Solved problem installing program
ognjenka724
I'm trying to install Portable Janus on my Vista Home Premium.
I tried with enable/disable UAC, tried with Compatibility mode and it didn't work.
Message is: Windows cannot access the specified device, path or folder. You may not have appropriate permissions to access the item.
Can anybody help?
You are very welcome, glad that it all worked out.
