output to cmd with | symbol
H
Hylle
Hi.
I am trying to call a cmd with some parameters. Unfortunately one of
them is the | symbol.
Here is the call i make:
cmd="cmd /c" & chr(34) & "Echo WEBTST" & vbtab & "Check Backup status"
& vbtab & status & vbtab & "Backup completed ok" & chr(124) &
"files=" & files & ", folders=" & folders &", bytes=" & bytes &
chr(34) & "|c:\repbcklog\send_nsca.exe -H nagios2 -c C:\repbcklog
\send_nsca.cfg"
wscript.echo cmd
The call is trying to send input to the send_nsca.exe program, which
requires TAB as the delimiter, and the chr(124) is the pipe symbol,
the other pipe sign is working fine. I have tested including the ^
sign before the chr(124). If i try to enter the command manually on a
command prompt it works fine, but if it is the vbscript that does it,
it complains that "files" is not a command. How do I escape the | sign
so it works?
Any hints?
regards
Jens Hyllegaard
P
Pegasus [MVP]
"Hylle" <[email protected]> wrote in message
news:[email protected]
> Hi.
> \send_nsca.cfg"
> wscript.echo cmd
> so it works?
> Any hints?
> regards
> Jens Hyllegaard
Let's have a look at the script line that actually invokes the command!
T
Tom Lavedas
On May 25, 10:02 am, Hylle <[email protected]> wrote:
> Hi.
> \send_nsca.cfg"
> wscript.echo cmd
> so it works?
> Any hints?
> regards
> Jens Hyllegaard
It appears to me that there is a problemwith the two Chr(34)s. They
are creating an invalid statement. In addition, I found that the
escape character needs to be escaped, so that it requires THREE carats
to make the statement work. Try this ...
cmd="cmd /c" & "Echo WEBTST" & vbtab & "Check Backup status" _
& vbtab & status & vbtab & "Backup completed ok^^^|" _
& "files=" & files & ", folders=" & folders &", bytes=" & bytes _
\send_nsca.cfg"
wscript.echo cmd
_____________________
Tom Lavedas
H
Hylle
> > \send_nsca.cfg"
> > wscript.echo cmd
> > so it works?
> > Any hints?
> > regards
> > Jens Hyllegaard
Sorry, I thought I had put it in.
here it is, pretty simple:
result = objShell.run (cmd)
I then check the value of result
Regards
Jens
H
Hylle
> > \send_nsca.cfg"
> > wscript.echo cmd
> > so it works?
> > Any hints?
> > regards
> > Jens Hyllegaard
> \send_nsca.cfg"
> wscript.echo cmd
> Tom Lavedas
Hi.
Thanks that did it. It was due to the triple ^
Here is what is working for me now.
& vbtab & status & vbtab & "Backup completed ok^^^" & chr(124) &
\send_nsca.cfg"
test = objShell.run (cmd)
wscript.echo cmd
