PDF to PNG conversion
J
Johnny B. Safe
Hi I have a PDF File that I need converting to PNG. As this is a one off I
dont want to buy a program to do this.
Does anyone know of a free way to do this? The only ones I have tried are
trial ones and as you know they put righting across so you have to buy there
product.
Thank you for any responce
J
John Inzer
> off I dont want to buy a program to do this.
> are trial ones and as you know they put righting across so you have
> to buy there product.
Maybe a screen shot would be worth a try.
If you are running any version of Vista other
than Basic you have the Snipping Tool.
Windows Vista -
Activate Vista's Snipping Tool
http://www.pcworld.com/article/137099/activate_vistas_snipping_tool.html
Use Snipping Tool to capture screen shots
http://windows.microsoft.com/en-us/windows-vista/Use-Snipping-Tool-to-capture-screen-shots
Vista Tutorial - How to use the Snipping Tool in Vista
http://www.vistax64.com/tutorials/148532-how-use-snipping-tool-vista.html
but the required software may not run on Vista:
Converting PDF Files So that they can be imported into Publisher
http://ed.mvps.org/Static.aspx?=Publisher/convertpdf
J. Inzer MS-MVP
Digital Media Experience
Notice
This is not tech support
I am a volunteer
Solutions that work for
me may not work for you
Proceed at your own risk
whs
2,026
Location
Germany/Florida
Since .png is a picture filetype, it has to fit into a picture frame. The suggested snip/sceenshot is the only option I see.
    Dell
    Q6600
    HP w2207h
    2x250GB HDDs
    1x60GB OCZ SSD
    6 external disks 60 to 640GBs
C
Carl-Aage Morgen
> product.
Zamzar is a free online file conversion utility - it can convert a
pdf-file to png.
http://www.zamzar.com/
best regards
Carl-Aage
