In the code below [my5.stuff]::EnumDisplayDevices($null,1,[ref]$test,0)
does not work because the $null is cast as ""
The following line does return true but $test is not populated with the expected details.
Presumably this is because [my5.DISPLAY_DEVICE]$test is not a reference
$obj.gettype().getmethod("EnumDisplayDevices").invoke($obj,@($null,[uint32]0,[my5.DISPLAY_DEVICE]$test,[uint32]0))
How can I pass a reference type to the invoked method so that $test is populated with the details for Display Device 0?
I have tried all sorts of different ways can cannot get $test set as needed.
(Watch out for line wrapping in the code)
Thanks
####Code####
[email protected]"
using System;
using System.Runtime.InteropServices;
using System.Threading;
namespace My5
// Remove the next flags line and the flags will be returned as integers
[Flags()]
public enum DisplayDeviceStateFlags : int
/// <summary>The device is part of the desktop.</summary>
AttachedToDesktop = 0x1,
MultiDriver = 0x2,
PrimaryDevice = 0x4,
/// <summary>Represents a pseudo device used to mirror application drawing for remoting or other purposes.</summary>
MirroringDriver = 0x8,
/// <summary>The device is VGA compatible.</summary>
VGACompatible = 0x16,
/// <summary>The device is removable; it cannot be the primary display.</summary>
Removable = 0x20,
/// <summary>The device has more display modes than its output devices support.</summary>
ModesPruned = 0x8000000,
Remote = 0x4000000,
Disconnect = 0x2000000
[StructLayout(LayoutKind.Sequential, CharSet=CharSet.Ansi)]
public struct DISPLAY_DEVICE
[MarshalAs(UnmanagedType.U4)]
public int cb;
[MarshalAs(UnmanagedType.ByValTStr, SizeConst=32)]
public string DeviceName;
[MarshalAs(UnmanagedType.ByValTStr, SizeConst=128)]
public string DeviceString;
public DisplayDeviceStateFlags StateFlags;
public string DeviceID;
public string DeviceKey;
add-type -typedefinition $source
$test=new-object my5.display_device
$test.cb=[system.runtime.interopservices.marshal]::sizeof($test)
#The following line errors
[my5.stuff]::EnumDisplayDevices($null,1,$test,0)
#Argument: '3' should be a System.Management.Automation.PSReference. Use [ref].
#The following line returns False and $test is not set to anything - this is due to the $null being cast as ""
$obj=(new-object -typename "my5.stuff")
#The following method was suggested to get round the 'null' issue
#but, while it returns True, $test is not set.
#Presumably this is because [my5.DISPLAY_DEVICE]$test is not a reference
$obj.gettype().getmethod("EnumDisplayDevices").getparameters()
#ParameterType : System.String
#Name : lpDevice
#DefaultValue :
#RawDefaultValue :
#Position : 0
#Attributes : None
#Member : Boolean EnumDisplayDevices(System.String, UInt32, My5.DISPLAY_DEVICE ByRef, UInt32)
#IsIn : False
#IsOut : False
#IsLcid : False
#IsRetval : False
#IsOptional : False
#MetadataToken : 134217729
#ParameterType : System.UInt32
#Name : iDevNum
#DefaultValue :
#RawDefaultValue :
#Position : 1
#Attributes : None
#IsIn : False
#IsOut : False
#IsLcid : False
#IsRetval : False
#IsOptional : False
#MetadataToken : 134217730
#ParameterType : My5.DISPLAY_DEVICE&
#Name : lpDisplayDevice
#DefaultValue :
#RawDefaultValue :
#Position : 2
#Attributes : None
#IsIn : False
#IsOut : False
#IsLcid : False
#IsRetval : False
#IsOptional : False
#MetadataToken : 134217731
#Name : dwFlags
#DefaultValue :
#RawDefaultValue :
#Position : 3
#Attributes : None
#IsIn : False
#IsOut : False
#IsLcid : False
#IsRetval : False
#IsOptional : False
#MetadataToken : 134217732
Thanks
####Code####
[email protected]"
using System;
namespace My5
[Flags()]
MultiDriver = 0x2,
Removable = 0x20,
Remote = 0x4000000,
public int cb;
#Name : lpDevice
#DefaultValue :
#RawDefaultValue :
#Position : 0
#Attributes : None
#IsIn : False
#IsOut : False
#IsLcid : False
#IsRetval : False
#IsOptional : False
#Name : iDevNum
#DefaultValue :
#RawDefaultValue :
#Position : 1
#Attributes : None
#IsIn : False
#IsOut : False
#IsLcid : False
#IsRetval : False
#IsOptional : False
#DefaultValue :
#RawDefaultValue :
#Position : 2
#Attributes : None
#IsIn : False
#IsOut : False
#IsLcid : False
#IsRetval : False
#IsOptional : False
#Name : dwFlags
#DefaultValue :
#RawDefaultValue :
#Position : 3
#Attributes : None
#IsIn : False
#IsOut : False
#IsLcid : False
#IsRetval : False
#IsOptional : False
