No DVD after Factory restore of Vista
cheesha
Posts
1
HP Pavilion DV 6000. After a factory restore of Vista, the DVD player no longer shows up in "MY COMPUTER"
I have replaced the drive. I have used CD Gone. I have gone to registry and looked to see if upper filters or lower filters were there <they weren't> so I couldn't delete that.
I've looked in the Bios. Drive is enabled. I've looked in device manager. No drive is listed. Disk Mgt. shows no drive.
My research indicates that it has been a problem in Vista operating systems. I am out of options.
Any assistance would be greatly appreciated!
ilikefree
New Zealand
Posts
2,887
Set a restore point (IMPORTANT) then do this
press Windows key and R
Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
In the right pane, click UpperFilters.
On the Edit menu, click Delete.
When you are prompted to confirm the deletion, click Yes.
In the right pane, click LowerFilters.
Exit Registry Editor.
Restart the computer.
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
