oscdimg and PowerShell - quirks?
P
perimere
Hi people,
I've been playing around with converting some old CMD scripts to
PowerShell :)
I've encountered what I consider to be strange behavior, but I'm sure
a programmer-type can probably explain ;)
I was trying to work out how to execute an EXE from within a PoSh
script, and I found a few references that prefix your command with the
&. This appears to work, though I haven't found any documentation/help
to detail it's use.
My issue is when I try to call the Microsoft tool: oscdimg.exe. I've
already found the limitation that when calling executables from within
PoSh that they need to be in the path *grumbles*....
The command line is: &oscdimg.exe -m -n -bd:\Images\Boot\etfsboot.com
d:\Images\x86\mount d:\Shiny.iso
The error I'm receiving is:
ERROR: Could not open boot sector file "D:"
So it seems to be having issues finding the etfsboot.com file.
Now oscdimg.exe is in the path, and the parameters are correct because
if I run this in CMD.exe it works. It also works if I put the command
in a CMD file and call that from PoSh (would like to avoid having to
do though!). I have also tried putting the etfsboot.com file both in
the path and same directory as the calling PS1 script.
Any ideas?
TIA
Cheers
Adam
A
Al Dunbar
"perimere" <adam@leadfollowmove.com> wrote in message
news:1181215050.429689.289650@q75g2000hsh.googlegroups.com...
> Hi people,
> PowerShell :)
> to detail it's use.
There'll be bigger grumbles when you are tricked into running a trojan
located in the default directory because it has the same name as a benign
executable in the path!
All you need to is explicitly specify the default directory (assuming, of
course, you know this is a safe executable):
&.\oscdimg.exe ...
I think that etfsboot.com is the "El Torito boot sector file", while
D:\Shiny.iso is the boot sector file. In either case, oscdimg seems to have
lost most of the path to whichever file it is having trouble with, as it
shows only the drive.
I'd suggest you re-try this using three different drives for the three
parameters to see which one is the problem.
Again, I'd like to confirm which file parameter is actually the problem. I
doubt that the program or powershell is looking at your fully qualified path
names and saying: "hmmm, he must be looking for this file somewhere on the
path".
/Al
> Any ideas?
> TIA
> Cheers
> Adam
M
Marcel J. Ortiz [MSFT]
> to detail it's use.
You should just be able to use the executable name if its in the PATH.
However, if you are giving the full path to the script and it contains
spaces, then you'll need & (& 'c:\Program Files\...').
This is true of pretty much all shells. Otherwise they would have to look
in the whole drive. I think what you are getting at though is that it
doesn't look in the current directory. You can change that if you want by
adding '.' to the PATH environment variable but I wouldn't recommend it.
Not executing from the current directory is meant to protect you from
trojans.
Try sorrounding that parameter with single quotes:
oscdimg.exe -m -n '-bd:\Images\Boot\etfsboot.com'
I'm pretty sure its splitting it up into parameter and argument, -bd and
\Images\boot\etfsboot.com respectively.
> Hi people,
> PowerShell :)
> to detail it's use.
> Any ideas?
> TIA
> Cheers
> Adam
