Solved Problem Uninstalling Hawking Print Server Software
andrewlloyd
Keywords: Uninstall Hawking HWPS12UG Print Server Utilities
Problem
When uninstalling the Hawking Print Server Utilities, you receive the message 'HAWKING_PS-P1 still in use! Please release the port before to complete uninstall Network driver'
Cause
You have a printer defined in your system (in Control Panel, Printers and Faxes) that is using the port named HAWKING_PS-P1, the port to which the Hawking Print Server Utilities' Network Driver is assigned.
Solution
  • Setting the printer concerned offline does not help.
  • Deleting the printer concerned does not help.
  • Deleting the port HAWKING_PS-P1 (using the Printers and Faxes window's menu option File, Server Properties, Ports tab) produces the error message 'Selected port cannot be deleted. Operation could not be completed.'
  • After rebooting the system, deleting the port succeeds.
  • After deleting the port HAWKING_PS-P1, the uninstall of the Hawking Print Server Utilities succeeds .
Hello andrewlloyd and welcome to the forums :party:
Thanks for sharing your solution with us :) I'm sure others who are experiencing the same problem as you will benefit from your advice
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    Samsung EVO 128GB SSD
    Seagate Barracuda 2TB 7200rpm
    NZXT Phantom 410
