Problems Sending Mail (Hotmail Account)
A
Adam G. Alsop
Hello:
I have noticed lately that I am having persistent problems in sending mail
(even a simple text message) using my Hotmail accounts. I will often have to
let it error out, then keep retrying several times before the message(s)
finally send. The server is set to HTTP -
http://mail.services.live.com/DeltaSync_v2.0.0/sync.aspx
The WLM version is 2009 (Build 14.0.8064.0206) - is there a more recent (or
beta) version?
Also, as a side note, I know that there is an issue with deleting or moving
a lot of messages at one time that ends up requiring the account to be
deleted in WLM and then being re-created. I was wondering if this issue is
being worked on at all?
Thank you :)
N
N. Miller
> beta) version?
I've had occasional failures of the Hotmail HTTPMail servers over the years.
I just chalk it up to a server glitch, and try again later. I've never seen
the problem persist more than a couple of days. If you need a more reliable
email service, you should look into fee-based third party providers.
Basically, you get what you are willing to pay for.
Norman
~Oh Lord, why have you come
~To Konnyu, with the Lion and the Drum
C
C Portanova
Adam,
I too am having all kind of problems, and just moved to a temporary DSL
connection and thought that was the problem - but I have no problems getting
online. It's just sending (not receiving) any emails for me despite the
account in Windows Live Mail. And I'm not a fan of using the web-based mail
apps - I really like using Windows Live Mail! And updates on a fix from
Microsoft would be helpful!
Thanks,
Carolyn Portanova
"Adam G. Alsop" wrote:
> Hello:
> beta) version?
> Thank you :)
I
Ildhund
It would help if you posted the entire error message that you get,
so that people have a chance of diagnosing what your problem is.
While the Hotmail servers do drop out occasionally, in my experience
it's months between occurrences, when some maintenance is being
done.
That said, the usual cause of intermittent errors in sending is
antivirus scanning of outgoing mail. Could that be your problem?
You are using the latest version of WLMail.
It's as well to be circumspect when manipulating large numbers
(hundreds) of messages. There's a lot of work involved in the
background involving a lot of memory, and any system will choke if
it's provoked beyond the limit. Take the time to do it by easy
stages and let things settle down before starting on the next lot.
Another good idea is to force a compaction of the database after
manipulating large numbers of messages.
Noel
"Adam G. Alsop" <AdamGAlsop@xxxxxx> wrote in
message news:2137EF01-46CC-4F59-836C-4C5AEFA96280@xxxxxx
> Hello:
> sending mail (even a simple text message) using my Hotmail
> accounts. I will often have to let it error out, then keep
> retrying several times before the message(s) finally send. The
> recent (or beta) version?
> or moving a lot of messages at one time that ends up requiring the
> account to be deleted in WLM and then being re-created. I was
> wondering if this issue is being worked on at all?
A
Adam G. Alsop
Noel:
Yes, you are correct. I *should* have posted the complete error message -
and I will do so the next time it occurs.
Anti-virus is not an issue, as I have it turned off for outgoing mail (that
was actually the first thing I checked).
I will try compacting things the next time I move a lot of messages (hadn't
thought of that).
It's not that it's *that* big of a deal to remove and re-add the account in
WLM, it's just the time it takes when you have a lot of messages for it to
download, lol. Overall, I still find Hotmail to be the most preferable
"free" mail system (over the likes of Yahoo, GMail, etc). I would have just
thought that the sync process would be similar to that betweek Outlook &
Exchange, and I've never encountered a similar issue with them.
And I agree with you, it's been a rare occasion when the actual Hotmail
server is down - that's clearly not the case with the issue I'm describing,
as I can log into the web interface and things work just fine.
As I said, I'll update this thread with specific error message the next time
it happens.
Thank you for your helpful response :)
--- Adam
> done.
> Noel
> > Hello:
