page fault in nonpaged area
S
Sugar
My first computer ever! e-machine with Vista Premium Home; I get this big
blue screen with
STOP:oxooooo5o(oxf5eo718,oxooooooo1,ox81d4f0b5,oxooooooo2)and
Page_fault_in_nonpaged_area ; and something about disable bios memory
options such as caching or shadowing. It usually takes about 2-3 hours of
surfin or workin and then BLAM! Help Pleze.
R
Rick Rogers
The error is a driver issue, but the fact that the system runs for a while
before this occurs is unusual. It may be a faulty component that is
overheating and not responding properly at that point.
Is a module listed as being involved? Does it mention anything about
creating a dump file?
Disabling rom shadowing may help. To do this you need to access the system
BIOS at startup, before Vista begins to load, and check the advanced
options.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
My thoughts http://rick-mvp.blogspot.com
"Sugar" <[email protected]> wrote in message
news:[email protected]
> blue screen with
S
Sugar
New computer;New future nerd. Yes a memory dump 100 shows up ; I have no
ideal what disabling rom shadowing is; I do not know how to access the system
bios at start-up ; I do not know how to check the advance options. is there
any hope ?
"Rick Rogers" wrote:
> Hi,
> options.
> Best of Luck,
> > blue screen with
R
Rick Rogers
There's always hope. Look under C:\Windows\minidump for the most recently
created file. Send it to me at [email protected] using a subject line of 'per
req' (if you don't use this subject line, I'll never see it).
Accessing the system BIOS is done by hitting the appropriate keys during the
initial power on. This is usually evidenced by a screen message that says
something like "hit F2 to enter setup". This page has a nice overview on a
number of different systems and how to access this:
http://michaelstevenstech.com/bios_manufacturer.htm
Once in the BIOS, depending on how it is configured, you will generally find
rom shadowing under the more advanced options relating to the video and
processor.
Best of Luck,
> system
> there
> any hope ?
>> Hi,
>> while
>> system
>> options.
>> Best of Luck,
>> news:D93D553F-E85D-[email protected]
>> > big
>> > blue screen with
>> > of
S
Sugar
I have no ideal what look under C:/ windows/minidump means! But when this
computer blue screens I go to Problem Reporting in my control panel and it
shows Windows Modules Inst...WINDOWS-WCP-OTHER-FAILU... AND WHEN i VIEW THE
PROBLEM IT SAYS Windows Module Installer Os version:6.0.6000
File:Base/xml/udom_microdom.cpp Function:RTlcreatemicrodon
Line:4493 Status:c000a083 OSVersion:6.0.6000.2.0.0.768.3 Local
ID:1033 Files that help describe the problem poqexec.log
Cbs.log Memory.hdmp Minidump.mdmp I hope this is what you need
because most of the last reply I didnot and do not know what you are asking
for. Sugar
> Hi,
> processor.
> Best of Luck,
> > system
> > there
> > any hope ?
> >> Hi,
> >> while
> >> system
> >> options.
> >> Best of Luck,
> >> > big
> >> > blue screen with
> >> > of
R
Rick Rogers
Hi Sugar,
Click start, type "Windows Explorer". Right click the entry that appears in
the start menu and select 'run as administrator'. Click continue at the UAC
prompt. Click in the address bar of Windows Explorer, then type
"C:\Windows\minidump" and hit <enter>. You should see a collection of files
that start with "minixxxxxx-xx" where the x's are the creation date of the
file. I need you to send the one that is dated most recently (just right
click it and use 'send to/email').
If you cannot see the files I am referring to, click start and type 'control
folders' and hit <enter>. On the second (view) tab there are a number of
options to check and uncheck. Click the line to "show hidden files and
folders", and uncheck the box that hides operating system files. Then go
back and repeat the steps above.
Best of Luck,
> THE
> asking
> for. Sugar
>> Hi,
>> the
>> a
>> find
>> processor.
>> Best of Luck,
>> > no
>> > system
>> > there
>> > any hope ?
>> >> Hi,
>> >> while
>> >> system
>> >> options.
>> >> Best of Luck,
>> >> > this
>> >> > big
>> >> > blue screen with
>> >> > memory
>> >> > hours
>> >> > of
R
radakaiman
I'm getting the same type of error...
Problem signature:
Problem Event Name: BlueScreen
OS Version: 6.0.6000.2.0.0.768.3
Locale ID: 1033
Additional information about the problem:
BCCode: 50
BCP1: F524D880
BCP2: 00000000
BCP3: 81CE7527
BCP4: 00000002
OS Version: 6_0_6000
Service Pack: 0_0
Product: 768_1
I don't have an option to disable rom shadowing in my bios?
Any thoughts , possible a program i have installed?
> Hi Sugar,
> Best of Luck,
> > THE
> > asking
> > for. Sugar
> >> Hi,
> >> the
> >> a
> >> find
> >> processor.
> >> Best of Luck,
> >> > no
> >> > system
> >> > there
> >> > any hope ?
> >> >> Hi,
> >> >> while
> >> >> system
> >> >> options.
> >> >> Best of Luck,
> >> >> > this
> >> >> > big
> >> >> > blue screen with
> >> >> > memory
> >> >> > hours
> >> >> > of
R
Rick Rogers
Not all BIOS' will have the option, it's dependent on manufacturer. OEMs in
particular modify the instruction set to limit alteration by the end user.
The error, as stated with the originator of this thread, is a driver issue.
Check the event viewer to see if a module is listed as being involved.
Best of Luck,
"radakaiman" <[email protected]> wrote in message
> Problem signature:
> Locale ID: 1033
> BCCode: 50
> BCP1: F524D880
> BCP2: 00000000
> BCP3: 81CE7527
> BCP4: 00000002
> Service Pack: 0_0
> Product: 768_1
>> Hi Sugar,
>> in
>> UAC
>> files
>> the
>> 'control
>> Best of Luck,
>> >this
>> > it
>> > THE
>> > Local
>> > need
>> > asking
>> > for. Sugar
>> >> Hi,
>> >> recently
>> >> 'per
>> >> during
>> >> the
>> >> says
>> >> on
>> >> a
>> >> generally
>> >> find
>> >> and
>> >> processor.
>> >> Best of Luck,
>> >> > have
>> >> > no
>> >> > the
>> >> > system
>> >> > is
>> >> > there
>> >> > any hope ?
>> >> >> Hi,
>> >> >> a
>> >> >> while
>> >> >> about
>> >> >> system
>> >> >> advanced
>> >> >> options.
>> >> >> Best of Luck,
>> >> >> > this
>> >> >> > big
>> >> >> > blue screen with
>> >> >> > memory
>> >> >> > hours
>> >> >> > of
S
Sugar
I stopped my anti-virus,phishing filter,spam filter, and almost everything
else connected in that area and still to no avial-Blue Screen after a hour or
two.
> Hi,
> Best of Luck,
> > Problem signature:
> > Locale ID: 1033
> > BCCode: 50
> > BCP1: F524D880
> > BCP2: 00000000
> > BCP3: 81CE7527
> > BCP4: 00000002
> > Service Pack: 0_0
> > Product: 768_1
> >> Hi Sugar,
> >> in
> >> UAC
> >> files
> >> the
> >> 'control
> >> Best of Luck,
> >> >this
> >> > it
> >> > THE
> >> > Local
> >> > need
> >> > asking
> >> > for. Sugar
> >> >> Hi,
> >> >> recently
> >> >> 'per
> >> >> during
> >> >> the
> >> >> says
> >> >> on
> >> >> a
> >> >> generally
> >> >> find
> >> >> and
> >> >> processor.
> >> >> Best of Luck,
> >> >> > have
> >> >> > no
> >> >> > the
> >> >> > system
> >> >> > is
> >> >> > there
> >> >> > any hope ?
> >> >> >> Hi,
> >> >> >> a
> >> >> >> while
> >> >> >> about
> >> >> >> system
> >> >> >> advanced
> >> >> >> options.
> >> >> >> Best of Luck,
> >> >> >> > this
> >> >> >> > big
> >> >> >> > blue screen with
> >> >> >> > memory
> >> >> >> > hours
> >> >> >> > of
R
Rick Rogers
Have you sent the minidump file yet? I've not seen it.
Best of Luck,
> or
> two.
>> Hi,
>> in
>> user.
>> issue.
>> Best of Luck,
>> > Problem signature:
>> > Locale ID: 1033
>> > BCCode: 50
>> > BCP1: F524D880
>> > BCP2: 00000000
>> > BCP3: 81CE7527
>> > BCP4: 00000002
>> > Service Pack: 0_0
>> > Product: 768_1
>> >> Hi Sugar,
>> >> appears
>> >> in
>> >> the
>> >> UAC
>> >> files
>> >> the
>> >> right
>> >> 'control
>> >> of
>> >> go
>> >> Best of Luck,
>> >> >this
>> >> > and
>> >> > it
>> >> > VIEW
>> >> > THE
>> >> > Local
>> >> > need
>> >> > asking
>> >> > for. Sugar
>> >> >> Hi,
>> >> >> recently
>> >> >> of
>> >> >> 'per
>> >> >> during
>> >> >> the
>> >> >> that
>> >> >> says
>> >> >> overview
>> >> >> on
>> >> >> a
>> >> >> generally
>> >> >> find
>> >> >> and
>> >> >> processor.
>> >> >> Best of Luck,
>> >> >> > I
>> >> >> > have
>> >> >> > no
>> >> >> > access
>> >> >> > the
>> >> >> > system
>> >> >> > options.
>> >> >> > is
>> >> >> > there
>> >> >> > any hope ?
>> >> >> >> Hi,
>> >> >> >> for
>> >> >> >> a
>> >> >> >> while
>> >> >> >> is
>> >> >> >> about
>> >> >> >> the
>> >> >> >> system
>> >> >> >> advanced
>> >> >> >> options.
>> >> >> >> Best of Luck,
>> >> >> >> > get
>> >> >> >> > this
>> >> >> >> > big
>> >> >> >> > blue screen with
>> >> >> >> > bios
>> >> >> >> > memory
>> >> >> >> > 2-3
>> >> >> >> > hours
>> >> >> >> > of
S
Sugar
I sent the mini-dump on 10-14 and your reply was content non-specific w/Ref.
to Kernel file (ntkrnlpa exe.) I did more checking and don`t know how I did
it but I came up with a Summary Page evvent; Source:WerSvc Event id:5007
Level: Error Keyword : Classic I don`t know if this is involved too but I
found it somewhere on the computer.
> Best of Luck,
> > or
> > two.
> >> Hi,
> >> in
> >> user.
> >> issue.
> >> Best of Luck,
> >> > Problem signature:
> >> > Locale ID: 1033
> >> > BCCode: 50
> >> > BCP1: F524D880
> >> > BCP2: 00000000
> >> > BCP3: 81CE7527
> >> > BCP4: 00000002
> >> > Service Pack: 0_0
> >> > Product: 768_1
> >> >> Hi Sugar,
> >> >> appears
> >> >> in
> >> >> the
> >> >> UAC
> >> >> files
> >> >> the
> >> >> right
> >> >> 'control
> >> >> of
> >> >> go
> >> >> Best of Luck,
> >> >> >this
> >> >> > and
> >> >> > it
> >> >> > VIEW
> >> >> > THE
> >> >> > Local
> >> >> > need
> >> >> > asking
> >> >> > for. Sugar
> >> >> >> Hi,
> >> >> >> recently
> >> >> >> of
> >> >> >> 'per
> >> >> >> during
> >> >> >> the
> >> >> >> that
> >> >> >> says
> >> >> >> overview
> >> >> >> on
> >> >> >> a
> >> >> >> generally
> >> >> >> find
> >> >> >> and
> >> >> >> processor.
> >> >> >> Best of Luck,
> >> >> >> > I
> >> >> >> > have
> >> >> >> > no
> >> >> >> > access
> >> >> >> > the
> >> >> >> > system
> >> >> >> > options.
> >> >> >> > is
> >> >> >> > there
> >> >> >> > any hope ?
> >> >> >> >> Hi,
> >> >> >> >> for
> >> >> >> >> a
> >> >> >> >> while
> >> >> >> >> is
> >> >> >> >> about
> >> >> >> >> the
> >> >> >> >> system
> >> >> >> >> advanced
> >> >> >> >> options.
> >> >> >> >> Best of Luck,
> >> >> >> >> > get
> >> >> >> >> > this
> >> >> >> >> > big
> >> >> >> >> > blue screen with
> >> >> >> >> > bios
> >> >> >> >> > memory
> >> >> >> >> > 2-3
> >> >> >> >> > hours
> >> >> >> >> > of
R
Rick Rogers
Ok, I didn't connect that email with you. The event record doesn't help.
Best of Luck,
>w/Ref.
> did
> but I
>> Best of Luck,
>> >everything
>> > hour
>> > or
>> > two.
>> >> Hi,
>> >> OEMs
>> >> in
>> >> user.
>> >> issue.
>> >> Best of Luck,
>> >> > Problem signature:
>> >> > Locale ID: 1033
>> >> > BCCode: 50
>> >> > BCP1: F524D880
>> >> > BCP2: 00000000
>> >> > BCP3: 81CE7527
>> >> > BCP4: 00000002
>> >> > Service Pack: 0_0
>> >> > Product: 768_1
>> >> >> Hi Sugar,
>> >> >> appears
>> >> >> in
>> >> >> the
>> >> >> UAC
>> >> >> of
>> >> >> files
>> >> >> of
>> >> >> the
>> >> >> right
>> >> >> 'control
>> >> >> number
>> >> >> of
>> >> >> and
>> >> >> Then
>> >> >> go
>> >> >> Best of Luck,
>> >> >> >when
>> >> >> >this
>> >> >> > panel
>> >> >> > and
>> >> >> > it
>> >> >> > i
>> >> >> > VIEW
>> >> >> > THE
>> >> >> > Local
>> >> >> > poqexec.log
>> >> >> > you
>> >> >> > need
>> >> >> > are
>> >> >> > asking
>> >> >> > for. Sugar
>> >> >> >> Hi,
>> >> >> >> recently
>> >> >> >> line
>> >> >> >> of
>> >> >> >> 'per
>> >> >> >> keys
>> >> >> >> during
>> >> >> >> the
>> >> >> >> that
>> >> >> >> says
>> >> >> >> overview
>> >> >> >> on
>> >> >> >> a
>> >> >> >> generally
>> >> >> >> find
>> >> >> >> video
>> >> >> >> and
>> >> >> >> processor.
>> >> >> >> Best of Luck,
>> >> >> >> > I
>> >> >> >> > have
>> >> >> >> > no
>> >> >> >> > access
>> >> >> >> > the
>> >> >> >> > system
>> >> >> >> > options.
>> >> >> >> > is
>> >> >> >> > there
>> >> >> >> > any hope ?
>> >> >> >> >> Hi,
>> >> >> >> >> runs
>> >> >> >> >> for
>> >> >> >> >> a
>> >> >> >> >> while
>> >> >> >> >> that
>> >> >> >> >> is
>> >> >> >> >> anything
>> >> >> >> >> about
>> >> >> >> >> access
>> >> >> >> >> the
>> >> >> >> >> system
>> >> >> >> >> advanced
>> >> >> >> >> options.
>> >> >> >> >> Best of Luck,
>> >> >> >> >> > I
>> >> >> >> >> > get
>> >> >> >> >> > this
>> >> >> >> >> > big
>> >> >> >> >> > blue screen with
>> >> >> >> >> > bios
>> >> >> >> >> > memory
>> >> >> >> >> > about
>> >> >> >> >> > 2-3
>> >> >> >> >> > hours
>> >> >> >> >> > of
S
Sugar
I finally can look in C: and in Windows>System32>DRVSTORE all the letters
are in blue print and not black like the rest of the files, why is this in
blue? does this mean anything? also in C:Windows>Temp there has got to be a
bizillion files and most with nothing in them or 0kb ; also in my problem
report for windows it says Module Installer and files that help describe the
problem are poqexec.Log and I found this in C:Windows>winsxs and it says the
files are empty and I could not delete this file. I really really hope
something in here helps. thanx Sug
> Best of Luck,
> >w/Ref.
> > did
> > but I
> >> Best of Luck,
> >> >everything
> >> > hour
> >> > or
> >> > two.
> >> >> Hi,
> >> >> OEMs
> >> >> in
> >> >> user.
> >> >> issue.
> >> >> Best of Luck,
> >> >> > Problem signature:
> >> >> > Locale ID: 1033
> >> >> > BCCode: 50
> >> >> > BCP1: F524D880
> >> >> > BCP2: 00000000
> >> >> > BCP3: 81CE7527
> >> >> > BCP4: 00000002
> >> >> > Service Pack: 0_0
> >> >> > Product: 768_1
> >> >> >> Hi Sugar,
> >> >> >> appears
> >> >> >> in
> >> >> >> the
> >> >> >> UAC
> >> >> >> of
> >> >> >> files
> >> >> >> of
> >> >> >> the
> >> >> >> right
> >> >> >> 'control
> >> >> >> number
> >> >> >> of
> >> >> >> and
> >> >> >> Then
> >> >> >> go
> >> >> >> Best of Luck,
> >> >> >> >when
> >> >> >> >this
> >> >> >> > panel
> >> >> >> > and
> >> >> >> > it
> >> >> >> > i
> >> >> >> > VIEW
> >> >> >> > THE
> >> >> >> > Local
> >> >> >> > poqexec.log
> >> >> >> > you
> >> >> >> > need
> >> >> >> > are
> >> >> >> > asking
> >> >> >> > for. Sugar
> >> >> >> >> Hi,
> >> >> >> >> recently
> >> >> >> >> line
> >> >> >> >> of
> >> >> >> >> 'per
> >> >> >> >> keys
> >> >> >> >> during
> >> >> >> >> the
> >> >> >> >> that
> >> >> >> >> says
> >> >> >> >> overview
> >> >> >> >> on
> >> >> >> >> a
> >> >> >> >> generally
> >> >> >> >> find
> >> >> >> >> video
> >> >> >> >> and
> >> >> >> >> processor.
> >> >> >> >> Best of Luck,
> >> >> >> >> > I
> >> >> >> >> > have
> >> >> >> >> > no
> >> >> >> >> > access
> >> >> >> >> > the
> >> >> >> >> > system
> >> >> >> >> > options.
> >> >> >> >> > is
> >> >> >> >> > there
> >> >> >> >> > any hope ?
> >> >> >> >> >> Hi,
> >> >> >> >> >> runs
> >> >> >> >> >> for
> >> >> >> >> >> a
> >> >> >> >> >> while
> >> >> >> >> >> that
> >> >> >> >> >> is
> >> >> >> >> >> anything
> >> >> >> >> >> about
> >> >> >> >> >> access
> >> >> >> >> >> the
> >> >> >> >> >> system
> >> >> >> >> >> advanced
> >> >> >> >> >> options.
> >> >> >> >> >> Best of Luck,
> >> >> >> >> >> > I
> >> >> >> >> >> > get
> >> >> >> >> >> > this
> >> >> >> >> >> > big
> >> >> >> >> >> > blue screen with
> >> >> >> >> >> > bios
> >> >> >> >> >> > memory
> >> >> >> >> >> > about
> >> >> >> >> >> > 2-3
> >> >> >> >> >> > hours
> >> >> >> >> >> > of
R
Rick Rogers
The blue color indicates they are compressed - did you somehow manage to do
this from the Windows system folder advanced properties? They are not
normally compressed, or is it just files within that folder?
Have you opened the log file to see what information it may contain?
Best of Luck,
> a
> the
> the
>> Best of Luck,
>> >w/Ref.
>> > I
>> > did
>> > but I
>> >> Best of Luck,
>> >> >everything
>> >> > a
>> >> > hour
>> >> > or
>> >> > two.
>> >> >> Hi,
>> >> >> OEMs
>> >> >> in
>> >> >> end
>> >> >> user.
>> >> >> driver
>> >> >> issue.
>> >> >> involved.
>> >> >> Best of Luck,
>> >> >> message
>> >> >> > Problem signature:
>> >> >> > Locale ID: 1033
>> >> >> > BCCode: 50
>> >> >> > BCP1: F524D880
>> >> >> > BCP2: 00000000
>> >> >> > BCP3: 81CE7527
>> >> >> > BCP4: 00000002
>> >> >> > Service Pack: 0_0
>> >> >> > Product: 768_1
>> >> >> >> Hi Sugar,
>> >> >> >> appears
>> >> >> >> in
>> >> >> >> at
>> >> >> >> the
>> >> >> >> UAC
>> >> >> >> collection
>> >> >> >> of
>> >> >> >> files
>> >> >> >> date
>> >> >> >> of
>> >> >> >> the
>> >> >> >> (just
>> >> >> >> right
>> >> >> >> type
>> >> >> >> 'control
>> >> >> >> number
>> >> >> >> of
>> >> >> >> files
>> >> >> >> and
>> >> >> >> Then
>> >> >> >> go
>> >> >> >> Best of Luck,
>> >> >> >> >when
>> >> >> >> >this
>> >> >> >> > panel
>> >> >> >> > and
>> >> >> >> > it
>> >> >> >> > WHEN
>> >> >> >> > i
>> >> >> >> > VIEW
>> >> >> >> > THE
>> >> >> >> > version:6.0.6000
>> >> >> >> > Local
>> >> >> >> > poqexec.log
>> >> >> >> > what
>> >> >> >> > you
>> >> >> >> > need
>> >> >> >> > you
>> >> >> >> > are
>> >> >> >> > asking
>> >> >> >> > for. Sugar
>> >> >> >> >> Hi,
>> >> >> >> >> most
>> >> >> >> >> recently
>> >> >> >> >> line
>> >> >> >> >> of
>> >> >> >> >> 'per
>> >> >> >> >> keys
>> >> >> >> >> during
>> >> >> >> >> the
>> >> >> >> >> message
>> >> >> >> >> that
>> >> >> >> >> says
>> >> >> >> >> overview
>> >> >> >> >> on
>> >> >> >> >> a
>> >> >> >> >> generally
>> >> >> >> >> find
>> >> >> >> >> video
>> >> >> >> >> and
>> >> >> >> >> processor.
>> >> >> >> >> Best of Luck,
>> >> >> >> >> > up
>> >> >> >> >> > I
>> >> >> >> >> > have
>> >> >> >> >> > no
>> >> >> >> >> > access
>> >> >> >> >> > the
>> >> >> >> >> > system
>> >> >> >> >> > options.
>> >> >> >> >> > is
>> >> >> >> >> > there
>> >> >> >> >> > any hope ?
>> >> >> >> >> >> Hi,
>> >> >> >> >> >> runs
>> >> >> >> >> >> for
>> >> >> >> >> >> a
>> >> >> >> >> >> while
>> >> >> >> >> >> component
>> >> >> >> >> >> that
>> >> >> >> >> >> is
>> >> >> >> >> >> anything
>> >> >> >> >> >> about
>> >> >> >> >> >> access
>> >> >> >> >> >> the
>> >> >> >> >> >> system
>> >> >> >> >> >> the
>> >> >> >> >> >> advanced
>> >> >> >> >> >> options.
>> >> >> >> >> >> Best of Luck,
>> >> >> >> >> >> > Home;
>> >> >> >> >> >> > I
>> >> >> >> >> >> > get
>> >> >> >> >> >> > this
>> >> >> >> >> >> > big
>> >> >> >> >> >> > blue screen with
>> >> >> >> >> >> > disable
>> >> >> >> >> >> > bios
>> >> >> >> >> >> > memory
>> >> >> >> >> >> > about
>> >> >> >> >> >> > 2-3
>> >> >> >> >> >> > hours
>> >> >> >> >> >> > of
S
Sugar
Yes I found my way into the advanced properties and it said I could free up
space to compress zip something and yes I did. I have tried to open folders
in most of everything but it won`t let me open anything I have tried browsing
other applications even media center but I still cannot open anything, I
believe I may have compressed this in the last day or two as I have been
trying anything and everything to stop this blue screen.
> Hi,
> Best of Luck,
> > a
> > the
> > the
> >> Best of Luck,
> >> >w/Ref.
> >> > I
> >> > did
> >> > but I
> >> >> Best of Luck,
> >> >> >everything
> >> >> > a
> >> >> > hour
> >> >> > or
> >> >> > two.
> >> >> >> Hi,
> >> >> >> OEMs
> >> >> >> in
> >> >> >> end
> >> >> >> user.
> >> >> >> driver
> >> >> >> issue.
> >> >> >> involved.
> >> >> >> Best of Luck,
> >> >> >> message
> >> >> >> > Problem signature:
> >> >> >> > Locale ID: 1033
> >> >> >> > BCCode: 50
> >> >> >> > BCP1: F524D880
> >> >> >> > BCP2: 00000000
> >> >> >> > BCP3: 81CE7527
> >> >> >> > BCP4: 00000002
> >> >> >> > Service Pack: 0_0
> >> >> >> > Product: 768_1
> >> >> >> >> Hi Sugar,
> >> >> >> >> appears
> >> >> >> >> in
> >> >> >> >> at
> >> >> >> >> the
> >> >> >> >> UAC
> >> >> >> >> collection
> >> >> >> >> of
> >> >> >> >> files
> >> >> >> >> date
> >> >> >> >> of
> >> >> >> >> the
> >> >> >> >> (just
> >> >> >> >> right
> >> >> >> >> type
> >> >> >> >> 'control
> >> >> >> >> number
> >> >> >> >> of
> >> >> >> >> files
> >> >> >> >> and
> >> >> >> >> Then
> >> >> >> >> go
> >> >> >> >> Best of Luck,
> >> >> >> >> >when
> >> >> >> >> >this
> >> >> >> >> > panel
> >> >> >> >> > and
> >> >> >> >> > it
> >> >> >> >> > WHEN
> >> >> >> >> > i
> >> >> >> >> > VIEW
> >> >> >> >> > THE
> >> >> >> >> > version:6.0.6000
> >> >> >> >> > Local
> >> >> >> >> > poqexec.log
> >> >> >> >> > what
> >> >> >> >> > you
> >> >> >> >> > need
> >> >> >> >> > you
> >> >> >> >> > are
> >> >> >> >> > asking
> >> >> >> >> > for. Sugar
> >> >> >> >> >> Hi,
> >> >> >> >> >> most
> >> >> >> >> >> recently
> >> >> >> >> >> line
> >> >> >> >> >> of
> >> >> >> >> >> 'per
> >> >> >> >> >> keys
> >> >> >> >> >> during
> >> >> >> >> >> the
> >> >> >> >> >> message
> >> >> >> >> >> that
> >> >> >> >> >> says
> >> >> >> >> >> overview
> >> >> >> >> >> on
> >> >> >> >> >> a
> >> >> >> >> >> generally
> >> >> >> >> >> find
> >> >> >> >> >> video
> >> >> >> >> >> and
> >> >> >> >> >> processor.
> >> >> >> >> >> Best of Luck,
> >> >> >> >> >> > up
> >> >> >> >> >> > I
> >> >> >> >> >> > have
> >> >> >> >> >> > no
> >> >> >> >> >> > access
> >> >> >> >> >> > the
> >> >> >> >> >> > system
> >> >> >> >> >> > options.
> >> >> >> >> >> > is
> >> >> >> >> >> > there
> >> >> >> >> >> > any hope ?
> >> >> >> >> >> >> Hi,
> >> >> >> >> >> >> runs
> >> >> >> >> >> >> for
> >> >> >> >> >> >> a
> >> >> >> >> >> >> while
> >> >> >> >> >> >> component
> >> >> >> >> >> >> that
> >> >> >> >> >> >> is
> >> >> >> >> >> >> anything
> >> >> >> >> >> >> about
> >> >> >> >> >> >> access
> >> >> >> >> >> >> the
> >> >> >> >> >> >> system
> >> >> >> >> >> >> the
> >> >> >> >> >> >> advanced
> >> >> >> >> >> >> options.
> >> >> >> >> >> >> Best of Luck,
R
Rick Rogers
Start by undoing the compression. Trying things hit & miss is very unlikey
to resolve the problem, but let's start by undoing whatever you've done so
far.
Best of Luck,
> up
> folders
> browsing
>> Hi,
>> do
>> Best of Luck,
>> >letters
>> > in
>> > be
>> > a
>> > problem
>> > describe
>> > the
>> > says
>> > the
>> >> help.
>> >> Best of Luck,
>> >> >w/Ref.
>> >> > how
>> >> > I
>> >> > did
>> >> > too
>> >> > but I
>> >> >> Best of Luck,
>> >> >> >everything
>> >> >> > after
>> >> >> > a
>> >> >> > hour
>> >> >> > or
>> >> >> > two.
>> >> >> >> Hi,
>> >> >> >> manufacturer.
>> >> >> >> OEMs
>> >> >> >> in
>> >> >> >> end
>> >> >> >> user.
>> >> >> >> driver
>> >> >> >> issue.
>> >> >> >> involved.
>> >> >> >> Best of Luck,
>> >> >> >> message
>> >> >> >> > Problem signature:
>> >> >> >> > Locale ID: 1033
>> >> >> >> > BCCode: 50
>> >> >> >> > BCP1: F524D880
>> >> >> >> > BCP2: 00000000
>> >> >> >> > BCP3: 81CE7527
>> >> >> >> > BCP4: 00000002
>> >> >> >> > Service Pack: 0_0
>> >> >> >> > Product: 768_1
>> >> >> >> >> Hi Sugar,
>> >> >> >> >> that
>> >> >> >> >> appears
>> >> >> >> >> in
>> >> >> >> >> continue
>> >> >> >> >> at
>> >> >> >> >> the
>> >> >> >> >> UAC
>> >> >> >> >> type
>> >> >> >> >> collection
>> >> >> >> >> of
>> >> >> >> >> files
>> >> >> >> >> creation
>> >> >> >> >> date
>> >> >> >> >> of
>> >> >> >> >> the
>> >> >> >> >> (just
>> >> >> >> >> right
>> >> >> >> >> and
>> >> >> >> >> type
>> >> >> >> >> 'control
>> >> >> >> >> a
>> >> >> >> >> number
>> >> >> >> >> of
>> >> >> >> >> files
>> >> >> >> >> and
>> >> >> >> >> files.
>> >> >> >> >> Then
>> >> >> >> >> go
>> >> >> >> >> Best of Luck,
>> >> >> >> >> >But
>> >> >> >> >> >when
>> >> >> >> >> >this
>> >> >> >> >> > control
>> >> >> >> >> > panel
>> >> >> >> >> > and
>> >> >> >> >> > it
>> >> >> >> >> > WHEN
>> >> >> >> >> > i
>> >> >> >> >> > VIEW
>> >> >> >> >> > THE
>> >> >> >> >> > version:6.0.6000
>> >> >> >> >> > Local
>> >> >> >> >> > poqexec.log
>> >> >> >> >> > what
>> >> >> >> >> > you
>> >> >> >> >> > need
>> >> >> >> >> > what
>> >> >> >> >> > you
>> >> >> >> >> > are
>> >> >> >> >> > asking
>> >> >> >> >> > for. Sugar
>> >> >> >> >> >> Hi,
>> >> >> >> >> >> the
>> >> >> >> >> >> most
>> >> >> >> >> >> recently
>> >> >> >> >> >> subject
>> >> >> >> >> >> line
>> >> >> >> >> >> of
>> >> >> >> >> >> 'per
>> >> >> >> >> >> it).
>> >> >> >> >> >> appropriate
>> >> >> >> >> >> keys
>> >> >> >> >> >> during
>> >> >> >> >> >> the
>> >> >> >> >> >> message
>> >> >> >> >> >> that
>> >> >> >> >> >> says
>> >> >> >> >> >> nice
>> >> >> >> >> >> overview
>> >> >> >> >> >> on
>> >> >> >> >> >> a
>> >> >> >> >> >> will
>> >> >> >> >> >> generally
>> >> >> >> >> >> find
>> >> >> >> >> >> the
>> >> >> >> >> >> video
>> >> >> >> >> >> and
>> >> >> >> >> >> processor.
>> >> >> >> >> >> Best of Luck,
>> >> >> >> >> >> > shows
>> >> >> >> >> >> > up
>> >> >> >> >> >> > I
>> >> >> >> >> >> > have
>> >> >> >> >> >> > no
>> >> >> >> >> >> > to
>> >> >> >> >> >> > access
>> >> >> >> >> >> > the
>> >> >> >> >> >> > system
>> >> >> >> >> >> > advance
>> >> >> >> >> >> > options.
>> >> >> >> >> >> > is
>> >> >> >> >> >> > there
>> >> >> >> >> >> > any hope ?
>> >> >> >> >> >> >> Hi,
>> >> >> >> >> >> >> system
>> >> >> >> >> >> >> runs
>> >> >> >> >> >> >> for
>> >> >> >> >> >> >> a
>> >> >> >> >> >> >> while
>> >> >> >> >> >> >> component
>> >> >> >> >> >> >> that
>> >> >> >> >> >> >> is
>> >> >> >> >> >> >> anything
>> >> >> >> >> >> >> about
>> >> >> >> >> >> >> to
>> >> >> >> >> >> >> access
>> >> >> >> >> >> >> the
>> >> >> >> >> >> >> system
>> >> >> >> >> >> >> the
>> >> >> >> >> >> >> advanced
>> >> >> >> >> >> >> options.
>> >> >> >> >> >> >> Best of Luck,
S
Sugar
OK I uncompressed the DRVSTORE in System32 I had also deleated my browsing
history but that is gone now.
> Hi,
> far.
> Best of Luck,
> > up
> > folders
> > browsing
> >> Hi,
> >> do
> >> Best of Luck,
> >> news:AC546EF5-4697-4811-814A-412239F0[email protected]
> >> >letters
> >> > in
> >> > be
> >> > a
> >> > problem
> >> > describe
> >> > the
> >> > says
> >> > the
> >> >> help.
> >> >> Best of Luck,
> >> >> >w/Ref.
> >> >> > how
> >> >> > I
> >> >> > did
> >> >> > too
> >> >> > but I
> >> >> >> Best of Luck,
> >> >> >> >everything
> >> >> >> > after
> >> >> >> > a
> >> >> >> > hour
> >> >> >> > or
> >> >> >> > two.
> >> >> >> >> Hi,
> >> >> >> >> manufacturer.
> >> >> >> >> OEMs
> >> >> >> >> in
> >> >> >> >> end
> >> >> >> >> user.
> >> >> >> >> driver
> >> >> >> >> issue.
> >> >> >> >> involved.
> >> >> >> >> Best of Luck,
> >> >> >> >> message
> >> >> >> >> > Problem signature:
> >> >> >> >> > Locale ID: 1033
> >> >> >> >> > BCCode: 50
> >> >> >> >> > BCP1: F524D880
> >> >> >> >> > BCP2: 00000000
> >> >> >> >> > BCP3: 81CE7527
> >> >> >> >> > BCP4: 00000002
> >> >> >> >> > Service Pack: 0_0
> >> >> >> >> > Product: 768_1
> >> >> >> >> >> Hi Sugar,
> >> >> >> >> >> that
> >> >> >> >> >> appears
> >> >> >> >> >> in
> >> >> >> >> >> continue
> >> >> >> >> >> at
> >> >> >> >> >> the
> >> >> >> >> >> UAC
> >> >> >> >> >> type
> >> >> >> >> >> collection
> >> >> >> >> >> of
> >> >> >> >> >> files
> >> >> >> >> >> creation
> >> >> >> >> >> date
> >> >> >> >> >> of
> >> >> >> >> >> the
> >> >> >> >> >> (just
> >> >> >> >> >> right
> >> >> >> >> >> and
> >> >> >> >> >> type
> >> >> >> >> >> 'control
> >> >> >> >> >> a
> >> >> >> >> >> number
> >> >> >> >> >> of
> >> >> >> >> >> files
> >> >> >> >> >> and
> >> >> >> >> >> files.
> >> >> >> >> >> Then
> >> >> >> >> >> go
> >> >> >> >> >> Best of Luck,
> >> >> >> >> >> >But
> >> >> >> >> >> >when
> >> >> >> >> >> >this
> >> >> >> >> >> > control
> >> >> >> >> >> > panel
> >> >> >> >> >> > and
> >> >> >> >> >> > it
> >> >> >> >> >> > WHEN
> >> >> >> >> >> > i
> >> >> >> >> >> > VIEW
> >> >> >> >> >> > THE
> >> >> >> >> >> > version:6.0.6000
> >> >> >> >> >> > Local
> >> >> >> >> >> > poqexec.log
> >> >> >> >> >> > what
> >> >> >> >> >> > you
> >> >> >> >> >> > need
> >> >> >> >> >> > what
> >> >> >> >> >> > you
> >> >> >> >> >> > are
> >> >> >> >> >> > asking
> >> >> >> >> >> > for. Sugar
> >> >> >> >> >> >> Hi,
> >> >> >> >> >> >> the
> >> >> >> >> >> >> most
> >> >> >> >> >> >> recently
> >> >> >> >> >> >> subject
> >> >> >> >> >> >> line
> >> >> >> >> >> >> of
> >> >> >> >> >> >> 'per
> >> >> >> >> >> >> it).
> >> >> >> >> >> >> appropriate
> >> >> >> >> >> >> keys
> >> >> >> >> >> >> during
> >> >> >> >> >> >> the
> >> >> >> >> >> >> message
> >> >> >> >> >> >> that
> >> >> >> >> >> >> says
> >> >> >> >> >> >> nice
> >> >> >> >> >> >> overview
> >> >> >> >> >> >> on
> >> >> >> >> >> >> a
> >> >> >> >> >> >> will
> >> >> >> >> >> >> generally
> >> >> >> >> >> >> find
> >> >> >> >> >> >> the
> >> >> >> >> >> >> video
> >> >> >> >> >> >> and
> >> >> >> >> >> >> processor.
> >> >> >> >> >> >> Best of Luck,
R
Rick Rogers
Ok, can you now send me the poqexec.log, same conditions as with the memory
dump.
Also, what Antivirus program do you have installed?
Best of Luck,
> browsing
>> Hi,
>> unlikey
>> so
>> far.
>> Best of Luck,
>> > free
>> > up
>> > folders
>> > browsing
>> > I
>> > been
>> >> Hi,
>> >> to
>> >> do
>> >> Best of Luck,
>> >> >letters
>> >> > this
>> >> > in
>> >> > to
>> >> > be
>> >> > a
>> >> > problem
>> >> > describe
>> >> > the
>> >> > says
>> >> > the
>> >> > hope
>> >> >> help.
>> >> >> Best of Luck,
>> >> >> >non-specific
>> >> >> >w/Ref.
>> >> >> > know
>> >> >> > how
>> >> >> > I
>> >> >> > did
>> >> >> > Event
>> >> >> > involved
>> >> >> > too
>> >> >> > but I
>> >> >> >> Best of Luck,
>> >> >> >> >everything
>> >> >> >> > after
>> >> >> >> > a
>> >> >> >> > hour
>> >> >> >> > or
>> >> >> >> > two.
>> >> >> >> >> Hi,
>> >> >> >> >> manufacturer.
>> >> >> >> >> OEMs
>> >> >> >> >> in
>> >> >> >> >> the
>> >> >> >> >> end
>> >> >> >> >> user.
>> >> >> >> >> driver
>> >> >> >> >> issue.
>> >> >> >> >> involved.
>> >> >> >> >> Best of Luck,
>> >> >> >> >> message
>> >> >> >> >> > Problem signature:
>> >> >> >> >> > Locale ID: 1033
>> >> >> >> >> > BCCode: 50
>> >> >> >> >> > BCP1: F524D880
>> >> >> >> >> > BCP2: 00000000
>> >> >> >> >> > BCP3: 81CE7527
>> >> >> >> >> > BCP4: 00000002
>> >> >> >> >> > Service Pack: 0_0
>> >> >> >> >> > Product: 768_1
>> >> >> >> >> >> Hi Sugar,
>> >> >> >> >> >> entry
>> >> >> >> >> >> that
>> >> >> >> >> >> appears
>> >> >> >> >> >> in
>> >> >> >> >> >> continue
>> >> >> >> >> >> at
>> >> >> >> >> >> the
>> >> >> >> >> >> UAC
>> >> >> >> >> >> type
>> >> >> >> >> >> collection
>> >> >> >> >> >> of
>> >> >> >> >> >> files
>> >> >> >> >> >> creation
>> >> >> >> >> >> date
>> >> >> >> >> >> of
>> >> >> >> >> >> the
>> >> >> >> >> >> recently
>> >> >> >> >> >> (just
>> >> >> >> >> >> right
>> >> >> >> >> >> and
>> >> >> >> >> >> type
>> >> >> >> >> >> 'control
>> >> >> >> >> >> are
>> >> >> >> >> >> a
>> >> >> >> >> >> number
>> >> >> >> >> >> of
>> >> >> >> >> >> hidden
>> >> >> >> >> >> files
>> >> >> >> >> >> and
>> >> >> >> >> >> files.
>> >> >> >> >> >> Then
>> >> >> >> >> >> go
>> >> >> >> >> >> Best of Luck,
>> >> >> >> >> >> >means!
>> >> >> >> >> >> >But
>> >> >> >> >> >> >when
>> >> >> >> >> >> >this
>> >> >> >> >> >> > control
>> >> >> >> >> >> > panel
>> >> >> >> >> >> > and
>> >> >> >> >> >> > it
>> >> >> >> >> >> > AND
>> >> >> >> >> >> > WHEN
>> >> >> >> >> >> > i
>> >> >> >> >> >> > VIEW
>> >> >> >> >> >> > THE
>> >> >> >> >> >> > version:6.0.6000
>> >> >> >> >> >> > Local
>> >> >> >> >> >> > poqexec.log
>> >> >> >> >> >> > is
>> >> >> >> >> >> > what
>> >> >> >> >> >> > you
>> >> >> >> >> >> > need
>> >> >> >> >> >> > what
>> >> >> >> >> >> > you
>> >> >> >> >> >> > are
>> >> >> >> >> >> > asking
>> >> >> >> >> >> > for. Sugar
>> >> >> >> >> >> >> Hi,
>> >> >> >> >> >> >> the
>> >> >> >> >> >> >> most
>> >> >> >> >> >> >> recently
>> >> >> >> >> >> >> subject
>> >> >> >> >> >> >> line
>> >> >> >> >> >> >> of
>> >> >> >> >> >> >> 'per
>> >> >> >> >> >> >> see
>> >> >> >> >> >> >> it).
>> >> >> >> >> >> >> appropriate
>> >> >> >> >> >> >> keys
>> >> >> >> >> >> >> during
>> >> >> >> >> >> >> the
>> >> >> >> >> >> >> message
>> >> >> >> >> >> >> that
>> >> >> >> >> >> >> says
>> >> >> >> >> >> >> nice
>> >> >> >> >> >> >> overview
>> >> >> >> >> >> >> on
>> >> >> >> >> >> >> a
>> >> >> >> >> >> >> you
>> >> >> >> >> >> >> will
>> >> >> >> >> >> >> generally
>> >> >> >> >> >> >> find
>> >> >> >> >> >> >> to
>> >> >> >> >> >> >> the
>> >> >> >> >> >> >> video
>> >> >> >> >> >> >> and
>> >> >> >> >> >> >> processor.
>> >> >> >> >> >> >> Best of Luck,
S
Sugar
I sent the poqexec.log file but it had nothing init (I think) cuz it would
not let me open it up and also i sent you the list of my antivirus programs
and I tried to shut them off but I think i may have deleated them as they
don`t work now. Sugar
> dump.
> Best of Luck,
> > browsing
> >> Hi,
> >> unlikey
> >> so
> >> far.
> >> Best of Luck,
> >> > free
> >> > up
> >> > folders
> >> > browsing
> >> > I
> >> > been
> >> >> Hi,
> >> >> to
> >> >> do
> >> >> Best of Luck,
> >> >> >letters
> >> >> > this
> >> >> > in
> >> >> > to
> >> >> > be
> >> >> > a
> >> >> > problem
> >> >> > describe
> >> >> > the
> >> >> > says
> >> >> > the
> >> >> > hope
> >> >> >> help.
> >> >> >> Best of Luck,
> >> >> >> >non-specific
> >> >> >> >w/Ref.
> >> >> >> > know
> >> >> >> > how
> >> >> >> > I
> >> >> >> > did
> >> >> >> > Event
> >> >> >> > involved
> >> >> >> > too
> >> >> >> > but I
> >> >> >> >> Best of Luck,
> >> >> >> >> >everything
> >> >> >> >> > after
> >> >> >> >> > a
> >> >> >> >> > hour
> >> >> >> >> > or
> >> >> >> >> > two.
> >> >> >> >> >> Hi,
> >> >> >> >> >> manufacturer.
> >> >> >> >> >> OEMs
> >> >> >> >> >> in
> >> >> >> >> >> the
> >> >> >> >> >> end
> >> >> >> >> >> user.
> >> >> >> >> >> driver
> >> >> >> >> >> issue.
> >> >> >> >> >> involved.
> >> >> >> >> >> Best of Luck,
> >> >> >> >> >> message
> >> >> >> >> >> > Problem signature:
> >> >> >> >> >> > Locale ID: 1033
> >> >> >> >> >> > BCCode: 50
> >> >> >> >> >> > BCP1: F524D880
> >> >> >> >> >> > BCP2: 00000000
> >> >> >> >> >> > BCP3: 81CE7527
> >> >> >> >> >> > BCP4: 00000002
> >> >> >> >> >> > Service Pack: 0_0
> >> >> >> >> >> > Product: 768_1
> >> >> >> >> >> >> Hi Sugar,
> >> >> >> >> >> >> entry
> >> >> >> >> >> >> that
> >> >> >> >> >> >> appears
> >> >> >> >> >> >> in
> >> >> >> >> >> >> continue
> >> >> >> >> >> >> at
> >> >> >> >> >> >> the
> >> >> >> >> >> >> UAC
> >> >> >> >> >> >> type
> >> >> >> >> >> >> collection
> >> >> >> >> >> >> of
> >> >> >> >> >> >> files
> >> >> >> >> >> >> creation
> >> >> >> >> >> >> date
> >> >> >> >> >> >> of
> >> >> >> >> >> >> the
> >> >> >> >> >> >> recently
> >> >> >> >> >> >> (just
> >> >> >> >> >> >> right
> >> >> >> >> >> >> and
> >> >> >> >> >> >> type
> >> >> >> >> >> >> 'control
> >> >> >> >> >> >> are
> >> >> >> >> >> >> a
> >> >> >> >> >> >> number
> >> >> >> >> >> >> of
> >> >> >> >> >> >> hidden
> >> >> >> >> >> >> files
> >> >> >> >> >> >> and
> >> >> >> >> >> >> files.
> >> >> >> >> >> >> Then
> >> >> >> >> >> >> go
> >> >> >> >> >> >> Best of Luck,
> >> >> >> >> >> >> >means!
> >> >> >> >> >> >> >But
> >> >> >> >> >> >> >when
> >> >> >> >> >> >> >this
> >> >> >> >> >> >> > control
> >> >> >> >> >> >> > panel
> >> >> >> >> >> >> > and
> >> >> >> >> >> >> > it
> >> >> >> >> >> >> > AND
> >> >> >> >> >> >> > WHEN
> >> >> >> >> >> >> > i
> >> >> >> >> >> >> > VIEW
> >> >> >> >> >> >> > THE
> >> >> >> >> >> >> > version:6.0.6000
> >> >> >> >> >> >> > Local
> >> >> >> >> >> >> > poqexec.log
> >> >> >> >> >> >> > is
> >> >> >> >> >> >> > what
> >> >> >> >> >> >> > you
> >> >> >> >> >> >> > need
> >> >> >> >> >> >> > what
> >> >> >> >> >> >> > you
> >> >> >> >> >> >> > are
> >> >> >> >> >> >> > asking
> >> >> >> >> >> >> > for. Sugar
> >> >> >> >> >> >> >> Hi,
> >> >> >> >> >> >> >> the
> >> >> >> >> >> >> >> most
> >> >> >> >> >> >> >> recently
S
Sugar
Did you find out what is causing your blue screen? I`m still fighting with
mine.
> Problem signature:
> Locale ID: 1033
> BCCode: 50
> BCP1: F524D880
> BCP2: 00000000
> BCP3: 81CE7527
> BCP4: 00000002
> Service Pack: 0_0
> Product: 768_1
> > Hi Sugar,
> > Best of Luck,
> > > THE
> > > asking
> > > for. Sugar
> > >> Hi,
> > >> the
> > >> a
> > >> find
> > >> processor.
> > >> Best of Luck,
> > >> > no
> > >> > system
> > >> > there
> > >> > any hope ?
> > >> >> Hi,
> > >> >> while
> > >> >> system
> > >> >> options.
> > >> >> Best of Luck,
> > >> >> > this
> > >> >> > big
> > >> >> > blue screen with
> > >> >> > memory
> > >> >> > hours
> > >> >> > of
