Permanent Problems with Vista - can't reinstall
Antonius
11
I am VERY disappointed with VISTA :sa:
I have had Windows Vista 64 for 2 Months now and of that period of time it worked soundly for about 2 Weeks.
I am NOT an irresponsible User, I don't just delete Data, I know a little something about computing, I don't visit or download from dubious sites etc.
Nevertheless, Vista has been causing problem after Problem since I have it
1) Without any reason software suddently doesn't work.
a) I installed a Antivirussoftware - after 3 Weeks it suddently didn't work any more (Kaspersky) I couldn't reinstall it.
b) I installed a new Antivirussoftware - after 5 days it didn't work anymore.
c) 4 days later I started to get errormessages "Windows Defender doesn't work any more" - "Windows Hostprocess doesn't work anymore"
furthermore:
The Internet Explorer doesn't work anymore, I have no idea why (I usually use Firefox)
Windows Media player doesn't work anymore
2) Everytime I check the C: drive for errors it tells me there are errors, same thing when I do the sfc_scannow test.
3) I can't reinstall Vista, when I do it tells me there has been an Error 0x80070241
I think I need to completely reboot and reinstall everything
PLEASE HELP! :cry:
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
skunksmash
im coming for cake
2,254
Location
norfolk
Hi Antonius....;)
have you tried rolling back the machine..?? System Restore
please fill out your system specs at the bottom of your post, or via the ''userCP''
:)SK
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
Antonius
11
Hi skunksmash thanks for the reply.
tried it, all the problems remain.
My System:
CPU: 2,83 GHZ Quad Core
8 GB RAM
Vista 64 bit Home Premium
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
SIW2
2,741
Hi Atonius.
If you got this error code while trying to install from the dvd :
It may indicate a problem finding install.wim and copying the setup files.
You may have better luck with a different (external) dvd player, or a borrowed x64 installation dvd - using your own product key, of course.
Hope it helps
    Intel E8400
    ASRock1333-GLAN R2.0
    2gb DDR2 800
    nvidia 9500GT 1gb
Antonius
11
1) noone around me has vista 64 and they all laugh at me for buying it (XP wouldn't work because of the RAM) so where can I get a DVD?
2) why is there suddently something wrong with the DVD? it worked the first time?
3) can't I just delete the whole thing via bios? how would that work?
4) what is wrong anyway? why is this happening with Vista? If I reinstall everything, will it do the same thing again?
5) could it be hardware related?
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
H2SO4
A bit of a numpty
1,241
Location
Australia
ok great so no one has any Idea what is going on with my vista?
I'd suggest picking a specific problem and then providing additional detail around it. For example, the "host process" error (that may potentially be more serious than your other issues):
- What is the exact error message, down to the numbers?
- Can you reproduce it somehow or is it intermittent?
- If you can repro, does it also happen when you test in safe mode?
There's a natural human tendency to assume that all problems are interlinked, but that's not always the case. Try break things up into bite-sized chunks.
Antonius
11
thank you for your answer!
Specific Problem Nr. 1
Every time I start my computer (also in safe mode) I get an error message:
(translated) Windows defender doesn't work any more. A solution is being searched for.
I have been getting that for the last weeks, since both my antivirusprograms stopped working.
these are the details:
Problemsignature
Problemname: BEX64
Applicationname: svchost.exe_WinDefend
Applicationnversion: 6.0.6001.18000
Applicationntimestamp (?) 47919291
Errormodule name: StackHash_65c9
Errormodule version: 0.0.0.0
Errormodule time stamp: 00000000
exeptionoffset: 00000000007806d0
exeptioncode: c0000005
exeptionaten: 0000000000000008
Operating system version: 6.0.6001.2.1.0.768.3
Area-ID: 3079
additional info 1: 65c9
additional info 2: 05711230d99ac11ec7dfaa2f56f6510a
additional info 3: c857
additional info 4: 28080fbe4950dcac4c5e86cb0ae5ba6d
(translated)
I cannot download the software and reinstall it, every time I try it tells me "this update is not for your system"
Specific Problem Nr. 2
IE and WMPlayer don't work any more, without any reason why.
they just don't start.
additional info for the IE issue:
Problemsignatur
Problemereignisame: APPCRASH
Applicationname: Explorer.EXE
Applicationnversion: 6.0.6001.18164
Applicationntimestamp (?) 4907e791
Errormodule name: msvcrt.dll
Errormodule version: 7.0.6001.18000
Errormodule time stamp: 4791ad6b
exeptionoffset: 0000000000001753
Area-ID: 3079 3079
additional info 1: ae66
additional info 2: a5c9bb9cb7dd1bc15fcdc78f8fb20bdf
additional info 3: 0775
additional info 4: 1494b369bdfeb069a3e9393ccb29fce3
(translated)
Specific Problem Nr. 3
Windows does NOT let me repair itself.
When I insert the disc to reinstall windows it tells me this errormessage:
Specific Problem Nr. 4
Every time I start my computer (also in safe mode), after I get the windows defender error message I get following Errormessage
"Windows Host-Process doesn't work any more. A solution is being looked for"
there is no additional info.
Lets deal with that for starters.
I am VERY grateful for any help
thank you guys in advance
    2,83 GHZ QUAD CORE
    ASUS P5Q
    8GB RAM
