possible function bug?
K
klumsy@xtra.co.nz
if i make a function
function test
$input
then do
whatever | test
the results should be and are the same as if i had run whatever,
correct?
likewise if i do the function
function test2
begin {}
process {$_ }
end {}
that function should effectively do the same thing as test right,
however on a per item basis, EVERYTHING that comes in the pipeline
should go out?
this works in the majority of cases, however if an expession in the
pipeline puts things in the pipeline over multiple expressions, it
fails
i.e
cd "hklm:\system\CurrentControlSet/Control/Session Manager"
(Get-Item .).property | foreach { $_;$( (Get-ItemProperty .).$_ );} |
test2
however actually it works.. its just that i add test2 on, inside C#
code, rather than in script , and in that case it fails, so i don't
know if this is a bug as far as the interfaces are concerned.. however
if i "flatten" it.. all works fine.. i.e
% {$_ }
| test2
hmmm...
(b.t.w the contenxt is inside powershell analyzer..
\cd "hklm:\system\CurrentControlSet/Control/Session Manager"
doesn't show the 2nd lot of things... and its because i am adding a
function on at the last stage of the pipeline that spits out $_ in a
process block..
Karl
(i think i will have confused everybody with this post, well maybe not
the MS guys)
J
James Truher
i'm confuseled
The "2nd lot of things" seem to be the result of a sub-expression. have you
tried
$_;$t = gp .;$t.$_
instead?
James Truher [MSFT]
Windows PowerShell Development
Microsoft Corporation
<klumsy@xtra.co.nz> wrote in message
news:1159548814.910445.190010@b28g2000cwb.googlegroups.com...
> function test
> $input
> then do
> whatever | test
> correct?
> function test2
> begin {}
> process {$_ }
> end {}
> should go out?
> fails
> i.e
> test2
> % {$_ }
> | test2
> hmmm...
> process block..
> Karl
> the MS guys)
