Parental Controls - blocking proxy sites
K
keona1995
Blocking objectionable and vicious sites is a very useful feature. How does
one block proxy sites that are not in themselves objectionable, but allow a
child to defeat parental controls simply by entering the names of the bad
sites? Is there an easy way to do this without inputting the thousands of
proxy sites?
Thank you for your help.
keona1995
"keona1995" <keona1995@xxxxxx> wrote in message
news:D1DFD28E-C486-47EE-B804-FB474A7839E9@xxxxxx
> does
> a
> proxy sites?
> keona1995
This is a good question, since there are different types of proxies.
You can set Internet Explorer to work with a proxy, of which there are
thousands available as you say, but it should be possible to disable this
feature- possibly disabling the 'Winhttp Web Proxy Auto discovery service'
may help there via services.msc - or if that's not it then there is probably
some other settting that will disable it.
What would be harder to disable though would be websites that simply take
your request and then present you with the website. I don't know how you
could disable those completely, other than blocking those particular sites -
BUT there are fewer of them, so you could probably dispense with 90% of them
by blocking those particular sites.
Someone else better qualified in this area may have a better solution.
Jon
B
Bob Willard
> proxy sites?
The best parental control is physical presence; technology is not a good
substitute for actual parenting. Move your kid's PCs into the most public
room in your house, then remind the kids that you have a right and an
obligation to monitor their online activities, then do so: look over their
shoulders while they are online, and check the history files.
In my house, IM is a no-no, and we do cut off 'net access when we find they
have created Facebook/Myspace/etc. entries without our permission. If it
helps, you can setup many routers to disable 'net access during times when
you are not present.
Cheers, Bob
