Solved PC Angel - restoring without restore CD?
My wife's Emachine PC (produced just prior to Gateway's takeover of Emachines) originally came with Vista Home Premium on it.
Because of some classes that she was taking, it was an absolute MUST that she had XP on it (she wouldn't even consider a virtual machine - go figure?).
So, we removed Vista and installed XP.
Now that the class is done, her XP load is going screwy because of all kinds of garbage that my step-son did on it via various less-than-savory websites, and she wants Vista back.
Between then and now we moved and we haven't the first clue where any of the restore CDs or DVDs are - BUT - there is a partition on the hard drive that was created by PC Angel.
Is there any way that we can get the data from that partition back into place on the C drive and have a usable, bootable OS without having to jump through hoops or shelling out money for a new restore CD/DVD ?
It would appear by the folder structures there and everything that I've seen in them that it's a full blown setup of Vista Home Premium.
Any help is appreciated!
    AMD Athlon 64x2 3800+ (Socket 939)
    MSI K8N SLI
    2GB Corsair DDR in dual channel mode
    2x BFG Geforce 7600GT in SLI mode
    Soundblaster Audigy 2
    Big ol' 21 inch Gateway LCD monitor
    160GB SATA1 (Western Digital)
    500GB USB External (Western Digital)
    600 Watt BFG
    Logitech G7
    Logitech G15
Joan Archer
Cross Stitch Queen
uk uk_wales
Have you been to the web site of the makers to see if they have any manuals for the model of machine you have, perhaps it may give you a clue on how to recover the machine to factory settings.
    Zoostorm
    Intel Core 2 Duo E4600 @ 2400 MHz
    Foxconn 45CMX/45GMX/45CMX-K
    2048 MB (2 x 1024 DDR2-SDRAM)
    Intel Corp 82945G Integrated Graphics Controller
    Onboard Realtek
    Hanns.G HH221 22" inches Widescreen
    ExcelStor (250GB)
    Microsoft Optical Wheel Mouse
    Microsoft Natural Ergonomic Keyboard 4000
    Just under 4 MB ADSL Broadband
    Epson Stylus SX415 All-in-one Printer
    Seagate 500 MB Expansion USB Desktop Hard Drive
Yes, and unfortunately all they mention is using the restore CD...
There's got to be another way! (fingers crossed!)
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
Bare Foot Kid
R.I.P. August 13th 2014
usa us_south_carolina
Hello JWhipple!
When you click "Computer" in the start menu do you see a drive listed as "D: Recovery"
or "Factory Image D:" ?
Keep us informed!
Later :shock: Ted
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
I'll check that first thing when I get home. I just RDPed into my machine at home but because of the issues we're having with her box, I am able to ping it but not connect via daisy-chained RDP...
Can't map a drive either - says there aren't enough resources :-(
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
Partition is labeled as "Recovery" and is a 9.64GB partition.
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
z3r010
Staff member
england uk_lancashire
What model Emachine?
Do you have the option to press F11 as the manchine starts to start the recovery?
  • Show second system?
    Yes
    Operating System
    Windows 10
    me
    Asus RAMPAGE V EXTREME
    Creative
    6 @ 2560x1440
    3x 1TB Samsung Evo 840's
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic
    350 Mb/s
    WinTV NovaTD
    HP CP1515n Color Laser
    Microsoft LifeCam Cinema
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    Intel HD Graphics 4400
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
#8
It's a T5086 ... I'll check the F11 options when it gets done doing a hard drive error scan.
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
z3r010
Staff member
#9
Just looked it up and your system does seem to have the F11 option (if it works is a different matter)
Info here:- http://support.gateway.com/s/Manuals/Desktops/8510406.pdf
To restore system software from the hard drive backup copy:​
1​
Restart the computer, then press F11 when prompted to start the
restore process. The System Recovery program starts. You have
three seconds to press
F11 before Windows starts.
2​
Click a system restore option. For more information, see
“Restoration options” on page 5.
Non-Destructive System Restore (Recommended)
Full System Restore (Destructive)
Full System Restore (with Backup) (Advanced Option)
3​
Follow the on-screen instructions to complete the system
software restoration process.
    Yes
    Operating System
    Windows 10
    me
    Creative
    6 @ 2560x1440
    Enermax Liqtech 240
    Surface Ergonomic
    350 Mb/s
    WinTV NovaTD
    APC 750i Smart UPS
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
#10
Well damn, why couldn't it be that easy on all machines? LOL
Thanks!
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
Bare Foot Kid
#11
Thanks!
Hello, JWhipple!
Very glad to see you found a solution!
Later :) Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
#12
ok I was too quick to jump for joy...
I actually got around to going to do the restore to this machine and sure enough, nothing happens when I press F11 at boot-up.
I think the F11 portion went away when I blew away the Vista OS and went back to XP.
Unless anyone else has any ideas, I'm sunk - having to reload Vista by hand - not that it's that great of a chore, just not something I was looking forward to.
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
Brink
Staff member
mvp
usa us_oklahoma
#13
Hi JWhipple,
As soon as you restart the computer, start tapping the F11 key every second to see if you enter the Recovery window. You only have 3 seconds to press it at boot, so it's real easy to not time it right and miss pressing it within that tiny time frame.
    Yes
    Operating System
    ASUS Maximus X Code Z370
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    6TB WD Black WD6001FZWX
    Corsair Air 740
    Logitech MX Master
    Creative F200 webcam,
    Linksys EA9500 router,
    Arris SB6190 cable modem,
    APC SMART-UPS RT 1000 XL,
    Lumia 1520 phone
Shawn,
Just tried tapping F11 at least twice every second - it does nothing but boot into XP.
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
#15
Shawn,
Maybe you need to press an F lock if you multimedia keyboard
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP
    500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner,
    15 in 1 card reader
    Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
#16
No F Lock on this keyboard. F2 for Setup Menu, F10 for Boot menu and F8 for WinXP startup options all work fine.
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
#17
So it looks like you destroyed your hidden recovery by installing XP. Only option is to do clean installation of Vista.
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    5.1 surround sound
    15 in 1 card reader
Brink
Staff member
mvp
usa us_oklahoma
#18
I agree with ACDCFan. It looks like you may have deleted the Recovery Partition somewhere inbetween deleting Vista and installing XP. :(
You will need to use your installation DVD from now on instead.
Sorry,
    Yes
    Operating System
    Integrated
    3 x 27" Asus VE278Q
    1920x1080
    256GB OCZ Vector,
    Corsair Air 740
    Logitech MX Master
    Lumia 1520 phone
Even bigger problem now...
Since the serial number that I have for that machine is OEM but the media was not for the OEM version, it's not allowing me to activate.
LOVELY.
Think calling M$ is going to prove to be a waste of time?
    MSI K8N SLI
    600 Watt BFG
    Logitech G7
    Logitech G15
SIW2
MS seem to have handed all o/s support to the OEM manufacturer.
You would need to contact Emachines ( Think it's owned by Acer now instead of Gateway - anyway seems to be operating as a separate brand )
eMachines Support Home
They will probably send you some kind of disc - HP do this free, so I guess Emachines will
Good luck
SIW2
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
