Please help me on mail
10
i have a yahoo and a live email i am tryn my hardest to set them up on windows mail. my live i COULD receive but NOW IT WILL DO EITHER but my yahoo will not either THese are THE ERROR MESSAGE
The message could not be sent. The authentication setting might not be correct for your outgoing e-mail [SMTP] server. For help solving this problem, go to Help, search for "Troubleshoot Windows Mail", and read the "I'm having problems sending e-mail" section. If you need help determining the proper server settings, please contact your e-mail service provider.
The rejected e-mail address was 'badassme82@live.com'. Subject 'fgh', Account: 'pop3.live.com', Server: 'smtp.live.com', Protocol: SMTP, Server Response: '550 5.7.3 Requested action aborted; user not authenticated', Port: 25, Secure(SSL): Yes, Server Error: 550, Error Number: 0x800CCC78
The host 'pop.att.yahoo.com' could not be found. Please verify that you have entered the server name correctly.
Account: 'pop.att.yahoo.com', Server: 'pop.att.yahoo.com', Protocol: POP3, Port: 995, Secure(SSL): Yes, Socket Error: 11001, Error Number: 0x800CCC0D
The host 'smtp.live.com' could not be found. Please verify that you have entered the server name correctly.
Subject '', Account: 'pop3.live.com', Server: 'smtp.live.com', Protocol: SMTP, Port: 25, Secure(SSL): Yes, Socket Error: 11001, Error Number: 0x800CCC0D
The host 'pop3.live.com' could not be found. Please verify that you have entered the server name correctly.
Account: 'pop3.live.com', Server: 'pop3.live.com', Protocol: POP3, Port: 995, Secure(SSL): Yes, Socket Error: 11001, Error Number: 0x800CCC0D
please help me please i have worked all day for two days and cant get it to work.
CAN SOMEONE PLEASE HELP ME. I NOT COMPUTER SMART. NOW I CANT DO NOTHING
now that i have totally took out the yahoo one . this is wat my live says now on receiven
Account: 'pop3.live.com', Server: 'pop3.live.com', Protocol: POP3, Server Response: '-ERR command not implemented', Port: 995, Secure(SSL): Yes, Server Error: 0x800CCC90, Error Number: 0x800CCC18n
and sending is
An unknown error has occurred. Subject '', Account: 'pop3.live.com', Server: 'smtp.live.com', Protocol: SMTP, Server Response: '550 5.3.4 Requested action not taken; This account is currently blocked from sending messages. If you don't think you've violated the Windows Live Terms of Use, please contact customer support.', Port: 25, Secure(SSL): Yes, Server Error: 550, Error Number: 0x800CCC69
but here are my settings
on my live account i have it set up like this sever tab
incoming is pop3.live.com
outgoing is smtp.live.com
log on using secure is checked.
the out going autha. is checked.
advance tab
out going sever port number is 25
incoming port number is 995
i have the ssl checkd on both
on yahoo
sever tab
incoming is pop.att.yahoo.com
outgoing is smtp.att.yahoo.com
the out going auth. is checked
advance tab
out going sever port number is 495
ssl is checked on both.
YOU CAN ALSO REACH ME ON YAHOO BADASSME82 IS MY ID. THANKS
IF WE CAN DO REMOTE ASS. JUST PLEASE HELP ME
R
Ron Sommer
This is the Windows Live Mail newsgroup. Post here
news://msnews.microsoft.com/microsoft.public.windows.vista.mail
When you post, say what settings you are trying to use.
Yahoo has to be Plus account to do pop.
Secure(SSL): Yes means that you have checked 'Log on using secure password
authentication'. If you check anything, you should be checking 'My server
requires authentication.
Hotmail now has pop access. I don't know if that applies to a live.com
address.
Ronald Sommer
"badassme82" <guest@xxxxxx-email.com> wrote in message
news:238c04e482e2108f54107fc5f7a71662@xxxxxx-gateway.com...
> service provider.
> The rejected e-mail address was 'badassme82@xxxxxx'. Subject 'fgh',
> Number: 0x800CCC78
> 0x800CCC0D
> Number: 0x800CCC0D
> 0x800CCC0D
> it to work.
> NOTHING
> and sending is
> -on my live account i have it set up like this sever tab
> advance tab
> on yahoo
> sever tab
> advance tab
> ssl is checked on both.-
> THANKS
> badassme82
G
Gary VanderMolen
I responded to your identical posts in the Windows Mail newsgroup.
Gary VanderMolen, MS-MVP (Mail)
"badassme82" <guest@xxxxxx-email.com> wrote in message news:238c04e482e2108f54107fc5f7a71662@xxxxxx-gateway.com...
> service provider.
> Number: 0x800CCC78
> 0x800CCC0D
> Number: 0x800CCC0D
> 0x800CCC0D
> it to work.
> NOTHING
> and sending is
> advance tab
> on yahoo
> sever tab
> advance tab
> THANKS
> badassme82
W
...winston
