PowerShell's Default Start Directory
A
Algernon
How do I change the directory that PowerShell starts in? it shows my
"Documents and Settings\username" for a path after the prompt, but I
just want to see "PS C:\"
R
RichS
Do you want PowerShell to start in c:\ ?
if so then right click the icon you use to start it and chnage the "Start
in: " property on the Shortcut tab to be the folder where you want to start
Do you just want the prompt to say C:\ irrespective of where you start?
If so then change the prompt function in your profile so that it says "C:\"
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
Blog: http://richardsiddaway.spaces.live.com/
PowerShell User Group: http://www.get-psuguk.org.uk
D
dreeschkind
Putting
set-location c:\
in your PowerShell startup script ($profile) might also be an option.
....\MyDocs\WindowsPowerShell\Microsoft.PowerShell_profile.ps1
greetings
dreeschkind
G
Guest
"Algernon" <[email protected]> a écrit dans le message de news:
[email protected]...
in your $PROFILE file, you can add a
Set-Location "xxxxxxxxx"
where xxxxxxxxx is the path you want to start on.
bye
Nico
