Pc doesn't recognize flash drive
patch41
Vista Pro
328
Hi Folks, I plug in my flash drive and it doesn't register, i look in device manager and i see the yellow triangle next to the flash-drive device, i right click to update the device,it tells me the device driver is up to date, i click on to property's and it say's this device cannot start, code10, any advise would be appreciated,thanks.
ilikefree
2,877
Location
New Zealand
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    1x 180GB Intel 530 series SSD
    1 x 120GB Hitachi 5400rmp
    Medium for New Zealand
    Only ever used a laptop.
    Also use USB Freeview TV Card
    Lenovo Docking Station
    External Speakers
    Other bits a pieces as needed
patch41
Vista Pro
328
Thanks for your response ilikefree,tried your suggestion but it did'nt work found the solution in one of the other forums,apparently if you use up all the assigned letters the pc doesn't know what to assign it to,i am enclosing attachment which explains it better than i can, thanks again.patch41
v877051
Power User
79
Location
Fort Wayne, IN
Very cool, thanks for putting in some follow-up, especially with this great solution!
    Dell
    Intel Core i7 820QM 1.73GHz "Clarksfield" (8 Threads)
    Dell Inc. 0874P6 (U2E1)
    4.0GB Dual-Channel DDR3 @ 661MHz (9-9-9-24)
    ATI Mobility Radeon HD 5400 Series
    (SoundMAX) IDT High Definition Audio
    15"+ Standard Dell Studio 1558 LCD monitor.
    1024 x 768
    (x2) 1TB WD "Elements" External HDD + (x1) 1.5TB WD "Elements) External HDD; 500GB Solid State Storage on laptop.
    N/A Notebook
    N/A
    External (NON-USB!) NZXT CRYO-S (X) Silver. ICE COLD.
    Good 'ol reliable USB 2.0 Microsoft 3-button mouse.
    Standard, non-10-key, no fancy backlighting.
    16 Mbps w/ Aaris DOCSIS 3.0-compliant modem
    Gigabit LAN. Tight network security. (Hopes of getting a Linksys 4-Port Gigabit Security Router with VPN!) Disabled WiFi/Wireless hardware; don't believe in the concept. If I did, would use draft-N adapter.
ilikefree
2,877
Location
New Zealand
Thanks didn't know that. You must have a lot of stuff attached to your computer
    LENOVO 64734VM
    15 inch
    External Speakers
patch41
Vista Pro
328
No, but at one time i did download virtual drive's, where i mounted, lets say tuturial dvd's where i didn't have to keep inserting the dvd's to play them, since then i have removed the virtual drive's but apparently in the pc's memory the letters are still active till you reassign the letters, patch41
Shadowjk
Network Enthusiast
2,180
Location
Northamptonshire, England
In device manager uninstall the driver(s) to do with that flash drive also can i ask do oyu ever get BSOD?
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
patch41
Vista Pro
328
#8
I tried uninstalling drivers for the flash-drive but did not work, The problem was all the letters where used up and the computer didn't know where to assign it, as for bsod,blue screen of death, have not had that problem yet and hope i never have to deal with it
Shadowjk
Network Enthusiast
2,180
Location
#9
What are the drives taking up those letters are you able to remove them?
    AMD HD Radeon 6870
    Novatech Night
v877051
Power User
79
Location
Fort Wayne, IN
#10
At Start,right-click on Computer; choose Disk Management. Within thr MSC snap-in, you can re-assign drive paths & letters; from experience, don't fuss with C:\ or D:\
You can re-arrange virtual drives, too; PowerISO is a GREAT way to quickly re-enable since lost ones!
    Dell
    1024 x 768
    N/A Notebook
    N/A
99
#11
i seen a few play up when first used, uac and security apps prevent the usb stick installing the vendors drivers and backup app etc. when they are removed on a xp box and the stick formated to fat32 or ntfs they run fine.
    home brews
    pc1 msi k7delta, pc2 asus kn79txd evo
    pc1 2gb crucial, pc2 4gb gskill ripjaws
    pc1 bfg 7800gs, pc2 shapphire 5770 vapor-x
    onboard
    corsair hx
    jeantech phong
    pc1, handmade waterblocks,passive cooling, pc2 corsair h50
    logictech mx510s wired
v877051
Power User
79
Location
Fort Wayne, IN
#12
UAC shouldn't be negotiable and seen as a dredge or anti-compatibility issue. It's a bar-none proven frontline defense which if disabled renders your Vista OS no better off than a vulnerable antiquated XP Pro disaster which isnt even capable of using 3+GB of RAM, unless you really go 64 bit and good luck watching WindowsUpdate have the propensity intermittently knock core system drivers. UAC doesn't conflict with any sort of like-intended security measure whether it be an A/V module or a scan-as-needed freeware A/M utility. Furthermore, anyone who gets up early enough in the morning knows that it's no BIOS-flashing type risk to simply censor mindless wizards which we are made to think are proprietary; is navigating to an appropriate INF or SYS or whatever file via Device Manger manually which is in itself failsafe assuming you selected the correct driver for the given piece of hardware in the first place. Just curious but what does your title or whatever mean in terms of your credentials or authority?
    Dell
    1024 x 768
    N/A Notebook
    N/A
