Prevent Output
  • Thread starter ryanlsanders@gmail.com
  • Start date
R
I have this script (yes I am using some stuff from Quest)
$VAR = 0
while ($VAR -ne 10)
$VAR++
New-QADUser -ParentContainer 'OU=Test,DC=domain,DC=local' -Name
"Test User$var"
How can I prevent the script from showing a line for each user added.
I just want a output line when the script has run.
K
Keith Hill [MVP]
<ryanlsanders@gmail.com> wrote in message
news:1180555213.973716.171960@q69g2000hsb.googlegroups.com...
> $VAR = 0
> while ($VAR -ne 10)
> $VAR++
> "Test User$var"
You have a couple of options:
$results = New-QADUser -ParentContainer 'OU=Test,DC=domain,DC=local' -Name
"Test User$var"
if you want to keep the output of this cmdlet. If you don't want the output
at all then you could also do this:
New-QADUser -ParentContainer 'OU=Test,DC=domain,DC=local' -Name "Test
User$var" > $null
Keith
D
dreeschkind
Piping to out-null should do the trick:
$VAR = 0
while ($VAR -ne 10)
$VAR++
User$var" | out-null
greetings
dreeschkind
> $VAR = 0
> while ($VAR -ne 10)
> $VAR++
> "Test User$var"
R
RichS
$null = New-QADUser -ParentContainer 'OU=Test,DC=domain,DC=local' -Name
"Test User$var"
should work as well
Richard Siddaway
Please note that all scripts are supplied "as is" and with no warranty
Blog: http://richardsiddaway.spaces.live.com/
PowerShell User Group: http://www.get-psuguk.org.uk
> $VAR = 0
> while ($VAR -ne 10)
> $VAR++
> greetings
> dreeschkind
> > $VAR = 0
> > while ($VAR -ne 10)
> > $VAR++
> > "Test User$var"
K
klumsy@xtra.co.nz
> $VAR = 0
> while ($VAR -ne 10)
> $VAR++
> [void] ( New-QADUser -ParentContainer 'OU=Test,DC=domain,DC=local' -Name "Test User$var" )
casting to void works.. here being a cmdlet you gotta put the
expression in a ()
but if its say just a method on a dotnet object you could do
[void]$a.additem()
