Print Screen using Vista
This may be the stupidest question ever, but how does the "print screen" work
on Vista? I've tried every possible thing with Shift, Ctrl, Alt..... Still
seeking the resolution.
M
this is a programmign group - but to answer your question -
its Alt-PrintScreen - and it puts the pictuer of your desktop into your
clipboard to be pasted anywhere.
Now, if you have a laptop - you probably have to hit something like
Alt+FunctionKey+Printscreen, if the printscreen button is on a 'secondary
button'
Miro
"n8" <n8@xxxxxx> wrote in message
news:F8F11914-9A09-4C02-9AF3-434AED7CCAD2@xxxxxx
> work
> Still
M
Mark Salsbery [MVP]
> work
> Still
Ctl-PrtScn gets the entire desktop
Alt-PrtScn gets the active top-level window
Some keyboards (like mine) you need to turn FLock off to get at the PrtScn.
Mark
Mark Salsbery
Microsoft MVP - Visual C++
wow....alt+function key+printscreen works!
they say for vista there's a snipping tool for capturing a window...but i
couldn't find it either.
thanks a lot for the alt+fn+prtsc.
> button'
> Miro
> > work
> > Still
locoeng
Flim-Flam Man
> button'
> Miro
> > work
> > Still
Here ya go ~ http://www.vistax64.com/tutorials/148532-how-use-snipping-tool-vista.html
SIW2
> button'
> Miro
> > work
> > Still
You need Tablet PC installed to get the Snipping Tool. Don't think you get it in Home Basic.
If you have one of the other editions, ControlPanel>Uninstall a Program and on the left of that window, Turn Windows features on or off.
Faststone Capture53 is an excellent free screen capture app.
FastStone Capture 5.3 - eSnips, share anything
Hope it helps
SIW2
