pop-up box internet explorer not working
patch41
Vista Pro
328
hi, i keep getting a pop-up box saying that internet explorer has stopped working windows is searching for a solution,the problem is internet explorer is working fine. So i have been just canceling the box out,is there any suggestions to correct the box from popping up.thank you...patch41
fadedrs
Lost in my own World
Power User
695
Location
Maple Grove, MN
what version of IE?
if it is not IE V8 try upgrading to it and see if that helps.
or you could just switch over to FireFox (more stable).
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
mansrm81
1,884
Location
Rockford, IL
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Western Digital 160 GB IDE
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
patch41
Vista Pro
328
hi mansrm81,did like you said programs accessories and system tools and started removing add-ons that i did not need and it seems to have solved the problem. You will have to help me out with the next question as i am a novice,i would like to click the scales but i dont know where. can you clue me in and thanks for the advise....patch41 ps.i just found the scales in the upper right hand corner (i clicked)
mansrm81
1,884
Location
Rockford, IL
Glad I could help patch41
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    7200 rpm
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
