problem with invoke-expression
B
Ben Christian
trying to open some documents, but some of the filenames have spaces in them,
and i'm not able to get invoke-expression to properly read it. I've tried
messing around with quotes, double quotes, parenthesis, etc, but can't seem
to get it to work...invoke expression stops reading the variable where the
first space in the path is...
here's the code snippet...
$files = @(get-childitem $searchpath | ? {$_.extension -match "pdf"})
foreach ($document in $files) {
write-host $document.fullname
invoke-expression $document.fullname
i've also just tried using $searchpath\$document instead of
$document.fullname. Neither work.
Thanks for your help!!
K
Kiron
Use Invoke-Item instead of Invoke-Expresion
invoke-item $document.fullname
Kiron
K
Kiron
You can also use the Call operator too:
& $document.fullname
Kiron
K
Keith Hill [MVP]
True but since the primary distinction between & and . (dot) is that dot executes the command in the current scope there isn't much benefit to using it when invoking external commands.
Keith
"Kiron" <Kiron@xxxxxx> wrote in message news:41032077-DEBE-4311-BDE6-0E5CB71301F6@xxxxxx
...or the Dot:
. $document.fullname
Kiron
