Operating System Not Found
rsaya1
1
hello,
i have a Windows Vista Basic laptop, i've had it for a year now and no problems but a few days ago it was working all good until i shut it down. properly.
and then when i turned it on it only comes in a blank black screen only saying Operating system not found.
if u know how to fix it please post in the forums
Thank you
Brink
Staff member
mvp
32,205
Location
Oklahoma, USA
  • Show second system?
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
motarola2
Power User
190
well, you need to post your computer's brand, model and specifications.
"operating system not found" could be a RAID setting disabled or enabled in the BIOS, depending on your configuration. could be a broken RAID, loose hard drive, defective hard drive.
check if your hard drive is detected in the BIOS, and check the RAID settings.
other than that try a checkdisk, or reinstall windows.
Dwarf
The Contemplator
2,760
Location
Doncaster, UK
Hi rsaya1,
When your power up your laptop, enter your BIOS by pressing 'Esc', 'Del' or 'F2' (these are the typical keys) - check the manual to see which key to press. Check the system time. Is it correct, and is it maintaining the correct time or is it resetting to an arbitrary time and date each time you power up your system? If it is failing to keep the correct time then that means the small button battery on your motherboard has failed and that the CMOS has lost its settings. Usually, the BIOS will revert back to using default settings, but if the settings have to be changed from their defaults to allow your laptop to function then this could be where the problem lies. Refer to the manual for details on how to change this battery, but if you are unsure about how to proceed you will need to entrust your laptop to someone with more experience in this sort of thing.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    Gigabyte IF233
bruce2
Vista Pro
618
Before you do anything, check if there is bad contact at the hd connector.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
koyo
1
i'm also have a same problem... and i did what u suggest but it still happen... any suggestion about this..?
my brand Laptop is compaq
model is compaq presario v3000 (v3119au)
my operating system is vista Ultimate x64
