Hello all,
I've found a solution (worked for my setup) that clears the printer offline
problem when printing from a Vista laptop PC over a home network to a printer
connected to a Windows98 desktop PC. I never had this problem with my XP
Home laptop accessing the printers on the Windows98 PC.
With the Vista PC, I was always able to Add my 2 printers (HP PSC 1350 and
Canon i560) using Vista's wizard (Add a local printer), but after a restart
of the Vista PC, both printers would be offline. In Printer properties,
Ports tab, both printers would appear as Client Side Rendering Provider under
the Description column.
My Vista PC is a new Dell Inspiron 1420, Vista Home Premium.
My print server is a Dell Dimension V350, Windows 98.
Home network is WiFi using a D-Link 624 router, WPA-PSK security enabled.
Canon i560 on parallel port of Dell Dimension V350
HP PSC 1350 on USB port of Dell Dimension V350
Here's the fix:
1. In Control Panel, Printers, delete offline printers. If they wont
delete, it may be because there are pending print jobs in the queue. Open the
printer and Cancel the jobs.
2. In Printer properties, Ports tab, delete the previoulsy installed
printers (offline statuts) that appear as Client Side Rendering Provider
under the Description column. To do this, highlight the port, then click on
Delete Port button. Click Apply.
3. Restart your PC.
4. Now reinstall the printers as follows:
5. Open Control panel, Printers, and click Add a printer.
6. Click Add a local printer.
7. Select the "Use an existing port" radio button, and select LPT1: (Printer
Port). Click Next.
8. Install the printer driver. Mine were found in the list inlcuded with
Vista. Select the manufacturer and the printer. Click Next.
9. In the next window, accept the printer name or type in a new name. Leave
the "Set as default printer" box unchecked. Click Next.
10. Vista should now install the printer. A window should open saying
"You've successfully added printer name.
11. DO NOT Print a test page at this time, because nothing is connected to
the LPT1 port on the laptop. Just press Finish. The printer you just added
should appear in the Printers window.
12. Click ONCE on the newly added printer to highlight it, then right-click
and open Properties.
13. On the Ports tab, click Add Port…, select Local Port, then click New Port…
14. When the Port Name window open, Enter a port name as follows:
\\computername\printername
(replace computername with the name of your PC acting as print server, and
printername with the name of your printer). Click OK.
15. You should now have a new port listed on the Ports tab of the printer
Properties, but now the Description should be Local Port, instead of Client
Side Rendering Provider. Click OK.
16. Now you can go to the General tab, and Print a Test Page.
Hopefully, your test page will print. Then restart your computer to check
that the printer comes back online.
This procedure worked for me. Hope it works for you too. Good luck!
"Alan Morris [MSFT]" wrote:
> Yes this was deprecated.
> Are you using a net use command to LPT on startup?
> When attempting to connect do you get the "could not connect" dialog.
> What port is the Vista "connection" assigned?
> Alan Morris
> Windows Printing Team
> Search the Microsoft Knowledge Base here:
> http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
> This posting is provided "AS IS" with no warranties, and confers no rights.
> "Howard - Sheffield" <[email protected]> wrote in
> message news:[email protected]
> > Do you really mean 'disabled' - or just not designed and tested to work
> > with
> > Win9x?
> > Clearly I can get Vista to print to a printer attached to a Win ME PC over
> > my network - I just can't get it to stay on-line on a restart.
> > The net print command worked as you indicated - but teh printer is still
> > shown as off-line.
> > Are you saying that because Vista is not designed to work with Win9x PCs,
> > this situation isn't fixable? Is there a workaround to keep the printer
> > on-line?
> > Regards
> > Howard - Sheffield
> >> Actually connecting to a shared Win9x printer was disabled in Vista. I
> >> assume you created a local port that targets
> >> \\WindowsMEmachine\printershare
> >> in order to create the SMB connection.
> >> When the printer goes offline open a command prompt and type
> >> net print \\WindowsMEmachine\printershare
> >> you should get this returned.
> >> E:\>net print \\win98\xerox
> >> Printers at \\win98
> >> Name Job # Size Status
> >> XEROX Queue 0 jobs *Printer Active*
> >> The command completed successfully.
> >> Alan Morris
> >> rights.
> >> "Howard - Sheffield" <Howard - [email protected]> wrote
> >> in
> >> >I have (well at least my daughter has) a Vista home basic laptop - with
> >> > almost identical problems.
> >> > I can connect okay (over a Netgear wireless network) to an Epson 760
> >> > printer
> >> > (using the standard Vista driver) which is connected to an older PC
> >> > running
> >> > Windows ME - but if the laptop goes to sleep, or is re-started - the
> >> > printer
> >> > shows up as off-line - and won't come back on line - using either the
> >> > standard or admin menus.
> >> > The only successful method seems to be to delete and re-install the
> >> > printer
> >> > - every time you turn the laptop off. What a pain! (Not something I can
> >> > explain to my daughter how to do).
> >> > I have seen some comments from Alan Morris elsewhere about disabling
> >> > SNMP
> >> > on
> >> > the printer port - but even after re-installing from scratch (with teh
> >> > printer working fully) - the 'configure port' button shows up an error
> >> > when
> >> > clicking on it. So how do I get access to this SNMP setting (for a
> >> > network
> >> > port).
> >> > I have searched for hours on the internet for solutions to this issue -
> >> > and
> >> > there are literally thousands of posts to all sorts of technical forums
> >> > about
> >> > this same issue (with some pretty crazy suggestions being put forward).
> >> > Many
> >> > people obviously haven't realised that this is a straight Windows Vista
> >> > bug.
> >> > It works fine on Windows ME and XP - so isn't it about time that
> >> > Microsoft
> >> > sorted this problem out - for all versions of Vista - and stopped
> >> > people
> >> > pulling their hair out on this one.
> >> > If I had a choice (except that this was a smart new laptop with Vista
> >> > Basic
> >> > on) - I would go straight back to Windows XP asap - at least it works!
> >> > Come on Microsoft - you must know what the problem is by now - it's
> >> > highly
> >> > repeatable for any number of printers. We all want a downloadable
> >> > hotfix/solution now!!!
> >> > Howard - Sheffield, UK
> >> > "Corliss" wrote:
> >> >> Hi guys,
> >> >> The issue is when a vista machine "sleeps" or is logged off but still
> >> >> the
> >> >> machine is still running.
> >> >> As far as I can tell the vista machine does not refresh the printer
> >> >> list
> >> >> after the workstation comes back online.
> >> >> To fix this you must ensure that SNMP is not selected.You must restart
> >> >> your
> >> >> workstaion and problem solved.
> >> >> Once again when SNMP is selected and the workstaion goes into standby
> >> >> mode
> >> >> the list is not being refreshed.
> >> >> Cheers,
> >> >> Corliss
