Plug a cable into network adaptor "Local Area Connection"??
khayes
2
Hi, i have a problem with my internet connection...
Basically i have been trying to connect to wireless internet my Mother-In-Laws house where i am currently staying, when it automatically connects it all looks fine until you try to access any website and the whole connection just goes down and i don't understand why?! When it goes off it will immediately try to re-connect, aquire ip address and then connect with and then disconnect again and just does this in circles.
In the diagnostics, if i try to repair, it says there might be a problem with one or more network adaptors on this computer and then tells me to plug a cable into the network adaptor "local area connection" I'm not exactly hot with computers and don't understand what this means at all lol :o
On the computer i am on now, which is the main one in the house, the connection
is fine and doesn't break up.
Someone please help cos i'm going insane :mad:
Thanks!!
S
sloan
You need to find a newsgroups with the name "windows" in it.
This is a DOTNET newsgroup, where developers (programmers) ask questions
about the DotNet framework.
"khayes" <guest@xxxxxx-email.com> wrote in message
news:f2d50d8fe9704d2e4eb2f13af9d90a2d@xxxxxx-gateway.com...
> circles.
> In the diagnostics, if i try to repair, it says -there might be a
> problem with one or more network adaptors on this computer- and then
> tells me to -plug a cable into the network adaptor "local area
> connection"- I'm not exactly hot with computers and don't understand
> connection
> Thanks!!
> khayes
E
eBob.com
You've indeed gone insane if you think that this newsgroup has anything to
do with your problem. Please find a newsgroup that contains maybe
"windows", or "wireless" or "networking" in its name.
Good Luck, Bob
> circles.
> connection
> Thanks!!
> khayes
P
PvdG42
> circles.
> connection
> Thanks!!
> khayes
To find an applicable discussion group for your question, do the following:
As you appear to be using a web interface, start here:
http://www.microsoft.com/communities/newsgroups/en-us/default.aspx
In the tree on the left, first open the English category, then open Windows.
In Windows, find and open the category for Windows XP.
In that category, find a group to post in.
