ODBC / Vista / Foxpro
R
Robert Hooker
I have installed our .NET application on a system running Microsoft Windows
Vista operating system.
When I run our application, I receive the following error message whenever
it tries to create a DBF file using VFPODBC:
"ERROR [IM001] [Microsoft][ODBC Driver Manager] Driver does not support this
function"
I am using a connection string that I have used for many years with no
problems, here is some sample C# code:
try
string connectionStatement = "Driver={Microsoft Visual FoxPro
Driver};SourceType=DBF;SourceDb=C:\\temp";
string createTableStatement = "CREATE TABLE [c:\\temp\\test] FREE(field1
C(10), field2 C(10), field3 C(10))";
OdbcConnection dbConnection = new OdbcConnection(connectionStatement);
dbConnection.Open();
OdbcCommand createCmd = new OdbcCommand(createTableStatement,
dbConnection);
createCmd.ExecuteNonQuery(); <<<< Fails here with the
message above >>>>
catch( System.Exception e )
MessageBox.Show(e.Message, "Error Creating Report Table"
,MessageBoxButtons.OK, MessageBoxIcon.Error);
How can I get my program to work in Vista (32 and 64bit)?
Rob
M
Mythran
"Robert Hooker" <[email protected]> wrote in message
news:[email protected]
> this function"
> try
> dbConnection);
> message above >>>>
> Rob
You could try:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=<path>;Extended
Properties=dBASE IV;User ID=Admin;Password="
as the connection string and use OleDb instead of ODBC.
HTH,
Mythran
R
Robert Hooker
Small correction:
It actually fails here:
> this function"
> try
> dbConnection);
> message above >>>>
> Rob
C
Cindy Winegarden
Hi Mythran,
For the record, not all DBFs are compatible with the dBase driver. FoxPro
DBFs created with VFP3-6 may be accessed via the FoxPro and Visual FoxPro
ODBC drivers, downloadable from
msdn.microsoft.com/vfoxpro/downloads/updates/odbc, and also DBFs that are
created with VFP7-9 if they don't use any of the new data features added in
VFP7 and above.
All versions of FoxPro DBFs are accessible via the FoxPro and Visual FoxPro
OLE DB data provider, downloadable from
msdn.microsoft.com/vfoxpro/downloads/updates .
Cindy Winegarden MCSD, Microsoft Most Valuable Professional
[email protected]
"Mythran" <[email protected]> wrote in message
> You could try:
C
Cindy Winegarden
Hi Robert,
Have you tried the FoxPro and Visual FoxPro OLE DB data provider,
downloadable from msdn.microsoft.com/vfoxpro/downloads/updates ? A typical
OLE DB data provider connection string (in VB) looks like:
connString = "Provider = VFPOLEDB.1; Data Source = C:\Temp;"
You can only work with Visual FoxPro ODBC or OLE DB in a 64-bit environment
in compatibility mode. There are no plans to create a 64-bit FoxPro ODBC
driver or OLD DB data provider. I'm told there will, however, be a .NET data
provider for FoxPro.
[email protected]
>> this function"
>> try
>> FREE(field1 C(10), field2 C(10), field3 C(10))";
