Password Reset disk
M
Mazen
hi all
just i want to know about some thing in create password reset disk . this
step is great but my comment is let say you create your password reset on a
USB Flash Memory is protacted by password .
and unfortunaltly i need to use this usb flash to reset my password, because
i forget my account password . so when i press reset password in logon screen
and you pluged your use so i don't think so you will be able to get the
password from protacted use falsh memory.
thanks
N
nemo wang
How to reset windows password
With vista the only thing you can do is a clean install using the disc that came with it.
You meas you forgot your PC password? Windows administrator password?
If it is your own computer, I recommend you to reset Windows Password using Windows Password Unlocker.
1 . Download it from?Windows Password Unlocker Official site,?and burn the Iso image file onto CD and reset the unknown password with the newly created CD.
2 . Then, Insert the newly created CD into the locked computer and re-boot it from the CD drive.
3 . After launched the CD, a window pop up with all your account names(if you have several accounts) select one of the accounts that you have forgotten its password to reset it. Just one press, this software can remove screen password instantly.
Maze wrote:
Password Reset disk
24-Jan-07
hi all
thanks
Previous Posts In This Thread:
On Wednesday, January 24, 2007 11:37 AM
Maze wrote:
Password Reset disk
hi all
thanks
Submitted via EggHeadCafe - Software Developer Portal of Choice
Entity Framework 4.0 POCO-First development and POCO Template
http://www.eggheadcafe.com/tutorials/aspnet/488279c4-214b-47ef-b152-955f3795ee13/entity-framework-40-poco.aspx
