Offline Status issue - Vista on SBS 2003
J
Jaredean
I have a user that when he connects to the network he is having issues
with being "online"...he is connected, has internet access, can see
his folder on the server - but his status at the bottom of an explorer
window shows:
Offline Status: Offline (not connected)
Offline Availability: Available
In XP you get the "bubble" that tells you you are disconnected and you
can click it, click OK and it will connect you back to the
server...But, I don't know where to go in Vista to get it connected...
I tried looking in the Sync Center, but see nothing there...i did make
a folder on the server available offline and hit "Sync" and it synched
that folder but shows that it only was partially successful. Before
that it showed it hadn't synched in months, but all of the files he
worked on last week out of the office are on the server just like a
successful sync...
jared
R
Robbin Meng [MSFT]
Hi jared,
Thanks for your post and Russ's input.
As Russ indicated, the network connection bandwitch also affect the offline files sync. If there is slow connection detected, it may disconnects the offline sync. Please check:
1. Open Offline Files by clicking the Start button , clicking Control Panel, clicking Network and Internet, and then clicking Offline Files.
2. Click the Network tab, there should be a checkbox says "On slow connections, automatically work offline".
So if possible, please replace the network connection with a relatively stable one if you are using WiFi, or take the problematic computer to your office and connect it with a
NIC to the domain network and see if the issue persists.
More information, please see:
To sync all of your offline files immediately
http://windowshelp.microsoft.com/Wi...f57a-fa36-40be-a5c2-907f51cda1fe1033.mspx#EHF
Understanding offline files
http://windowshelp.microsoft.com/Windows/en-US/Help/93a550df-34cd-4497-85d0-8732602f59591033.mspx
Hope this helps. Also, if you have any questions or concerns, please do not hesitate to let me know.
Best regards,
Robbin Meng(MSFT)
Microsoft Online Newsgroup Support
Please post your SBS 2008 related questions to the SBS newsgroup on Connect website:
https://connect.microsoft.com/sbs08/community/discussion/richui/default.aspx
Please post your EBS related questions to the EBS newsgroup on Connect website:
https://connect.microsoft.com/ebs08/community/discussion/richui/default.aspx
If you want to use a newsreader other than a web forum to access these newsgroups,
please refer to the following blog to apply NNTP password and configure a newsreader:
http://msmvps.com/blogs/bradley/archive/2008/11/02/signing-up-for-the-sbs-2008-newsgroups.aspx
When responding to posts, please "Reply to Group" via your newsreader so
that others may learn and benefit from your issue.
L
Les Connor [SBS MVP]
Have you, by chance, disabled opportunistic file locking? This is sometimes
done for legacy database apps, but it plays havoc with Vista offline syncs
whereby it had no effect on XP.
"Jaredean" <shop@newsgroup> wrote in message
news:fr5h759kqn7dpfk05844gu2a4gg9u4l8hf@newsgroup
> window shows:
> successful sync...
> jared
J
Jaredean
Hey Russ, sorry i didn't give more information - here are the answers:
>Hi Jaredean,
>What AV are you using?
- McAfee
>Do you have SCAN Network drives (ON)
- no
>How much Memory are you using vs how much you have?
- 4 gig installed - not sure how much is using (user is offsite today)
>How many Applications are Up and Running.
- non, cold boot
>Is this WiFi what speed is he connecting at and signal strength.
- gigabit ethernet
>Is the PC a Member of the Domain?
- yes
>Is the SBS Server the DHCP Server?
- yes, SBS 2003 Premium
>All these things can affect it.
jared
J
Jaredean
Hey Robbin, thanks for the reply...it is on a gigabit connection and i
also tried the 802.11N wireless that is working well and neither
worked...it is a brand new computer (Sony VGN-Z690)...
I'll have to check the "slow connection" setting when he comes in
next...
jared
On Wed, 05 Aug 2009 03:34:48 GMT, v-robmen@newsgroup
("Robbin Meng [MSFT]") wrote:
>Hi jared,
>Best regards,
>Robbin Meng(MSFT)
J
Jaredean
When researching this issue, i came across that issue and I don't
remember ever disabling it, but it has been several years since i
setup the network and might have done it in the past at one point -
but honestly i don't believe i did...i need to find the documentation
on how to do it and verify it hasn't been done...
thanks for the heads up...
jared
On Wed, 5 Aug 2009 09:26:55 -0500, "Les Connor [SBS MVP]"
R
Robbin Meng [MSFT]
Hi jared,
Thanks for your prompt replies.
Please go ahead with your remaining tests and checking. I am with Russ on turning off/disable 3rd party firewall/anti-virus programs for test purpose.
Have a good day.
Best regards,
Robbin Meng(MSFT)
L
#8
\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\LanmanServer\Parameters
EnableOplocks REG_DWORD 0 or 1
Default: 1 (true)
Specifies whether the server allows clients to use oplocks on files. Oplocks
are a significant performance enhancement, but have the potential to cause
lost cached data on some networks, particularly wide-area networks.
By default, the registry entry is 1 (oplock enabled), as a rule of thumb you
should set this key to 0 (disable oplock) when sharing files with
Xbase++/Clipper/FoxPro and MS-Access. We have not encountered any
performance drawbacks in real-world scenarios after having disabled oplocks.
However problems with Xbase++ file-based database applications simple went
away after re-configuration of the server.
news:oemj755v386sskl8v90o8hr4eoqeutu7qv@newsgroup
> jared
>>sometimes
J
Jaredean
#9
Ok, the user finally got back into town after being on the road and
i've had a chance to check what you've each have asked as well as i
have more symptoms to report:
- I've disabled McAfee for testing purposes and rebooted
- I've looked for the settings that Robbin suggested "On slow
connections, automatically work offline" - but it is greyed out and
not selectable.
- I checked the Opportunistic File locking (both on the server and the
client) as Les suggested and there was no entry in the registry for
"EnableOplocks" -- i checked the LanmanServer and the
Lanmanworkstation just to be safe...neither the server nor the laptop
had the key...
When he got back online this morning, again - he still has an internet
connection, but he can't go to any share for some reason and his
Outlook is reporting "disconnected" (all of this is using a direct
connection to the server using a gigabit ethernet cable, not wireless
- his wireless is turned off) and the error on a send/recieve is "the
server is not available" 0x8004011d.
I wanted to test his connection on a different ethernet to rule that
out, so i brought it into my office and the password login box popped
up asking for his password (like when you are offsite using RPC over
HTTP. I asked him if that comes up all of the time looking for a
password and he said that it does - he didn't know that on the network
it isn't supposed to.
Also, his offline files sync still isn't synching as before.
So, new symptoms and not fix after suggestions...i am wondering if i
remove/delete his computer from the server and reconnect it using a
different computer name if that will restore things properly?
thoughts?
thanks,
jared
On Thu, 6 Aug 2009 09:02:29 -0500, "Les Connor [SBS MVP]"
>Default: 1 (true)
L
#10
If there are basic network connectivity issues, I'd think you need to
resolve those first - otherwise not much is going to work.
news:t0nl85911r6is8o5voaj6kkotkpg2244rp@newsgroup
> not selectable.
> had the key...
> thoughts?
> thanks,
> jared
>>Default: 1 (true)
>>Oplocks
>>you
>>oplocks.
J
Jaredean
#11
But as far as i can tell, there aren't any network connectivity
issues...15 users here, nobody else has issues...the laptop is online
no problem (internet browsing, etc.) and can see the H: drive, ping
the server, etc...it just seems to be a bad setup on the server...if
he didn't have internet connections i'd think it was something to do
with connectivity issues - but maybe i'm wrong...
jared
On Tue, 18 Aug 2009 12:41:02 -0500, "Les Connor [SBS MVP]"
L
#12
If no other users have issues, that goes a long way to discount general
server side issues. They seem unique to this user - which might include:
a) his profile
b) his network connection (switch port, cable)
c) his laptop - hardware issues such as NIC/nic driver
d) some software issue on his laptop
A, B and C are relatively easy to rule in/out. A and D could be done with
the big hammer - save his data off somewhere, remove his user and computer
account, format and re-install the laptop, and join it all together again.
There should be event logs on the laptop, as well as the server, to assist
in avoiding the big hammer, though.
news:r4ql85l4itudpv6eqtfvuk5uot4d274lri@newsgroup
> jared
L
#13
What's the H drive?
> jared
J
Jaredean
#15
Thanks Les, yeah, don't really want to do the "big hammer" as you put
it (classic term), but will if needed...but, wouldn't a "little
hammer" work out ok in re-establishing him to the server - that would
rule out his profile and give him a clean connection to the network
without having to rebuild his laptop...just delete his account on the
server and setup a new one, run the "connectcompter" and have it
rebuild his outlook/offline files? Since those are the two issues i'm
seeing, that seems like a dandy fix, no?
jared
On Tue, 18 Aug 2009 13:15:25 -0500, "Les Connor [SBS MVP]"
>a) his profile
L
#16
You could try disjoin and rejoin the computer, but AFAIK that isn't going to
affect his outlook profile nor offline file sync.
But outlook is easy, just remove the profile on the laptop, and create a new
one. Pretty much the same thing with offline folder syncs - turn it off -
just be sure you have the contents backed up somewhere.
The fact that both these facilities use a 'cache' would seem to be a hint.
Nothing firewally nor A/V related going on? 3rd party, perhaps.
news:911m859tlkptrbi18gt43cr4c85lunsf6j@newsgroup
> jared
>>a) his profile
J
Jim Behning SBS MVP
#17
Do your issues happen when you created a new user on the SBS and
logged in to the laptop as the new user? Both on and off the network?
On Tue, 18 Aug 2009 13:42:30 -0600, Jaredean <shop@newsgroup> wrote:
>Sorry, that is a share on the server...
>jared
>On Tue, 18 Aug 2009 13:16:16 -0500, "Les Connor [SBS MVP]"
>>What's the H drive?
See what SBS support is working on
http://blogs.technet.com/sbs/default.aspx
Check your SBS with the SBS Best Practices Analyzer
http://blogs.technet.com/sbs/archive/tags/BPA/default.aspx
J
Jaredean
#18
No, i've never had this issue and i've had this setup for 4 years now
and have had over 40 different users come and go...both on and off
network (and i'd say 3/4 of our users are mobile/laptop users)
jared
On Tue, 18 Aug 2009 21:02:11 -0400, Jim Behning SBS MVP
>>jared
>>>What's the H drive?
