PowerShell equivalents to some dir command variations
L
Larry__Weiss
I'm thinking that I can learn some things about PowerShell if I had some PowerShell
expressions to study that were the equivalent of some cmd.exe dir command
invocations
for a file system directory.
What is a PowerShell equivalent to these dir commands that I use often?
dir /ad
dir /a-d
dir /od
dir /od /a-d
dir /ah
dir /a-h
dir /b
- Larry
L
Larry__Weiss
Marco Shaw [MVP] wrote:
>> some PowerShell expressions to study that were the equivalent
>> of some cmd.exe dir command invocations for a file system directory.
>> dir /ad
>> dir /a-d
>> dir /od
>> dir /od /a-d
>> dir /ah
>> dir /a-h
>> dir /b
> Take a gander here:
> http://blogs.msdn.com/powershell/archive/2009/03/13/dir-a-d.aspx
> If you're up for trying v2, you're in for some fun! ;-)
I tried to follow the two links in that article
https://connect.microsoft.com/feedback/ViewFeedback.aspx?SiteID=99&FeedbackID=252549&wa=wsignin1.0
https://connect.microsoft.com/feedback/ViewFeedback.aspx?SiteID=99&FeedbackID=308796&wa=wsignin1.0
but I get the ambiguous notice
Page Not Found
The content that you requested cannot be found or you do not have permission
to view it.
Is there a way I can sign up to be able to access these resources?
- Larry
B
Bob Landau
Using Get-ChildItem to do slighly complicated but common filesystem tasks was
sooo frustrating that I nearly gave up using Powershell. What you've
mentioned below is so ackward compared to the NT shell.
Luckily I didn't give up on PS and wrote my own version of DIR which is/was
up on Microsofts' Scripting site (dir2.ps1) unfortunately I can't find it now
to give you the location.
I think I'll stick it up on CodePlex (the scripting site is really meant for
10-20 lines). Perhaps thats why the got rid if it.
Its a wrapper around Get-ChildItem but gives you the same simple syntax that
you and me are acustom to. See man page below
If you a would like to receive a copy prior it being published send me email
via my dog Galen: [email protected] (he doesn't mind spam) and I send you
the file. Its much too large to post to this news group.
bob
Here is the helpfile for it.
PS C:\Windows\System32> dir -?
These are the Standard options available in DIR
/A Displays files with specified attributes.
attributes D Directories R Read-only files
H Hidden files A Files ready for archiving
S System files I Not content indexed files
L Reparse Points - Prefix meaning not
/B Uses bare format (no heading information or summary)
/O List by files in sorted order
sortorder N By name (alphabetic) S By size (smallest first)
E By extension (alphabetic) D By date/time (oldest first)
A LastAccessTime C Same as D
W LastWriteTime - Prefix to reverse order
/P Pauses after each screenful of information
/S Displays files in specified directory and all subdirectories
/W Uses wide list format
-Search <character expression to include in search> <optional character
expression to exclude in search>
Like Get-ChildItem/Dir: the current directory will be used if no
-Path parameter is specified
This option is similar to the WHERE command that some might be
familar with.
This is simply a short cut for the following
Get-ChildItem -Path <...> -Include <...> -Exclude < > -Recurse
Both -Path and -Exclude are optional.
-LiteralPath now will filter the output by processing the expressions in
both Include/Exclude arguments.
This workaround can be removed once -LiteralPath has been fixed.
-Escape < [System.Collections.HashTable[]] > with the following signature:
@{Name='Name'; Expression=' User defined Filter pipe : returning
either a File/Directory Info class '}
This gives one the ability to inject a pipe expression into this
script.
This option is really ONLY benefitial to 5 percent of the Pipeline
expressions. Unless this is
used to "filter" the output for the next Pipe; this should not be
used.
Press <RETURN> for Get-ChildItem help :
< the rest of the help is Get-ChildItem>
> >> dir /ad
> >> dir /a-d
> >> dir /od
> >> dir /od /a-d
> >> dir /ah
> >> dir /a-h
> >> dir /b
> > Take a gander here:
> Page Not Found
> to view it.
> - Larry
willsteele
Being a cmd shell junkie, I can understand your pain. I know it's an old post, but, these are good commands for folks coming up from cmd to powershell anyway.
dir /ad
Get-ChildItem | Where-Object {$_.PSIsContainer}
dir /a-d
Get-ChildItem | Where-Object {!$_.PSIsContainer}
dir /od
Get-ChildItem | Sort-Object Date
dir /od /a-d
Get-ChildItem | Where-Object {!$_.PSIsContainer} | Sort-Object Date
dir /ah
Get-ChildItem -force -path C:\ | Where-Object {$_.Mode -match "h"}
dir /a-h
Get-ChildItem -force -path C:\ | Where-Object {!$_.Mode -match "h"}
dir /b
Get-ChildItem | Select-Object Name
L
Larry__Weiss
What I've also done is to place a cmd.exe batch file named dirr.bat into my path
that contains the two lines
@echo off
dir %*
This lets me add an extra "r" to "dir" whenever I need to use the legacy form of
the dir command.
Bob Landau shared his dir-like PowerShell command with me some time ago, and I
intend to complete a derivative of it that permits a similar parameter structure
as the legacy dir command without falling back on cmd.exe
I feel like I now have enough PowerShell practice behind me to allow me to
understand how Bob's scripting works.
I also feel that for reasons of ease of use as well as efficiency that Microsoft
should extend the file system provider's version of Get-ChildItem to allow the
parameter structure of cmd.exe's dir command.
- Larry
> powershell anyway.
> dir /ad
> dir /a-d
> dir /od
> dir /od /a-d
> dir /ah
> dir /a-h
> dir /b
ewgoforth
dir /ad
dir /a-d
dir /od
dir /od /a-d
dir /ah
dir /a-h
dir /b
I know this is ancient, but it's the first result in a Bing Query. I found that I needed to change Sort-Object Date to Sort-Object LastWriteTime to mimic the /od functionality.
    Windows 10
