Solved No monitor signal on Boot...HELP!!!
ok, i just did a fresh install of windows vista home premium (32 bit) i installed all drivers, but now every time i try to boot normally it will have a windows Loading screen, then the monitor will cut out and start flashing "no signal", weird thing is though i am fully capable of booting into safe mode (with networking ect) ive tried almost every method i could think of, not to mention employed the power of Google, yahoo, ask Jeeves, and various other search engines, not to mention arguing with HP tech support for an hour and a half.
    HP
    amd athlon 64 x2 dual core processor 6000+
    asus
    2558 mb
    nividia Geforce 220 GT
    avid pro tools Mbox usb Studio audio interface
    32" LG TV
Boot into safe mode & delete all of the monitors in device manager reboot into normal mode & let is discover the monitor from there.
This should reset Windows & the setting to one you can see.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    BluRay & DVD Weiters
    40 Meg
worked for about 5 mins, nividia installed its stupid drivers again, bluescreened and started back at 0 :/
    HP
    asus
    2558 mb
    32" LG TV
what was the blue screen? That might help. Also why did you reinstall? Was it because of a blue screen?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
the blue screen was stop 0x00000d1
and i just got a stop 0x00000A1,
the full reinstall was because of the computer to not even start at all
    HP
    asus
    2558 mb
    32" LG TV
Is that all you got? There should have been some kind of error code. It might have listed a driver or some other file.
Also before the reinstall what happened when you turned on your computer.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
its just showing long enough to catch those numbers
    HP
    asus
    2558 mb
    32" LG TV
When you turn on your computer immediately start hitting F8 until you get the advanced boot menu. Arrow down until you are at disable automatic restarts and hit enter. While you are at it try safe mode. If it stops during safe mode tell us the last driver listed and if you get a blue screen tell us the error name.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
it only bluescreens in normal mode
    HP
    asus
    2558 mb
    32" LG TV
can you give me more information on the blue screen?
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
for the stop 0x00000A1 it said MEMORY_MANAGEMENT
D1 is DRIVER_IRQL_NOT_LESS_OR_EQUAL
    HP
    asus
    2558 mb
    32" LG TV
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
    HP
    asus
    2558 mb
    32" LG TV
It's unfortunate that it came to that but I'm glad that you where able to figure it out and thank you for sharing. Let us know if we can ever again be of service.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
