Operator -not should get True for whatever -eq 0 gets True (and morefun)
R
Roman Kuzmin
Do I miss something (see the code and comments below)? I am with V2
CTP3, do other versions work in the same way?
# Operator -not should get True for whatever -eq 0 gets True
$ToBe = 0
$ToBe -eq 0 # True, OK
-not $ToBe # True, OK
$ToBe = (Get-Variable ToBe).Options
-not $ToBe # False, WOW, leads to subtle bugs, difficult to find
Actual output:
True
True
True
False
Expected output:
True
True
True
True
# How do you like this: both conditions are true
if ($ToBe -eq 0) {
"This is true, OK"
if ($ToBe) {
"And this is true, WOW"
Output:
This is true, OK
V
Vadims Podans
Re: Operator -not should get True for whatever -eq 0 gets True (and more fun)
PowerShell 1.0:
[user name] $tobe = 0
[user name] if ($ToBe -eq 0) {
>> "This is true, OK"
>> if ($ToBe) {
This is true, OK
[user name]
about your first example:
check the type of
((Get-Variable ToBe).Options0.gettype().fullname
WBR, Vadims Podans
PowerShell blog - www.sysadmins.lv
"Roman Kuzmin" <nightroman@xxxxxx> rakstija zinojuma
"news:dd554f76-1e88-4366-8bca-2176d2d9273f@xxxxxx"...
> $ToBe = 0
> Actual output:
> True
> True
> True
> False
> Expected output:
> True
> True
> True
> True
> if ($ToBe -eq 0) {
> "This is true, OK"
> if ($ToBe) {
> Output:
> This is true, OK
R
Roman Kuzmin
Re: Operator -not should get True for whatever -eq 0 gets True (andmore fun)
Hi Vadims,
So, do I understand correctly that in V1 it works differently? Namely,
"And this is true, WOW" is not written?
As for this
0> (Get-Variable ToBe).Options.GetType() | Out-String
... the type is enum:
IsPublic IsSerial Name BaseType
True True ScopedItemOptions System.Enum
And what is the type there in V1?
R
Roman Kuzmin
Hmm, I guess your example is for int 0, not enum 0. Try this:
$Foo = 0
$ToBe = (Get-Variable Foo).Options
if ($ToBe -eq 0) {
"This is true, OK"
if ($ToBe) {
Output:
This is true, OK
V
Vadims Podans
[user name] $tobe
None
[user name] $tobe -eq 0
True
therefore if you check this:
if ($ToBe -eq 0) {
"This is true, OK"
you'll get $true. If you check like this:
if ($ToBe) {
you get $true too, because if ($tobe) is the same as "if ($tobe -ne
$null -or $tobe -ne $false)". But your variable is not $null, or $false:
[user name] $tobe -eq $null
False
[user name] $tobe -eq $true
False
[user name] $tobe -eq $false
False
so, I sure that it is normal.
WBR, Vadims Podans
"news:11173878-088f-4acd-b2cb-07b4c61e28df@xxxxxx"...
> $Foo = 0
> if ($ToBe -eq 0) {
> "This is true, OK"
> if ($ToBe) {
> Output:
> This is true, OK
V
Vadims Podans
if ($tobe) is the same as "if ($tobe -ne $null -or $tobe -ne $false)"
here must be -and instead -or:
if ($tobe -ne $null -AND $tobe -ne $false)
Sorry.
"Vadims Podans" <vpodans> rakstija zinojuma
"news:OkHrP#9dJHA.4412@xxxxxx"...
> [user name] $tobe
> None
> True
> if ($ToBe -eq 0) {
> "This is true, OK"
> if ($ToBe) {
> False
> False
> False
> WBR, Vadims Podans
>> $Foo = 0
>> if ($ToBe -eq 0) {
>> "This is true, OK"
>> if ($ToBe) {
>> Output:
>> This is true, OK
R
Roman Kuzmin
I think that by this
if ($ToBe) {
we ask PowerShell to convert $ToBe to Boolean. It is in fact enum with
value 0. It does not look OK to me that on conversion to Boolean it is
at first converted to something that has presentation "None". Or, if
this is still OK, than why on conversion to int ($ToBe -eq 0) we get
true, as if "None" is the same as 0. Where is logic? Why "None" is 0,
but "None" is not False?
V
Vadims Podans
#8
no. Here is a trick, because "none" in fact is not necessarily digit 0. Look
here:
example with string:
[user name] $a = [string]0
[user name] $a -eq $true
False
[user name] $a -eq $false
False
[user name] $a -eq 0
True
[user name] if ($a){"yes"} else {"something wrong"}
yes
example with digit:
[user name] $a = [int]0
False
True
True
something wrong
WBR, Vadims Podans
"news:68adc363-c494-497f-80a2-40f8484a5682@xxxxxx"...
> if ($ToBe) {
