S
software
if your OS partition out of partition ,you can use partition wizard to extend the space large :
Disk is configured 2 partitions. One system partition and another partition (for data) next to system partition. Assume partition C is system drive, partition D is next to partition C.
1. Close applications running on D so that you don't have to reboot.
2. Launch Partition Wizard.
3. Right click the partition D and select "move/resize".
4. Position the mouse pointer to the right edge of the partition. When the mouse pointer changes to a double-headed arrow, drag mouse to the left to change partition size.
5. Click "Ok". Partition layout preview will display an unallocated space is created between C and D partition.
6. Right click the partition C and select "move/resize".
7. Position the mouse pointer to the right edge of the partition. When the mouse pointer changes to a double-headed arrow, drag mouse to the right to extend C partition.
8. Click "Ok". C partition is extend.
9. Click "Apply".
ssirman wrote:
OS Partition out of space!!!!
29-May-08
I have a server that the builder only gave a 4gig OS partition. Plenty of
space is left on the data partion.
OS partition is almost full.
What are my options to remedy other than building a new server, with a
proper OS partion size, and forklift the data.
This is a file server and drive is part of a raid 5 configuration.
Any ideas????
Previous Posts In This Thread:
On Thursday, May 29, 2008 1:47 PM
Any ideas????
On Thursday, May 29, 2008 1:57 PM
Danny Sanders wrote:
Move the pagefile?
Move the pagefile?
hth
DDS
On Thursday, May 29, 2008 2:15 PM
ssirman wrote:
Sorry...should have mentioned that was done.
As well as anything else I can think of. Got it down to the bare minimum.
At this point, there is either a way to extend this partion, or seriously
decrease the OS footprint....
What are my options?
Thanks for the reply!!!
"Danny Sanders" wrote:
On Thursday, May 29, 2008 2:32 PM
either rebuild the server or look into some third party partition software
like Partition magic
hth
DDS
On Thursday, May 29, 2008 5:02 PM
leew [MVP] wrote:
Re: OS Partition out of space!!!!
ssirmans wrote:
You want options... I will give you options... :-)
http://www.lwcomputing.com/tips/static/bootdrivesize.asp
About 20 different things you can do to recover disk space.
-Lee
Submitted via EggHeadCafe - Software Developer Portal of Choice
XAML Organizer
http://www.eggheadcafe.com/tutorials/aspnet/ac373a5d-e497-4e07-9186-12166e83a024/xaml-organizer.aspx
9. Click "Apply".
29-May-08
Any ideas????
Any ideas????
Move the pagefile?
Move the pagefile?
hth
DDS
hth
DDS
-Lee
XAML Organizer
