Print date picture was taken on picture
C
Carol
I have Windows Photo Gallery and Hp Photosmart printer. I need the date the
picture was taken printed on the picture for a legal reason. How do I do
this. I can get the picture on the screen with the date but it does not
print.
Thanx to all who can help me. Carol
J
John Inzer
> date the picture was taken printed on the picture for a legal reason.
> How do I do this. I can get the picture on the screen with the date
> but it does not print.
Maybe the following free software would
be worth a try.
FastStone Image Viewer
http://www.faststone.org/FSViewerDetail.htm
"Basic steps to add dates to image files
using Fast Stone Image Viewer"
(You'll have to experiment with position, font
size, color and the various Variables to achieve
the result you desire.)
Tools / Batch Convert / Batch Convert tab...
Check the box...Use advanced options...
Advanced Options button / Text tab /
Check the box...Use Text...
Open the drop window..."Insert a Variable"
choose...EXIF DateTime / Date and Time...OK...
Add the files you wish to append...
Choose an Output Format...
Choose an Output folder...
John Inzer
Digital Media MVP
Notice
This is not tech support
I am a volunteer
Solutions that work for
me may not work for you
Proceed at your own risk
C
Carol
Thank you for the help. I actually copied the pictures to a different
software and it worked. I will play with your suggestions and appreciate the
fact that you responded.
> be worth a try.
> John Inzer
> Digital Media MVP
> Notice
> I am a volunteer
J
John Inzer
> appreciate the fact that you responded.
You're welcome.
Which software worked for you?
John Inzer
Digital Media MVP
Notice
I am a volunteer
