no speaker icon in taskbar or system tray
Z
zinastar
My icon in the bottom right corner of the speaker for adjusting volume
disappeared. Why and where did it go? how do I get it back
J
Juan Perez
Hi:
If you go to Start-->Setting->Control panel ->Sound and Audio Devices you
will see in device volume a tick for Place Volume icon in the task bar.
Un Saludo
Juan Perez
"zinastar" <zinastar@xxxxxx> wrote in message
news:DA760E2E-1C70-474F-952B-17D0B9E30B76@xxxxxx
You said"if you go to Start-->Setting->Control panel ->Sound and Audio Devices you
will see in device volume a tick for Place Volume icon in the task bar"
No, I know this applied in XP, but in Vista 64bit you have instead a "sound" item under Control panel and you cant do as you suggest!
J
Juan Perez
Hi:
Sorry, I did not realise this was a Vista newgroup.
Un Saludo
Juan Perez
"richardamery" <guest@xxxxxx-email.com> wrote in message
news:4db6032557b923f9d7634e52d1a30295@xxxxxx-gateway.com...
> Devices you
> richardamery
D
Dominic Payer
Right click your Start orb and select Properties. In the Notification Area
tab check the Volume icon in System icons.
I was having the same problem with sound and network icons. Thanks for your post, it worked great.
#8
I tried your fix but the Volume icon is shaded - won't let me check. Any suggestions?
brummyfan
Brummy
Right click the Task bar and untick "Lock the Taskbar".
B
Bill Daggett
#10
brummyfan <guest@xxxxxx-email.com> wrote:
>msilverstein;1098630 Wrote:
>> > Area
>> > news:DA760E2E-1C70-474F-952B-17D0B9E30B76@xxxxxx> > > > >
>> > > volume
>> > > > disappeared. Why and where did it go? how do I get it back > > > > > >
>> Any suggestions?
HUH?
C
Curious
#11
Try control panel/taskbar/notification area -customize/volume options
"Bill Daggett" <Daggett@xxxxxx> wrote in message
news:vhom655shnp0maflcu0a58diu1ir8v97np@xxxxxx
>>> > Area
>>> > > volume
>>> Any suggestions?
> HUH?
Brink
Staff member
mvp
#12
Hi M. Silverstein,
This tutorial may be able to help you out.
Notification Area - System Icons
