Please do not Power off or unplug your machine
It is second time in this month.
When I tried reload the windows, It would not start and only show:
Installing Update 3 of 5
(Or Installing 5 of 5)
It will last forever,
The only way is turn off and unplug the machine to let it start windows.
I do not know if it is really update windows vista, CA antivirus or some
other program.
I do not know other person have some experience
Thanks
G
Gene E. Bloch
> other program.
> Thanks
Everyone with Vista or XP has experienced this when they have updated. It
can take a long time. You have to wait long enough. Turning it off manually
may have caused damage.
Gene E. Bloch letters0x40blochg0x2Ecom
>> Please do not Power off or unplug your machine Installing Update 3 of 5
>> windows.
>> some other program.
>> Thanks
> It can take a long time. You have to wait long enough. Turning it off
> manually may have caused damage.
How would you tell ;)
If waiting even one hour or a little more, OK
But after several hours I thought it might in dead loop
then I decided menually turned off windows and even I had to unplug the
machine.
After power on the window restarted and I did not find any other thing
wrong.
"Gene E. Bloch" <not-me@newsgroup> wrote in message
news:r910itboi5i2.1l629nd0dron7.dlg@newsgroup
>> other program.
>> Thanks
> manually
lemur
1,533
Location
University of Kentucky
    AMD AM2 6000+
    Nvidia M2N-E SLI
    GeForce 7600GT
    WD
    Cooler Master
    Three fans
    Dell Optical
    Dell Quietkey
    10 MBPS
G
Gene E. Bloch
OK, several hours is definitely bad, and I would've done the same as you
did. There's really no other choice at that point. And I would have scanned
for damage afterwards (chkdsk and fsk, for example).
I'm glad it came out OK. Scary... (or should I say :scary:?)
> machine.
> wrong.
>>> other program.
>>> Thanks
>> manually
I experienced another two, Both keep me waiting about 10 hours.
Then I checked windows update history and just told me it was update
security update for VS and end up with "failed".
Then I downloaded this upate and run it under winows, only took some
minites and end up with success
>> other program.
>> Thanks
> manually
