OEM Vista: how to reset to 'out of box'
L
I just acquired a new Fujitsu U810 UMPC, no optical drive. Before I had a
chance to get to it, some smart person managed to power it up and force a
shutdown during the initial Vista installation run.
Now I keep getting "Windows could not complete the installation. To install
Windows on this computer, please restart the installation." I have tried
Safe Mode and Repair (found no problems), and still get the same message.
I heard there is a way to reset Vista to 'out of box' setting. Can some
please help?
Normally one would use the Recovery disks to re-image the HDD but I don't
have a USB optical drive, plus that takes time. I am still researching the
external optical drives available, but looks like I may have to hasten my
efforts.
I have a very pretty, cute UMPC. But at the moment it is just a paper weight.
Thanks,
Leon
M
Malke
> install
> please help?
> the external optical drives available, but looks like I may have to hasten
> my efforts.
You're going to have to look in the manual or, if there is no paper manual,
on the website or call Fujitsu tech support for this. Every OEM has a
different method to return their computers to factory condition.
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
L
Thanks, Malke.
There is nothing in the paperwork for this. I have contacted Fujitsu tech
support who said they will get back to me. I think they are chasing the
solution 'further up the chain'.
Still waiting... Was hoping someone already knows and can share the info.
Leon
V
V Green
"leon" <leon@xxxxxx> wrote in message
news:4F4481FB-DB88-4130-BF58-985FBBA3D03B@xxxxxx
> please help?
> efforts.
> Thanks,
> Leon
I think you're probably just going to have to bite the bullet and get
that external DVD. Problem is, the OS never completed installing,
who knows what state things are in - even if you could get it to complete,
I would not trust the install and would wipe it and start over soonest. I
got a USB-DVD in order to upgrade my 810 to XP Tablet (yes, it's
an upgrade to go to XPT, you'll see what I mean after you get yours
going on Vista and find out how much stuff is broken).
You might try reposting here:
http://www.umpcportal.com/modules/newbb/viewforum.php?forum=16
and see if anyone can help.
H
Hu Ru
please help?
efforts.
weight.
Thanks,
LeonMethods for accessing the utilities
Certain LifeBook models have the Recovery and Utility applets pre-installed
on a hidden drive. Other systems require that the Recovery and Utility disc
be used (or in the event the hard disk has been reformatted).
In order to determine the method for accessing the Recovery and Utility
applet, perform the
following procedures in order.
Determining whether Recovery and Utility is pre-loaded 1 Turn on or reboot
your system. When the Fujitsu logo appears, press [F12] key.
2From the Boot Menu that appears, check whether the <Recovery and Utility>
option is present. If it is not present, it means that the utility must be
used from the disc. Proceed to “Running Recovery and Utility from the discâ€
if <Recovery and Utility> is unavailable.
Running Recovery and Utility from hard disk 1 Cursor down to <Recovery and
Utility> and press the [Enter] key.
2While the files are being loaded from the disc, a progress bar will appear
at the bottom of the screen.
3When the System Recovery Options dialog opens, select a new keyboard
layout, if necessary, then click [Next].
4When the Operating System dialog appears, click [Next].
5If necessary, enter your password, then click [OK].
6When System Recovery Options window appears, click on Recovery and Utility.
7The Recovery and Utility screen appears on the screen with three tabs:
Diagnostics,
Recovery and Utility. Please note that Diagnostics tab is not supported on
certain LifeBook/Stylistic models when running Recovery and Utility from the
hard disk. In order to restore the operating system, please insert the
“Recovery and Utility†disc in the CD/DVD drive and use the Start Recovery
function under the Recovery tab. For more information about the tabs, go to
“Recovery and Utility tabs†on page 106.
url for user guide
http://www.fujitsupc.com/www/content/pdf/SupportGuides/U800_UG_B5FJ-4211-01EN-00.pdf
V
V Green
"Hu Ru" <secretasianman@xxxxxx> wrote in message
news:ewHHCx$eIHA.5348@xxxxxx
> please help?
> efforts.
> weight.
> Thanks,
> applet, perform the
> used from the disc. Proceed to "Running Recovery and Utility from the disc"
> Diagnostics,
> "Recovery and Utility" disc in the CD/DVD drive and use the Start Recovery
> "Recovery and Utility tabs" on page 106.
> url for user guide
http://www.fujitsupc.com/www/content/pdf/SupportGuides/U800_UG_B5FJ-4211-01EN-00.pdf Not applicable to the U810.
Since it only has a 40GB HD, the OS comes as an image on
a recovery CD.
V
V Green
"V Green" <vanceg@xxxxxx> wrote in message
news:%23xOMrEAfIHA.4120@xxxxxx
> > please help?
> > efforts.
> > weight.
> > Thanks,
> > applet, perform the
> > Diagnostics,
> > url for user guide
> a recovery CD.
Make that "a recovery DVD"
