Powershell Script to backup Domain Controllers
C
Craig
Is there a ps script which can be used to backup AD System State Data on a
daily basis and a weekly full system backup. If yes, can this script be
scheduled to run daily?
J
jfrmilner
Craig,
It would be simpler if you just used Scheduled Tasks with ntbackup (2003) or
wbadmin (2008). Here are the links to the syntax:
wbadmin
http://technet.microsoft.com/en-us/library/cc754015(WS.10).aspx
ntbackup
http://technet.microsoft.com/en-us/library/bb490952.aspx
Regards,
jfrmilner
M
Marco Shaw [MVP]
Can you be more specific about whether this is for Server 2003, Server 2008
or Server 2008 R2? I don't know if the command-line utilities will be able
to do this...
Also, I've not done sys admin for years, I believe the mechanism as of
Server 2008 is to do system snapshots. Will that do for your weekly full
backup?
Marco
"Craig" <Craig@newsgroup> wrote in message
news:#VmOPBOgKHA.1112@newsgroup
V
Vadims Podans [MVP]
for windows server 2008 you can check this:
http://richardsiddaway.spaces.live.com/Blog/cns!43CFA46A74CF3E96!1006.entry
for 2008R2:
http://www.sysadmins.lv/PermaLink,guid,ffb3aa89-0bc0-4de0-9eaf-5866e813afec.aspx
http://www.sysadmins.lv/PermaLink,guid,89438ea9-9bec-4070-8d81-f355a2215a8c.aspx
(these links in Russian. You may have to use online translators from Russian
to your language).
WBR, Vadims Podans
MVP: PowerShell
PowerShell blog - www.sysadmins.lv
"jfrmilner" <jfrmilner@newsgroup> rakstÄ«ja ziņojumÄ
"news:859A530D-692F-4E70-BA44-F89BC99A758D@newsgroup"...
> Craig,
> or
> wbadmin
> ntbackup
> Regards,
> jfrmilner
>> a
