[offtopic] DNS is automatically changed
J
James
216.146.35.35
216.146.35.36
I have Server 2008 (not R2) with Hyper-V role installed. There are two
NICs - for internal and external network (there is also virtual SBS 2003 as
main server). Everything worked fine 8 months and few days ago I had an
error. Trying to resolve this issue I removed both virtual NICs, added it
again and now DNS on NIC is very strange.
First NIC has DG to ADSL router and DNS1 to ADSL router and DNS2 to ISP.
After 1-2 mins both DNS IP addresses are automatically changed to
216.146.35.35 and
216.146.35.36 ?! Why happened that? If I change it, it will automatically
modify again.
I found that IP address belong to dyndns organization (if is it true) and
DYNDNS client updater is installed on that machine.
Second NIC has only one DNS - main SBS server, and similar afer 1-2 it is
changed to 216.146.35.35 and 216.146.35.36.
Regarding this I have behavior like slow login to computer, which is related
to wrong DNS on internal NIC.
What happened, how can I resolve it.
Thank you in advance!
Regards
C
Cliff Galiher - MVP
It sounds like you already know the answer. Your DynDNS updater is making
changes for you. You'll have to review that documentation and may have to
contact them to resolve the issue.
With that said, a virtualization host OS should *just* be a host OS. The
DynDNS updater should not be installed on the host OS at all. Install it on
one of the child OS's if you must, but not the host.
-Cliff
"James" <jj@newsgroup> wrote in message
news:uHfS7811KHA.4724@newsgroup
> 216.146.35.35
> 216.146.35.36
> Hi,
> as main server). Everything worked fine 8 months and few days ago I had an
> 216.146.35.35 and
> modify again.
> related to wrong DNS on internal NIC.
> Regards
R
Russ SBITS.Biz [SBS-MVP]
I don't know what Cliff said?
however the NEW version of DYNDNS Updater
Changes your DNS to THEIR DNS Servers
and will do exactly what you are describing
*yes thank you Dyndns.org @#$@#$3
Althought one can't blame them for trying to make money like
OPENDNS.org does.
So put the updater on another PC or if you have the "OLD version
that doesn't do this you can use that also.
Russ
Russell Grover - SBITS.Biz [SBS-MVP]
MCP, MCPS, MCNPS, SBSC
Small Business Server/Computer Support - www.SBITS.Biz
Question or Second Opinion - www.PersonalITConsultant.com
BPOS - Microsoft Online Services - www.Microsoft-Online-Services.com
http://www.twitter.com/SBITSdotBiz
> 216.146.35.35
> 216.146.35.36
> Hi,
> 216.146.35.35 and
> modify again.
> Regards
R
Now I read what Cliff said
Yup (I should have in the first place)
Cliff is correct it's making the changes for you..
Russ
"Cliff Galiher - MVP" <cgaliher@newsgroup> wrote in message
news:D960379B-CDEA-4163-BA1B-23D235149D6E@newsgroup
> on one of the child OS's if you must, but not the host.
> -Cliff
>> 216.146.35.35
>> 216.146.35.36
>> Hi,
>> an error. Trying to resolve this issue I removed both virtual NICs, added
>> it again and now DNS on NIC is very strange.
>> 216.146.35.35 and
>> modify again.
>> Regards
B
Bill Sanderson
Yuck! If there's no way to turn this off, I'm going to guard a local copy
of the installer for the older version like gold...
Tonight I had trouble resolving salesforce.com--no other domains just that
one. Tried switching dns on my router from Verizon to opendns. No change.
Eventually, I realized I'd set dns on my laptop to Google's DNS servers.
Not anymore....
I want complete control (within the limits of my memory....) of my dns
settings.
"Russ SBITS.Biz [SBS-MVP]" <russ@newsgroup> wrote in message
news:CD706128-B78F-44A1-87DC-1559367C734A@newsgroup
> OPENDNS.org does.
> Russ
>> 216.146.35.35
>> 216.146.35.36
>> Hi,
>> 216.146.35.35 and
>> modify again.
>> Regards
B
Bill Sanderson
OK - According to the install instructions, this is an option and is easily
disabled:
Select whether you wish to enable Internet Guide, our free recursive DNS
service which offers phishing and malware protection as well as customizable
content filtering. (You may disable the service at any time by unchecking
the "Enable Internet Guide" field on the Advanced tab of the update client.)
Aside from the somewhat misleading name, this doesn't seem to be too much of
a barrier to using the client.
"Bill Sanderson" <bill_sanderson@newsgroup> wrote in message
news:B7FDA9B4-9208-4A8B-BB2E-2F30AF5DB394@newsgroup
> change. Eventually, I realized I'd set dns on my laptop to Google's DNS
> servers. Not anymore....
> settings.
>> OPENDNS.org does.
>> Russ
>>> 216.146.35.35
>>> 216.146.35.36
>>> Hi,
>>> added it again and now DNS on NIC is very strange.
>>> 216.146.35.35 and
>>> automatically modify again.
>>> and DYNDNS client updater is installed on that machine.
>>> is changed to 216.146.35.35 and 216.146.35.36.
>>> Regards
R
Ah I didn't see that in the version I had a while back
Glad to see it's there
thanks for letting me know
Russ
news:531B6ABE-D8AB-497E-8131-1EB4DC3563C3@newsgroup
> easily disabled:
> customizable content filtering. (You may disable the service at any time
> by unchecking the "Enable Internet Guide" field on the Advanced tab of the
> update client.)
> of a barrier to using the client.
>> copy of the installer for the older version like gold...
>> that one. Tried switching dns on my router from Verizon to opendns. No
>> settings.
>>> OPENDNS.org does.
>>> Russ
>>>> 216.146.35.35
>>>> 216.146.35.36
>>>> Hi,
>>>> 2003 as main server). Everything worked fine 8 months and few days ago
>>>> I had an error. Trying to resolve this issue I removed both virtual
>>>> NICs, added it again and now DNS on NIC is very strange.
>>>> ISP.
>>>> 216.146.35.35 and
>>>> Regards
A
Andrew M. Saucci, Jr.
#8
Better still, don't ever use software updaters-- they are terrible.
I always use an updater built into a hardware router or firewall.
> -Cliff
>> 216.146.35.35
>> 216.146.35.36
>> Hi,
>> 216.146.35.35 and
>> modify again.
>> Regards
R
#9
unfortunately with Dyndns.org
most routers update too quickly now for them
and you get a "you are updating too often"
and if you do not use their software, they suspend your account for abuse :(
Dlink has their own free service also with it built into their routers.
Russ
"Andrew M. Saucci, Jr." <spam-only@newsgroup> wrote in message
news:eN54kW51KHA.4560@newsgroup
>> making changes for you. You'll have to review that documentation and may
>> have to contact them to resolve the issue.
>> -Cliff
>>> 216.146.35.35
>>> 216.146.35.36
>>> Hi,
>>> 216.146.35.35 and
>>> Regards
J
James
#10
1) That worked few months perfectly!
2) it must be on host because there are few virtual machines and I need to
administer it from that server
3) it cannot be on router (dyndns updater) because it doesn't work fine
C
Charlie Russel - MVP
#11
I've used DirectUpdate successfully as well, with no ill effects and no
extra options you need to disable. And it fully supports DynDNS along with
lots of other providers and is completely configurable for how often it
updates, etc.
Charlie.
http://msmvps.com/blogs/russel
> easily disabled:
> update client.)
>> settings.
>>> OPENDNS.org does.
>>> Russ
>>>> 216.146.35.35
>>>> 216.146.35.36
>>>> Hi,
>>>> ISP.
>>>> 216.146.35.35 and
>>>> Regards
S
SuperGumby [SBS MVP]
#12
PAHHH, I have the exact opposite opinion. Ain't the world a wonderful place.
I have found software to work much better than router clients.
>> -Cliff
>>> 216.146.35.35
>>> 216.146.35.36
>>> Hi,
>>> 216.146.35.35 and
>>> Regards
R
#13
LOL,
I love the hardware however like I said the DynDNS.org Doesn't like the
updates too often :(
Oh well, Main thing it works...
and it is easier than it was long ago!
Russ
"SuperGumby [SBS MVP]" <not@newsgroup> wrote in message
news:#LrEY2A2KHA.4336@newsgroup
> place.
>> terrible. I always use an updater built into a hardware router or
>> firewall.
>>> may have to contact them to resolve the issue.
>>> The DynDNS updater should not be installed on the host OS at all.
>>> Install it on one of the child OS's if you must, but not the host.
>>> -Cliff
>>>> 216.146.35.35
>>>> 216.146.35.36
>>>> Hi,
>>>> ISP.
>>>> 216.146.35.35 and
>>>> Regards
J
James
#14
Can you please upload that old version?
J
James
#15
I found 3.0 version and it really works as before!
R
#16
someone said that the new version you can shut that off?
If not I copied my directory here.
http://www.sbits.biz/dns
I couldn't find the install for it sorry
(I hope this works)
Russ
news:u2XJ6yG2KHA.5200@newsgroup
A
#17
While I have occasionally had problems with hardware updaters being
blocked, they are far less severe and far less frequent than problems I've
had with software updaters, which are junk-- I don't care what DynDns says
about them. A firmware update will generally fix problems with hardware
updaters. Junky software updaters just never belong on an SBS.
I also object to the term "abuse" in this context. (I know-- it's
their term, but I object nonetheless.) The word has too many moral overtones
when all we're discussing here is a piece of computer equipment somewhere.
They make it sound as though they're some sort of angels for deigning to
provide such a service to us lowly network consultants-- nothing like
lording it over inferiors.
news:E5D15E5E-370A-4B7C-9488-EF5B51D08061@newsgroup
> Russ
>> firewall.
>>> -Cliff
>>>> 216.146.35.35
>>>> 216.146.35.36
>>>> Hi,
>>>> ISP.
>>>> 216.146.35.35 and
>>>> Regards
