One of my Common Folder is stuck in an unwanted location
S
Steve Karsidi
I've 2 logical drives with D: meant for for data. C: was running out of
space, so I moved all the Common Folders (Documents, Pictures, Videos, Links
etc) onto D: drive (eg D:\Documents)...but accidentally for Downloads it was
direct in D:\ root.
So when I open my personal folder, for Downloads it is replaced with the D:
drive icon (replaced the usual green/blue Downloads folder icon) consisting
of every data folders plus the recently moved Common Folders. So messy.
I wanted to restore the Downloads common folder back to default
"C:\Users\Steve\Downloads" but Vista won't let me with an error message:
Failed to build the list of regular subfolders under "D:\System Volume
Information" Access is denied.
It's driving me nuts, no one including MS tech support can help. I need an
easy solution, can you help me please?
Steve
Brink
Staff member
mvp
32,202
Location
Oklahoma, USA
direct in D:\ root.
Steve
Hi Steve,
See if this tutorial will help you relocate your Downloads folder back to the default location. The Shell command will be "shell:downloads" (no quotes). You will probable have to change the registry settings to the default location to. (See the top of the tutorial)
http://www.vistax64.com/tutorials/107990-personal-user-shell-folders-move-location.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
