Power Options
rrensing
The Power Options on my control panel simply don't work, no matter what setting I choose. Turning of my screen, sleep and hibernate ignore every setting.
Help !?
    Sony VGN-NS140D
Imperfect1
Try right-clicking on the battery icon in your Desktop system tray (Notification Area) and select Power Options. See if selecting your power options there makes a difference.
    HP Pavillion dv5t (Gen. 1)
    1680 x 1050
    built in - HP
    max
rrensing
Thanks for your message. Tried that but power options still doesn't work. Wonder if something went wrong when I installed the OS.
Thanks again.
    Sony VGN-NS140D
When did you install? What did you USE to install it (copied disc, original upgrade, full, OEM)? Did you change any settings?
    Apple MacBook Pro 13inch
    Intel Core 2 Duo @ 2.26GHz
    2GB DDR3 RAM
    NVIDIA GeForce 9400M @256MB Dedicated DDR3 VRAM
    Intel High Definition Audio
    Laptop: 32 bit Color LCD
    HITACHI HTS545025B9SA02 250GB (Internal)
    IOMEGA PRESTIGE PORTABLE 500GB (External)
    N/A
    N/A
    N/A
    No-Button Aluminum Trackpad w/ Mouse Gestures
    Black Chiclet-Style Keyboard (Standard US) with Backlight
    T1
rrensing
I installed all this a couple of months agop after I installed Windows 7 which promptly messed up my computer to the point where I had to wipe my harddrive and start fresh over again. I used the Vista startup discs that came with my Sony laptop that I bought last February. Before all this my Power Options and everything else worked fine, so I wonder if something with my re-install went haywire.
    Sony VGN-NS140D
