Parallel installation of VC6, VS2003 and VS2008
P
PawelSokolowski
On Jul 15, 10:35 pm, "PawelSokolowski" <PeeS...@xxxxxx> wrote:
> Hi all.,
> For quite some time I have been using VC 6.0 and VS2003 on the same
> computer.
> I have read somewhere, that VC 6.0 should be installed as a second.
> Now I have to use also VS2008.
> Is it possible to use all three of them without interfering one to another ?
> How to install them ?
> Best Regards
> Pawel
I think it is safer to assume that installing the oldest product first
is the better way since MS would have thought about checking for
previous version when installing a newer product.
P
PvdG42
"PawelSokolowski" <PeeS290@xxxxxx> wrote in message
news:u8xk%23fo5IHA.2060@xxxxxx
> Hi all.,
> computer.
> Best Regards
> Pawel
Yes. You should be OK just installing VS 2008 on your current setup (with
VC6 and VS 2003 already installed). VS 2008 is a separate product.
> Hi all.,
> computer.
> Best Regards
> Pawel
