Outlook Express 'locked'
A
argyliz
In attempting to open an email with attachment, the Outlook Express program
locked.. cannot delete, send, receive or send on the mail program. Cannot
get to tools, etc. completely unusable. Any help or suggestions much
appreciated.
thanks
"Hey, what am I doing in this Handbasket, and where are we going?"
anon.
F
Frank Saunders MS-MVP IE,OE/WM
"argyliz" <argyl12@xxxxxx> wrote in message
news:uZUwK6lEIHA.3916@xxxxxx
> program locked.. cannot delete, send, receive or send on the mail program.
> Cannot get to tools, etc. completely unusable. Any help or suggestions
> much appreciated.
> thanks
> anon.
I don't understand. You can't even install Outlook Express on Vista.
www.fjsmjs.com
Do not send email
A
argyliz
Sorry about that Frank --- the problem happened on my other computer with
Windows XP... any suggestions most appreciated. Ralph Griffith
"Frank Saunders MS-MVP IE,OE/WM" <franksaunders@xxxxxx> wrote in message
news:0A80F5C5-0939-46CE-9978-249F5DDEFC86@xxxxxx
>> program. Cannot get to tools, etc. completely unusable. Any help or
>> suggestions much appreciated.
>> thanks
>> anon.
> www.fjsmjs.com
> Do not send email
B
Bruce Hagen
X-Poxted to OE General.
Close OE. If you /must/ use Ctrl+Alt+Delete. Open Internet Explorer and File
| Work Offline. Open OE and see if you can delete it now.
Bruce Hagen
MS-MVP Outlook Express
Imperial Beach, CA
> much appreciated.
> thanks
> anon.
A
argyliz
Did not work Bruce -- when I opened Outlook , the box ask if I wanted to
continue 'offline' - I clicked Yes and it locked... thanks and please give
me something else to try. Ralph Griffith
"Bruce Hagen" <Nospam@xxxxxx> wrote in message
news:%230YrCxmEIHA.3636@xxxxxx
> File | Work Offline. Open OE and see if you can delete it now.
> Bruce Hagen
> Imperial Beach, CA
>> thanks
>> anon.
B
Bruce Hagen
Do you store messages in the Inbox, or can you afford to wipe it clean? If
you don't care about message in the Inbox, do the following. If you do need
messages, instead of deleting the Inbox.dbx, rename it to Inboxold.dbx. You
will need a tool to recover the messages and we'll deal with that later.
Tools | Options | Maintenance | Store Folder will reveal the location of
your Outlook Express files. Press the Tab key to highlight the folder
location, then Ctrl+C. Close OE, then Start | Run | Ctrl+V will put the
location in the box - Click OK and you'll see the OE files. Otherwise, write
the location down and navigate to it in Windows Explorer.
In WinXP, Win2K & Win2K3, the OE user files (DBX and WAB) are by default
marked as hidden. To view these files in Windows Explorer, you must enable
Show Hidden Files and Folders under Start | Control Panel | Folder Options
Icon | View, or in Windows Explorer | Tools | Folder Options | View.
With OE closed, find the DBX file for the folder in question {Inbox.dbx} and
delete it. A new one will be created automatically when you open OE.
General precautions for Outlook Express:
Do not archive mail in default OE folders. They will eventually become
corrupt. Create your own user defined folders for storing mail and move your
mail to them. Empty Deleted Items folder regularly. Keep user created
folders under 100MB, and Default folders as empty as is feasible.
After you are done, follow up by compacting your folders manually while
working *offline* and do it often.
Click on Outlook Express at the top of the folder tree so no folders are
open. Then: File | Work Offline (or double click Working Online in the
Status Bar). File | Folder | Compact all folders. Don't touch anything until
the compacting is completed.
Turn off e-mail scanning in your anti-virus program. It is a redundant layer
of protection that eats up CPUs and causes a multitude of problems such as
time-outs and account setting changes. Your up-to-date A/V program will
continue to protect you sufficiently. For more, see:
http://www.oehelp.com/OETips.aspx#3
In Tools | Options | Maintenance: Uncheck Compact messages in background and
leave it unchecked. {N/A if running XP/SP2}.
And backup often.
Outlook Express Quick Backup (OEQB):
http://www.oehelp.com/OEBackup/Default.aspx
Bruce Hagen
Imperial Beach, CA
news:OAiJqmnEIHA.1316@xxxxxx
>> Bruce Hagen
>> Imperial Beach, CA
>>> thanks
>>> anon.
A
argyliz
Thanks Bruce... worked fine and I am now back in business. Still don't know
what caused it, but deleting the 'Inbox.dbx' worked fine since there were
only 2 mails in the box. Grateful to you. Ralph Griffith
news:OdvSIsnEIHA.4140@xxxxxx
> need messages, instead of deleting the Inbox.dbx, rename it to
> Inboxold.dbx. You will need a tool to recover the messages and we'll deal
> with that later.
> write the location down and navigate to it in Windows Explorer.
> and delete it. A new one will be created automatically when you open OE.
> your mail to them. Empty Deleted Items folder regularly. Keep user created
> until the compacting is completed.
> layer of protection that eats up CPUs and causes a multitude of problems
> such as time-outs and account setting changes. Your up-to-date A/V program
> will continue to protect you sufficiently. For more, see:
> and leave it unchecked. {N/A if running XP/SP2}.
> And backup often.
> Bruce Hagen
> Imperial Beach, CA
>> give me something else to try. Ralph Griffith
>>> Bruce Hagen
>>> Imperial Beach, CA
>>>> thanks
>>>> anon.
B
Bruce Hagen
#8
You're welcome & glad it's fixed. Whatever caused it was in that e-mail with
the attachment.
Bruce Hagen
Imperial Beach, CA
news:eJyLLFpEIHA.4308@xxxxxx
> know what caused it, but deleting the 'Inbox.dbx' worked fine since there
> were only 2 mails in the box. Grateful to you. Ralph Griffith
>> If you don't care about message in the Inbox, do the following. If you do
>> with that later.
>> enable Show Hidden Files and Folders under Start | Control Panel | Folder
>> Options Icon | View, or in Windows Explorer | Tools | Folder Options |
>> View.
>> created folders under 100MB, and Default folders as empty as is feasible.
>> program will continue to protect you sufficiently. For more, see:
>> And backup often.
>> Bruce Hagen
>> Imperial Beach, CA
>>>> Bruce Hagen
>>>> Imperial Beach, CA
>>>>> thanks
>>>>> anon.
F
#9
View | Layout
Turn off the Preview Pane and try deleting again.
news:ekCwnSmEIHA.4400@xxxxxx
>>> thanks
>>> anon.
M
Maureen
#10
Tried to clink on link in document..window for Outlook appears and asks for
my Product Key...did purchase Home and Student so familiar with product key
and did not purchase Outlook. Do have Vist OS with Windows Mail set up...Also
Outlook appears in list of programs and would not uninstall. Thought Windows
Mail successor to Outlook. Sorry, I am novice that just had computer hacked
into!!!!
> the attachment.
> Bruce Hagen
> Imperial Beach, CA
> >> with that later.
> >> View.
> >> And backup often.
> >> Bruce Hagen
> >> Imperial Beach, CA
> >>>> Bruce Hagen
> >>>> Imperial Beach, CA
> >>>>> thanks
> >>>>> anon.
B
Bruce Hagen
#11
Please start a new thread in the correct newsgroup explaining /your/
problem.
Outlook and Outlook Express are entirely different programs. You will get
better help in an MS Outlook newsgroup:
news://msnews.microsoft.com/microsoft.public.outlook
news://msnews.microsoft.com/microsoft.public.outlook.General
news://msnews.microsoft.com/microsoft.public.outlook.configuration
news://msnews.microsoft.com/microsoft.public.outlook.installation
news://msnews.microsoft.com/microsoft.public.outlook.Contacts
news://msnews.microsoft.com/microsoft.public.outlook.Calendaring
news://msnews.microsoft.com/microsoft.public.outlook.Fax
news://msnews.microsoft.com/microsoft.public.outlook.interop
news://msnews.microsoft.com/microsoft.public.outlook.printing
news://msnews.microsoft.com/microsoft.public.outlook.Program_AddIns
news://msnews.microsoft.com/microsoft.public.outlook.program_forms
news://msnews.microsoft.com/microsoft.public.outlook.Program_VBA
news://msnews.microsoft.com/microsoft.public.outlook.ThirdPartyUtil
On the Web:
http://www.microsoft.com/communitie...&pt=&catlist=&dglist=&ptlist=&exp=&sloc=en-us
Windows Vista Mail Newsgroup.
In your newsreader:
news://msnews.microsoft.com/microsoft.public.windows.vista.mail
On the Web:
http://www.microsoft.com/communitie...t.aspx?dg=microsoft.public.windows.vista.mail
Bruce Hagen
Imperial Beach, CA
"Maureen" <Maureen@xxxxxx> wrote in message
news:3A9EB768-9AE4-479D-A258-D037682DA8FE@xxxxxx
> for
> key
> up...Also
> Windows
> hacked
> into!!!!
>> with
>> the attachment.
>> Bruce Hagen
>> Imperial Beach, CA
>> > there
>> >> clean?
>> >> do
>> >> deal
>> >> with that later.
>> >> of
>> >> the
>> >> default
>> >> Folder
>> >> View.
>> >> {Inbox.dbx}
>> >> OE.
>> >> move
>> >> feasible.
>> >> while
>> >> are
>> >> problems
>> >> background
>> >> And backup often.
>> >> Bruce Hagen
>> >> Imperial Beach, CA
>> >>> to
>> >>>> and
>> >>>> Bruce Hagen
>> >>>> Imperial Beach, CA
>> >>>>> or
>> >>>>> thanks
>> >>>>> anon.
G
Gary VanderMolen
#12
Windows Mail is not a successor to Outlook. It is a successor to
Outlook Express.
Gary VanderMolen, MS-MVP (WLM)
"Maureen" <Maureen@xxxxxx> wrote in message news:3A9EB768-9AE4-479D-A258-D037682DA8FE@xxxxxx
> into!!!!
M
Maureen
#13
Thanks for reply...I did not know that Outlook Express different...have heard
them use interchangably. Have tried to start new thread and would not allow??
> problem.
> On the Web:
> In your newsreader:
> On the Web:
> Bruce Hagen
> Imperial Beach, CA
> > for
> > key
> > up...Also
> > Windows
> > hacked
> > into!!!!
> >> with
> >> the attachment.
> >> Bruce Hagen
> >> Imperial Beach, CA
> >> > there
> >> >> clean?
> >> >> do
> >> >> deal
> >> >> with that later.
> >> >> of
> >> >> the
> >> >> default
> >> >> Folder
> >> >> View.
> >> >> {Inbox.dbx}
> >> >> OE.
> >> >> move
> >> >> feasible.
> >> >> while
> >> >> are
> >> >> problems
> >> >> background
> >> >> And backup often.
> >> >> Bruce Hagen
> >> >> Imperial Beach, CA
> >> >>> to
> >> >>>> and
> >> >>>> Bruce Hagen
> >> >>>> Imperial Beach, CA
> >> >>>>> or
> >> >>>>> thanks
> >> >>>>> anon.
B
Bruce Hagen
#14
Click on the link, then New | Question. I can't help you. I have never used
MS Outlook.
MS Outlook Newsgroup
Bruce Hagen
Imperial Beach, CA
news:122A0495-5E1B-4C22-A6B5-0D2CFA339AF2@xxxxxx
> heard
> allow??
>> problem.
>> On the Web:
>> In your newsreader:
>> On the Web:
>> Bruce Hagen
>> Imperial Beach, CA
>> > for
>> > key
>> > up...Also
>> > Windows
>> > hacked
>> > into!!!!
>> >> e-mail
>> >> with
>> >> the attachment.
>> >> Bruce Hagen
>> >> Imperial Beach, CA
>> >> > don't
>> >> > there
>> >> >> clean?
>> >> >> you
>> >> >> do
>> >> >> we'll
>> >> >> deal
>> >> >> with that later.
>> >> >> location
>> >> >> of
>> >> >> folder
>> >> >> the
>> >> >> Otherwise,
>> >> >> default
>> >> >> Folder
>> >> >> Options |
>> >> >> View.
>> >> >> {Inbox.dbx}
>> >> >> open
>> >> >> OE.
>> >> >> become
>> >> >> move
>> >> >> feasible.
>> >> >> while
>> >> >> folders
>> >> >> are
>> >> >> the
>> >> >> anything
>> >> >> redundant
>> >> >> problems
>> >> >> background
>> >> >> And backup often.
>> >> >> Bruce Hagen
>> >> >> Imperial Beach, CA
>> >> >>> wanted
>> >> >>> to
>> >> >>> please
>> >> >>>> Explorer
>> >> >>>> and
>> >> >>>> Bruce Hagen
>> >> >>>> Imperial Beach, CA
>> >> >>>>> Express
>> >> >>>>> mail
>> >> >>>>> help
>> >> >>>>> or
>> >> >>>>> thanks
>> >> >>>>> going?"
>> >> >>>>> anon.
M
Maureen
#15
I have tried that several times and did not work!
> MS Outlook.
> Bruce Hagen
> Imperial Beach, CA
> > heard
> > allow??
> >> problem.
> >> On the Web:
> >> In your newsreader:
> >> On the Web:
> >> Bruce Hagen
> >> Imperial Beach, CA
> >> > for
> >> > key
> >> > up...Also
> >> > Windows
> >> > hacked
> >> > into!!!!
> >> >> e-mail
> >> >> with
> >> >> the attachment.
> >> >> Bruce Hagen
> >> >> Imperial Beach, CA
> >> >> > don't
> >> >> > there
> >> >> >> clean?
> >> >> >> you
> >> >> >> do
> >> >> >> we'll
> >> >> >> deal
> >> >> >> with that later.
> >> >> >> location
> >> >> >> of
> >> >> >> folder
> >> >> >> the
> >> >> >> Otherwise,
> >> >> >> default
> >> >> >> Folder
> >> >> >> Options |
> >> >> >> View.
> >> >> >> {Inbox.dbx}
> >> >> >> open
> >> >> >> OE.
> >> >> >> become
> >> >> >> move
> >> >> >> feasible.
> >> >> >> while
> >> >> >> folders
> >> >> >> are
> >> >> >> the
> >> >> >> anything
> >> >> >> redundant
> >> >> >> problems
> >> >> >> background
> >> >> >> And backup often.
> >> >> >> Bruce Hagen
> >> >> >> Imperial Beach, CA
> >> >> >>> wanted
> >> >> >>> to
> >> >> >>> please
> >> >> >>>> Explorer
> >> >> >>>> and
> >> >> >>>> Bruce Hagen
> >> >> >>>> Imperial Beach, CA
> >> >> >>>>> Express
> >> >> >>>>> mail
> >> >> >>>>> help
> >> >> >>>>> or
> >> >> >>>>> thanks
> >> >> >>>>> going?"
> >> >> >>>>> anon.
B
Bruce Hagen
#16
Forwarded to the MS Outlook newsgroup via crossposting.
Bruce Hagen
Imperial Beach, CA
Original Post:
> for
> key
> up...Also
> Windows
> hacked
> into!!!!
B
Bruce Hagen
#17
I have forwarded your original post to MS Outlook newsgroup via crosspost.
Watch that post for a reply from the proper newsgroup.
For the future, you might want to set up OE as your newsreader instead of
using the crappy Web interface.
Setting up Outlook Express Newsreader for MSNews:
http://www.michaelstevenstech.com/outlookexpressnewreader.htm
And:
http://www.insideoe.com/resources/communities.htm#setupmsnews
Bruce Hagen
Imperial Beach, CA
news:A842C0E7-A1CB-49FD-BCB7-DDB4F567AA4A@xxxxxx
>> used
>> MS Outlook.
>> Bruce Hagen
>> Imperial Beach, CA
>> > heard
>> > allow??
>> >> problem.
>> >> get
>> >> On the Web:
>> >> In your newsreader:
>> >> On the Web:
>> >> Bruce Hagen
>> >> Imperial Beach, CA
>> >> > asks
>> >> > for
>> >> > product
>> >> > key
>> >> > up...Also
>> >> > Thought
>> >> > Windows
>> >> > computer
>> >> > hacked
>> >> > into!!!!
>> >> >> e-mail
>> >> >> with
>> >> >> the attachment.
>> >> >> Bruce Hagen
>> >> >> Imperial Beach, CA
>> >> >> > don't
>> >> >> > since
>> >> >> > there
>> >> >> >> clean?
>> >> >> >> If
>> >> >> >> you
>> >> >> >> do
>> >> >> >> we'll
>> >> >> >> deal
>> >> >> >> with that later.
>> >> >> >> location
>> >> >> >> of
>> >> >> >> folder
>> >> >> >> put
>> >> >> >> the
>> >> >> >> Otherwise,
>> >> >> >> default
>> >> >> >> must
>> >> >> >> Folder
>> >> >> >> Options |
>> >> >> >> View.
>> >> >> >> {Inbox.dbx}
>> >> >> >> open
>> >> >> >> OE.
>> >> >> >> become
>> >> >> >> and
>> >> >> >> move
>> >> >> >> user
>> >> >> >> feasible.
>> >> >> >> manually
>> >> >> >> while
>> >> >> >> folders
>> >> >> >> are
>> >> >> >> in
>> >> >> >> the
>> >> >> >> anything
>> >> >> >> redundant
>> >> >> >> problems
>> >> >> >> A/V
>> >> >> >> see:
>> >> >> >> background
>> >> >> >> And backup often.
>> >> >> >> Bruce Hagen
>> >> >> >> Imperial Beach, CA
>> >> >> >>> wanted
>> >> >> >>> to
>> >> >> >>> please
>> >> >> >>>> Explorer
>> >> >> >>>> and
>> >> >> >>>> Bruce Hagen
>> >> >> >>>> Imperial Beach, CA
>> >> >> >>>>> Express
>> >> >> >>>>> mail
>> >> >> >>>>> help
>> >> >> >>>>> or
>> >> >> >>>>> thanks
>> >> >> >>>>> going?"
>> >> >> >>>>> anon.
Please help--I wasn't even able to figure how to open a new thread for my
question, so I guess you know who you are dealing with. On my new Vista, in
control panel (and only in control panel), I cannot get fax and mail to open.
I get an error mesage that tells me I have insuffient memory and to close
some windows. I've got 2G Ram and have over 100gb free on the internal hard
drive, so something must be screwy. I did use an external "my book" backup
drive for the old computer as it was dying, and then have used it in the new
computer, where I think it created an imaginary memory for the new computer
in the internal hard drive by creating a second internal drive of ~10gb and
filling it halfway), but i don't see how this could be creating the problem
in opening the fax/mail in control panel. I CAN reach and use windows mail
without any problem; it's just that i cannot open up the control panel icon
for it. I really would appreciate your help.
Les
> Bruce Hagen
> Imperial Beach, CA
> Original Post:
> > for
> > key
> > up...Also
> > Windows
> > hacked
> > into!!!!
G
Gary VanderMolen
#19
Not sure why you are posting this to the vista.mail newsgroup.
The Mail and Fax icons in Control Panel have nothing to do with
Vista's Windows Mail.
Gary VanderMolen, MS-MVP (WLMail)
"Les" <Les@xxxxxx> wrote in message news:EE8720EF-289F-4839-8DAC-1BB769408E50@xxxxxx
> Les
I did so because this is my first use of this site and I have no idea what
I'm doing. That's why I need help. Where should I go?
> > Les
