Solved "open with" restore default
Mahtan
6
I have had this problem for awhile know and was searching around for an answer when I found this site. Im not going to type out my problem because I can't explain it very well; however, I read an older thread on the same subject and here was their problem... this is also my problem:
Hi, I want to know how I can reset to the default programs for opening a file..
For example, I've got an .sav file from my Halo game folder, and one day I
was just fiddling around with the folders and I accidently clicked it and
chose Adobe Reader as the program.. then I tried WordPad, etc.. - don't know
why I did that. And I don't like it how all my .sav files have the little
WordPad logo on their icons. Also, I want to get rid of the 'recommended
programs' that pops up when you >right-click >"open with..." [the recommended
programs is just all the programs I tried to open the .sav file with... -.- ]
So anyway, how do I make it so its the default (in this case, there isn't a
"Default" but I want it like it was before - i.e. 'unknown application' or
something where after you click it, it asks you to choose a program, etc..
Any help would be much appreciated!!
Thanks
Hi Darren,
In your case, the .sav file extension should not have anything associated with it. You will need to unassociate it. This will show you how:
http://www.vistax64.com/tutorials/91920-unassociate-file-extention-type.html
You might find these helpful to use in the future if needed:
To normally change program associations:
http://www.vistax64.com/tutorials/83196-default-programs-program-default-associations.html
To normally change file extension associations:
http://www.vistax64.com/tutorials/69758-default-programs.html
I tried downloading the Unassociate File Extention Type that Shawn posted the site for and it was also associated with a different program. So I don't know what I did, but I need to get the default back to open my programs right. Please help this is driving me crazy!
Thanks, Mahtan
lordbob75
Lord of Bobs
Vista Pro
1,676
Location
In my Fortress
re: "open with" restore default
Ok.... let me have a shot here.
To set the default, right click and choose properties. In the general tab, click on the button "change" next to the Open With bar. Choose from the "recommended programs" and that should set it. To set one not on there, then open the "change" menu and select browse at the bottom, and select from the location of the file you want to open it with.
I don't know how to un-associate them, though someone here should.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Samsung SP2514N ATA 250Gb 7200RPM
    Samsung [Model] 1Tb 7200RPM SATA2
    Razer Lachesis
    Razer Tarantula
    not fast enough
Brink
Staff member
mvp
32,201
Location
Oklahoma, USA
Hello Mahtan, and welcome to Vista Forums.
In order to help, we need to know exactly what file extension types are not associated correctly.
From your last comment, it appears that the .exe file extensions are not associated correctly for that. At the link below, click on the .exe option in the table box to download the .reg file. After downloading it, right click on the .reg file and clock on Merge and approve. This will restore the default .exe file extensions association.
http://www.winhelponline.com/articles/105/1/File-association-fixes-for-Windows-Vista.html
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Brink
Staff member
mvp
32,201
Location
Oklahoma, USA
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
lordbob75
Lord of Bobs
Vista Pro
1,676
Location
In my Fortress
Yeah that sounds like it was amusing... Yeah.
Good luck
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
Mahtan
6
#8
I download the file and clicked merge, but know I don't know what to do. Sorry but I don't know much about computers; maybe you could explain what to do after that in simpler terms.
Again sorry.
SIW2
2,741
#9
Hi Mahtan,
Once you merge that .reg file into the registry, it will delete all the .exe files from Open With.
Check and see if you are still having problems.
If you are, there may other file types that need to be dealt with.
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
Mahtan
6
#10
I did all that stuff; downloaded the thing and merged. But my original problem was with a zip file I was trying to download. When I try to save/ download it it opens in word pad.
SIW2
2,741
#11
Hi Mahtan'
What do you get if you right click a .zip file and select Open with ?
I get this
SIW2
    Intel E8400
    2gb DDR2 800
    nvidia 9500GT 1gb
Brink
Staff member
mvp
32,201
Location
Oklahoma, USA
#12
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Brink
Staff member
mvp
32,201
Location
Oklahoma, USA
#14
You're welcome Mahtan. I'm happy that you got it sorted out now. :)
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
lordbob75
Lord of Bobs
Vista Pro
1,676
Location
In my Fortress
#15
Glad to see you got it fixed.
~Lordbob
    ASUS P5QC
    2x2GB
    Mobo
    Razer Lachesis
    Razer Tarantula
    not fast enough
