Pecursive Delete Implementation in PowerShell
S
S. A. Gnezdov
I want to replace VBScript with PowerShell implementation. Here is VBScript
content:
' Deletes all .svn folders recursively
' To delete all .svn directories in current directory recursively execute
command:
' cscript del-svn-recursively.vbs
Set FSO = CreateObject("Scripting.FileSystemObject")
ShowSubfolders FSO.GetFolder(".")
Sub ShowSubFolders(Folder)
For Each eachFolder in Folder.SubFolders
' FSO.DeleteFolder(eachFolder)
if eachFolder.Name = ".svn" then
WScript.Echo eachFolder.Path
FSO.DeleteFolder eachFolder.Path, True
else
ShowSubFolders eachFolder
end if
Next
End Sub
R
RichS
You could try something like this
$fso = New-Object -com "Scripting.FileSystemObject"
$folder = $fso.GetFolder("C:\Test\")
foreach ($subfolder in $folder.SubFolders)
If ($subfolder.Name -like "*.svn")
remove-item $subfolder.Path -Verbose
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
Blog: http://richardsiddaway.spaces.live.com/
PowerShell User Group: http://www.get-psuguk.org.uk
> content:
> command:
> else
> end if
> Next
> End Sub
B
Brandon Shell
May I recommend the -whatif the first go :)
"RichS" <RichS@discussions.microsoft.com> wrote in message
news:C976E20F-9066-445F-AECB-2504B414C479@microsoft.com...
> Richard Siddaway
>> VBScript
>> content:
>> command:
>> else
>> end if
>> Next
>> End Sub
S
Shay Levi
First try with -whatIf to find what folders will be deleted
dir <path> -recurse | where {$_.PSIsContainer -and $_.Extension -eq ".svn"}
| remove-item -force -whatIf
Then remove -whatIf and run again
Shay
http://scriptolog.blogspot.com
>> $fso = New-Object -com "Scripting.FileSystemObject" $folder =
>> Richard Siddaway
>> warranty
>>> VBScript
>>> content:
>>> execute
>>> command:
>>> Set FSO = CreateObject("Scripting.FileSystemObject") ShowSubfolders
>>> FSO.GetFolder(".")
>>> else
>>> end if
>>> Next
>>> End Sub
K
Kiron
If speed matters, filter '.svn' through Get-ChildItem's -filter parameter,
also use this Cmdlet's -force parameter if you want to retrieve hidden
'.svn' folders:
gci $folder -fil '*.svn' -r -fo | ? {$_.psIsContainer} | ri -fo
Kiron
R
RichS
Aliases can be great for interactive work but they can intimidate people
trying to learn PowerShell as they make it more difficult to understand
Richard Siddaway
"lrbell" wrote:
> Kiron, your use of alias' is sweet. Rock on.
> I love how PS uses 3/4 of a line to do what used to take 15-20.
> lrbell
S
S. A. Gnezdov
#8
I don't think aliases should be used in posts unless those are standard
aliases.
news:E078C64B-C649-4921-9270-2AE32C61FC81@microsoft.com...
> Richard Siddaway
>> lrbell
K
Kiron
#9
You can find out more on aliases by typing:
help about_alias
PowerShell is indeed a great shell/language. One of its features is that all
Cmdlets' parameters can be named by their first characters --instead of the
full name-- as long as they disambiguate, or clearly identify, the parameter
with the least amount of characters.
There are also aliases for half of the ubiquitous parameters, better known
as 'common' parameters.
Ubiquitous parameter, Alias
Confirm
Debug
ErrorAction, ea
ErrorVariable, ev
OutBuffer, ob
OutVariable, ov
Verbose
WhatIf
This function will get a sorted list of the regular and common parameters of
a standard Cmdlet. With this list you can see which parameters can be named
with just their first character, or if you need to type its second and third
to clearly identify them. There is at least one other alias I'm aware of,
for New-Item's -itemType regular parameter you can use -type; there may be
more.
function Get-ParameterList
([string]$cmdlet = $(throw "Specify a PowerShell Cmdlet"))
if (@(powershell -noProfile {get-command -type Cmdlet | %
{$_.Name}}) -contains $cmdlet)
((get-command $cmdlet).definition).split() -match '\[-[a-z]+' -replace
'\[*-|\]' | sort -unique
else {"$cmdlet is not a standard Cmdlet"}
set-alias gpl Get-ParameterList
# list all parameters, regular and common
# note the use of the just created alias
gpl Get-ChildItem
Debug
ErrorAction
ErrorVariable
Exclude
Filter
Force
Include
LiteralPath
Name
OutBuffer
OutVariable
Path
Recurse
Verbose
According to the this list, and the implementation of common parameters'
aliases, for Get-ChildItem you can use:
-Debug or -d
-ErrorAction or -ea
-ErrorVariable or -ev
-Exclude or -ex
-Filter or -fi
-Force or -fo
-Include or -i
-LiteralPath or -l
-Name or -n
-OutBuffer or -ob
-OutVariable or -ov
-Path or -p
-Recurse or -r
-Verbose or -v
Kiron
K
Kiron
#10
I agree that using aliases can intimidate some people learning PowerShell,
but others will find them very useful. My suggestion was the fourth in the
series, did explicitly referred to the Get-ChilItem Cmdlet and its
parameters and was a modification of previous replies. I used aliases and
parameter disambiguation in the example because the Cmdlets and parameters
were mentioned before in the series and in my post --except for
Remove-Item-- :)
I suggest that aliases can be used if our reply doesn't add new Cmdlets to
previous replies or refers to the Cmdlet by name, same would apply to
parameter disambiguation.
What do you think?
Kiron
K
Kiron
#11
The 'speed' part of my suggestion doesn't have to do with less typing, is
just that by filtering through Get-ChildItem's -filter less objects are
passed down the pipeline to Where-Object, therefore, enhancing performance
The aliases used in my suggestion are standard, and the brief name for the
parameters is a PowerShell feature sometimes referred as "parameter
disambiguation", that later you might find very useful. See my reply to
lrbell for more on that. Besides you can always ask for clarification, lots
of smart --myself NOT included-- and helpful people here that can help out.
Kiron
S
Shay Levi
#12
I wrote a function that calculates the minimum paramater length you can type
something like:
PS C:\Scripts>get-params select-string
- Select-String -
name alias position
caseSensitive -c named
exclude -e named
include -inc named
inputObject -inp named
list -l named
path -path 2
pattern -patt 1
quiet -q named
simpleMatch -s named
text -t 2
You can find it here:
http://scriptolog.blogspot.com/2007/07/what-dat-parameter.html
Shay
> help about_alias
> that all Cmdlets' parameters can be named by their first characters
> --instead of the full name-- as long as they disambiguate, or clearly
> identify, the parameter with the least amount of characters.
> known as 'common' parameters.
> Confirm
> Debug
> ErrorAction, ea
> ErrorVariable, ev
> OutBuffer, ob
> OutVariable, ov
> Verbose
> WhatIf
> parameters of a standard Cmdlet. With this list you can see which
> parameters can be named with just their first character, or if you
> need to type its second and third to clearly identify them. There is
> at least one other alias I'm aware of, for New-Item's -itemType
> regular parameter you can use -type; there may be more.
> -replace
> gpl Get-ChildItem
> Debug
> ErrorAction
> ErrorVariable
> Exclude
> Filter
> Force
> Include
> LiteralPath
> Name
> OutBuffer
> OutVariable
> Path
> Recurse
> Verbose
> parameters'
> -Debug or -d
> -ErrorAction or -ea
> -Exclude or -ex
> -Filter or -fi
> -Force or -fo
> -Include or -i
> -LiteralPath or -l
> -Name or -n
> -OutBuffer or -ob
> -OutVariable or -ov
> -Path or -p
> -Recurse or -r
> -Verbose or -v
> Kiron
K
Kiron
#13
Thanks Shay, the parameter 'short' name generator is great.
Get-Help is a good source of information on each parameter, be aware that
some commonly used Cmdlets' help contents are missing parameters.
This script gets Set-Content's, Add-Content's and Get-Content's parameters
found through Get-Command and Get-Help, then compares the lists to see which
parameters, if any, are missing from either list:
I commented other $cmdlets assignments in case anyone is interested in
looking at other parameter discrepancies or comparing all standard Cmdlets.
<Get-MissingParameters.ps1>
$ubiq = 'Debug|ErrorAction|ErrorVariable|OutBuffer|OutVariable|Verbose'
# parameters missing in Get-Help
$cmdlets = 'Set-Content', 'Add-Content', 'Get-Content'
# parameters missing in Get-Command's Definition
# $cmdlets = 'Set-TraceSource', 'Trace-Command'
# parameters listed in Get-Help but are not functional
# $cmdlets = 'Get-ChildItem', 'Select-String'
# compare all standard Cmdlets
# $cmdlets = (powershell -noProfile {get-command -type Cmdlet | %
{$_.Name}})
foreach ($cmdlet in $cmdlets)
$thruGetCommand = ((gcm $cmdlet).definition).split() -match
'\[-[a-z]+|^\-[a-z]+' -replace '\[*-|\]' -notMatch $ubiq | sort -unique
$thruGetHelp = get-help $cmdlet -parameter * 2>$null| % {$_.name} | sort
if ($thruGetHelp -ne $null)
if ($thruGetCommand.length -ne $thruGetHelp.length)
"Differences found in $cmdlet's parameters:"
compare-object $thruGetCommand $thruGetHelp | ft -hide -auto
PowerShell's scalar/array treatment --as in your CSV post-- seems to be the
reason why your function doesn't support Cmdlets that have one or zero
regular parameter, but all support common parameters. Get-Command's
Definition property will list all functional parameters, except
the -Debugger for Set-TraceSource and Trace-Command.
Thanks also for updating the common parameters' aliases.
Debug, db
Verbose, vb
Kiron
S
Shay Levi
#14
Thanks, kiron. Cool stuff! Cheers all PowerShell enthusiasts.
Shay
> that
> parameters
> which
> Cmdlets.
> $ubiq =
> # parameters listed in Get-Help but are not functional # $cmdlets =
> {$_.Name}})
> -unique
> sort
> be the reason why your function doesn't support Cmdlets that have one
> or zero regular parameter, but all support common parameters.
> Get-Command's Definition property will list all functional parameters,
> except the -Debugger for Set-TraceSource and Trace-Command.
> Debug, db
> Verbose, vb
> Kiron
