Problems Installing Divx
C
Connie
My computer crashed and I'm trying to install Divx codec. I thought I only
needed the codec but the file would not play so I downloaded all four
components. Now it will play in the Divx player but as soon as I set WMP as
my default I get a message the WMP does not support the file. They are all
..avi files. Just to test, I tried the same files on another PC and they play
fine. Can anyone suggest what I need to do?
C
Connie
Doesn't seem to be a lot of activity over there so if anyone has any other
suggestions, I would appreciate. I should say I tried uninstalling and
reinstalling numerous times to no avail.
"Connie" <[email protected]> wrote in message
news:[email protected]
> Thank you!
> "porfitron" <[email protected]/> wrote in message
> news:%[email protected]
>> Not sure if my last post went through, but just in case, try asking for
>> help on the forum at DivX Labs: http://labs.divx.com since this is where
>> DivX people hang out to discuss the latest DivX Plus Software
>> frmsrcurl:
>> http://msgroups.net/microsoft.public.windows.vista.music_pictures_video/Problems-Installing-Divx
J
John Inzer
> other suggestions, I would appreciate. I should say I tried
> uninstalling and reinstalling numerous times to no avail.
Just guessing...but maybe you need the XviD codec:
(FWIW...it's always a good idea to create a System
Restore point before installing software or updates)
XviD Codec
http://www.xvidmovies.com/codec/
Good luck...
J. Inzer MS-MVP
Digital Media Experience
Notice
This is not tech support
I am a volunteer
Solutions that work for
me may not work for you
Proceed at your own risk
C
Connie
Thanks John.
"John Inzer" <[email protected]> wrote in message
> XviD Codec
> Good luck...
> J. Inzer MS-MVP
> Notice
> I am a volunteer
