Printing cropped images
L
Lothan
I have a problem that's driving me up a wall and I can't figure out how to
solve it. I'm using Windows 7 Ultimate x64 with a Canon iP6700D photo
printer and I've installed Windows Live Photo Gallery. I can use various
combinations of applications to print standard-sized pictures (4x6, 5x7,
8x10) with no problem. The issue is that I need to print an odd-size picture
for a 1.75-by-2.75-inch frame. I've already cropped the picture to the
correct size, but I can't get Windows Live Photo Gallery, Paint, Paint.NET,
or Adobe Photoshop Essentials to print the image in its cropped size. It
seems no matter what I do, Windows insists it print a "full page photo" to
match whatever paper size I've selected and the Canon printer driver won't
let me select custom paper sizes below 2.5-by-3.5-inches.
Any idea how I can convince Windows to print the original image without
blowing it up to match the paper size?
J
John Inzer
> how to solve it. I'm using Windows 7 Ultimate x64 with a Canon
> iP6700D photo printer and I've installed Windows Live Photo Gallery.
> I can use various combinations of applications to print
> standard-sized pictures (4x6, 5x7, 8x10) with no problem. The issue
> is that I need to print an odd-size picture for a 1.75-by-2.75-inch
> frame. I've already cropped the picture to the correct size, but I
> can't get Windows Live Photo Gallery, Paint, Paint.NET, or Adobe
> Photoshop Essentials to print the image in its cropped size. It seems
> won't let me select custom paper sizes below 2.5-by-3.5-inches.
> without blowing it up to match the paper size?
The freeware FastStone Image Viewer has
an option on the Print screen that allows you
to enter exact dimensions.
http://www.faststone.org/FSViewerDetail.htm
It also has a crop tool that allows you to crop
specific sizes...if the size you want is not in the
list you can add a custom size.
J. Inzer MS-MVP
Digital Media Experience
Notice
This is not tech support
I am a volunteer
Solutions that work for
me may not work for you
Proceed at your own risk
