Picture icons don't show preview of picture
  • Thread starter =?Utf-8?B?Q2F0aGVyaW5l?=
  • Start date
In my picture folders, all the pictures display with the same default icon (a
picture of a lake with mountain and blue sky) instead of a preview of my
pictures.
I wonder if it is a video card driver problem. I recently upgraded to the
NVIDIA GeForce Go 6200 TE 64M / 6600 TE 128M (Microsoft Corporation - WDDM)
and this seems to have happened since then. However Aeroglass seems to work
fine and the performance analyzer reports that everything is above 3.
Could the picture preview problem simply be a setting I have not turned on
somewhere?
Thanks,
Catherine
=?Utf-8?B?WkFa?=
Catherine,
Open up the Pictures folder from Start menu. On the blue task bar of the
window, click on Organize. Click on folder options. Then, click on the View
tab. Uncheck the checkbox that says "Always show icons, never thumbnails."
That should do the trick.
> pictures.
> somewhere?
> Thanks,
> Catherine
That fixed it! Thank you very much for the quick (and effective) reply :-)
Catherine
"ZAZ" wrote:
> Catherine,
> > pictures.
> > somewhere?
> > Thanks,
> > Catherine
=?Utf-8?B?WkFa?=
You're welcome. Have fun with Vista:-)
> Catherine
> "ZAZ" wrote:
> > Catherine,
> > > pictures.
> > > somewhere?
> > > Thanks,
> > > Catherine
surfsunsummer
I have tryed what you suggested but i could not find options under organize. When i open up my pictures folder and there are all my pictures all it shows is the grass and hills sceen. I would like to be able to see my pictures before opening them.
thankss for the consideration
SevenHeant
instead of clicking "organize," click "tools" (on the bar with, file, edit, view, "tools" and help). click folder options, then the view tab. uncheck the checkbox that says "always show icons, never thumbnails."
yeah, it's pretty much what Cat said, just a different approach.
