes, the Steve Midgley account worked normally in Vista for months.
Steve Midgley is the only account I can log on with and yes, it's the one
that changed.
Thanks for making the effort to get this figured out, Ronnie.
R
Ronnie Vernon MVP
#8
Steve
I haven't forgotten you, I'm still working on this and it's turning out to
be a tough one.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
news:CvadnXjk9qt29sPbnZ2dnUVZ_oavnZ2d@comcast.com...
>> Steve
>> Thanks.
>> changed?
>> Thanks again.
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
> that changed.
S
Steve Midgley
#9
news:F5307D17-1AB2-4476-AE1C-A4FD8C2F50F0@microsoft.com...
> Steve
> be a tough one.
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
Yes, a tough one , indeed. I plan on hanging on until this is solved - this
machine is still operable for the most part and my laptop has a nearly
identical setup if I were to get stuck.
R
Ronnie Vernon MVP
#10
Steve
I believe we have found a fix.
Thanks to MVP Jimmy Brush for doing the work on this procedure.
Here is his procedure:
<quote>
You get this behavior because the "net" command is running in the context of
the recovery environment, which is its own little in-memory windows
installation. The net command is listing the recovery enviornment's
accounts, and not the target windows installation's accounts.
Using the Recovery Environment, you can open the registry in the target
installation of Windows in order to apply the fix:
Boot with Vista installation disk in the drive and select the command prompt
in the repair options.
From the R.E. command prompt:
- Type: regedit
- Click on HKEY_LOCAL_MACHINE
- Click File -> Load Hive
- Browse to the target installation's \Windows\System32\Config folder
- Select the file named "SAM" and click Open
- Give it a name, e.g. "Target SAM" and click OK
- Expand "Target SAM" inside of HKEY_LOCAL_MACHINE
- Expand into the following subfolder: SAM\Domains\Account\Users\000001F4
- Double-click the item in the right called "F"
- You are now presented with a hex editor
- Change the 57'th position from hex 11 to hex 10. (I believe this is the
only spot in the data that contains a hex 11). To do this, click to the
right of hex 11 to make the insertion point there. Press backspace, and 11
disappears. Type 10.
On my computer, here's what the data looked like, up to the point that I
changed:
02,00,01,00,00,00,00,00,80,8c,d7,b2,e9,97,c7,01,00,00,00,00,00,00,00,
00,1f,ea,fd,ad,e9,97,c7,01,00,00,00,00,00,00,00,00,de,ad,60,9b,e9,97,c7,01,
f4,01,00,00,01,02,00,00,11, ...
TO:
f4,01,00,00,01,02,00,00,10, ...
This should make the built-in admin account active, but we still need to
unhide it from the welcome screen.
**NOTE, the following key may not be present on all systems. If this key is
missing, simply exit regedit, exit the command prompt and restart the system
to the normal Vista installation.***
- Follow the same steps on loading a hive, but instead of loading SAM, load
SOFTWARE
- Give it a name such as "Target Software"
- Expand Target Software, and browse to the following key:
Microsoft \ Windows NT \ CurrentVersion \ Winlogon \ SpecialAccounts \
UserList \
- Delete the entry in there named "Administrator"
- Close down regedit
- Reboot
Administrator should now be enabled and able to be logged in as or elevated
to.
- JB - Windows Shell/User
</quote>
***Note when you boot to Vista the administrator account should appear on
the login screen. If it does not, log on with your normal account and try
starting a program or application with administrator privileges, you should
get an elevation prompt.
Let me know how this works for you.
Ronnie Vernon
Microsoft MVP
Windows Shell/User
news:oYOdnc7SGLI3x8LbnZ2dnUVZ_h-vnZ2d@comcast.com...
>> Steve
>> to be a tough one.
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
> this machine is still operable for the most part and my laptop has a
> nearly identical setup if I were to get stuck.
S
Steve Midgley
#11
That did it! It took all of five minutes.
Thanks so much, I owe you guys big time!
Steve Midgley
news:178D77E2-45C3-4FD3-94BB-53E6162DD396@microsoft.com...
> Steve
> <quote>
> of
> prompt in the repair options.
> - Type: regedit
> changed:
> FROM:
> TO:
> is missing, simply exit regedit, exit the command prompt and restart the
> system to the normal Vista installation.***
> load
> SOFTWARE
> UserList \
> - Reboot
> elevated
> to.
> </quote>
> should get an elevation prompt.
> Ronnie Vernon
> Microsoft MVP
> Windows Shell/User
>>> Steve
>>> to be a tough one.
>>> Ronnie Vernon
>>> Microsoft MVP
>>> Windows Shell/User
R
Ronnie Vernon MVP
#12
Steve
That's great!
Kudos goes to MVP Jimmy Brush for coming up with this fix.
Thanks for sticking with me on this, and thanks for letting us know how it
turned out. :)
Ronnie Vernon
Microsoft MVP
Windows Shell/User
news:O-Odnaz7nt09lv_bnZ2dnUVZ_jWdnZ2d@comcast.com...
> Steve Midgley
>> Steve
>> <quote>
>> of
>> - Type: regedit
>> 11
>> changed:
>> FROM:
>> TO:
>> load
>> SOFTWARE
>> UserList \
>> - Reboot
>> elevated
>> to.
>> </quote>
>> Ronnie Vernon
>> Microsoft MVP
>> Windows Shell/User
>>>> Steve
>>>> to be a tough one.
>>>> Ronnie Vernon
>>>> Microsoft MVP
>>>> Windows Shell/User
J
Jimmy Brush
#13
Hello,
If anyone else is experiencing this problem, I have created a small
program that automates the process of editing the registry from the
Windows Recovery Environment.
Here are the updated instructions:
- Download the following file and save it to your desktop:
http://www.jimmah.com/vista/downloads/enableadmin.exe.
- Click on the start orb. Write down your username (the name listed
right below your picture on the start menu).
- Place your Windows Installation DVD into your DVD drive
- Restart your computer
- When prompted, press a key on your keyboard to boot from the DVD
- Select your language options and click Next
- Select the option at the bottom to repair your computer
- Select your Windows installation from the list. Make sure you notate
what drive letter it is installed on.
- Select the last option from the list to open a Command Prompt
- Type the drive letter that you notated, type a colon (:), and then
press enter. For example, if your Windows installation was on drive C,
you would type
C:
- Type the following command, and press enter:
cd users
- Type cd, a space, your username that you wrote down, and then press
enter. For example, if your username is jimmy, you would type
cd jimmy
cd desktop
-Type the following command, and press enter:
enableadmin
- You should receive a message telling you to restart your computer.
Close the command prompt window and click on the 'Restart' button on the
window that gives you the list of options.
- When your computer restarts, log in with the account named
'Administrator'. Use this emergency Administrator account to fix your
normal administrator account by using the user accounts control panel.
-JB
Microsoft MVP - Windows Shell/User
Windows Vista Support FAQ - http://www.jimmah.com/vista/
fishwanda
1
#14
Someone please help! :) I got to Double-click the item in the right called "F"
But there is not 11 on here. Can someone help please
