Product Key on bottom of Laptop faded ! help
T
The Patient
I have had a corrupted system for some reason so had to remove everything
and restart. However. The Vista Product Key on the bottom of my Laptop has
faded so a few of the letters look unrecognisable. I have tried what I
believe it to be and it doesn't work. As I have not exactly lost my Product
Key, Is there a way to get this product key from somewhere without paying for
a new one ?? I have activated it with microsoft and provided my details so
should it be registered to me somewhere ??
Help !
C
Carey Frisch [MVP]
How to Replace Lost, Broken, or Missing Microsoft Software or Hardware
http://support.microsoft.com/kb/326246/en-gb
Carey Frisch
Microsoft MVP
Windows Desktop Experience -
Windows Vista Enthusiast
"The Patient" <[email protected]> wrote in message news:[email protected]
Help !
chinga69
    PHENOM II X4 Quad Core 965 Black Edition CPU, 3.40 GHz
    GA-MA790FXT-UD5P
    G.Skill 4GB (2x XMS3 2GB) PC-12800 (1600MHz
    nvidia 9500 gt
    on board
    T231H / X243H ACER
    1980x1050
    Hitachi 500 samsung 1terabyte wd 750
    550 watt
    cooler master
    stock
    logitech
    microsoft
    8000 dl 356 ul
    booting xp32 2x dual pci-e digital tv tuners
    xp pro v 1xpci digital tv tuners
    vista ultimate 64 1x pci sat tuner
    win7 64
    win8 64
M
Malke
chinga69 wrote:
> this will show you your product key
> 'RJL Software - Software - Utility - Windows Product Key Viewer'
> (http://www.rjlsoftware.com/software/utility/winproductkey/)
> sorry wont work if you have reinstalled vista
Key finders like that won't help the OP. The key finder will only show the
OEM's volume license key used for their image. The correct Product Key on
an OEM machine is always the one on the COA sticker.
To the OP: With OEM machines one usually doesn't need the Product Key unless
one forgets to create restore disks or has otherwise lost the OEM
installation media. Is that your situation? In that case, the best solution
is to contact the OEM and get replacement restore disks. This usually is
quite inexpensive.
Malke
MS-MVP
Elephant Boy Computers
www.elephantboycomputers.com
Don't Panic!
Brink
Staff member
mvp
quite inexpensive.
Malke
MS-MVP
index
Don't Panic!
Hi Malke,
I had a OEM product key number for a version of Vista I had before and this program posted by Chinga69 above showed the correct product key number, and not the same product ID number shown under System in Vista.
http://www.vistax64.com/tutorials/85023-product-key-number.html
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    6TB WD Black WD6001FZWX
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
M
Malke
I'm not talking about generic OEM keys. Naturally the product key you see in
a key finder program will match the one on the COA if you use a generic
OEM.
However, unless the OP comes back with more information about the situation,
the issue is moot and the thread is dead.
Malke
MS-MVP
Don't Panic!
G
Guy seeking help
I just prchased a laptop from a store. I couldnt find the product key. So I
decided to look underneath the laptop. I located all the serial numbers and
the product key. When I enter the product key I receive a message saying that
it's wrong. I made sure the letters and numbers were correct several times
but it still won't work. Can any help?
Guy seeking help
> OEM.
> Malke
> MS-MVP
> Don't Panic!
Brink
Staff member
mvp
Hello,
The Product Key Number should be the one with 25 numbers and letters broken up into 5 sections. The screenshots for the examples in this tutorial may help you locate it better to.
Guy seeking help
> OEM.
> Malke
> MS-MVP
> Don't Panic!
    Lumia 1520 phone
J
JW
You can use the following utility:
"Guy seeking help" <[email protected]> wrote in message
> and
> that
> Guy seeking help
>> in
>> OEM.
>> situation,
>> Malke
>> MS-MVP
>> Don't Panic!
D
David B.
That product key is OEM, are you installing from an OEM installation disc?
Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm
How to ask a question http://support.microsoft.com/kb/555375
Help Us Help You http://dts-l.net/goodpost.htm
> and
> that
> Guy seeking help
>> in
>> OEM.
>> situation,
>> Malke
>> MS-MVP
>> Don't Panic!
M
Mark H
Doesn't matter what install disc is used. The PID determines the
installation.
The PID derived with a third party product will reveal the manufacturer's
volume PID typically tied to the BIOS. This will not be the PID on the
label.
"David B." <[email protected]> wrote in message
>>I
>> and
>> that
>> times
>> Guy seeking help
>>> > Vista.
>>> see in
>>> OEM.
>>> situation,
>>> Malke
>>> MS-MVP
>>> Don't Panic!
D
David B.
You are incorrect, you can't use upgrade or retail installation media with
an OEM product key.
"Mark H" <[email protected]> wrote in message
> installation.
> label.
>> disc?
>>>I
>>> and
>>> that
>>> times
>>> Guy seeking help
>>> "Malke" wrote:
>>>> > and
>>>> > Vista.
>>>> see in
>>>> OEM.
>>>> situation,
>>>> Malke
>>>> MS-MVP
>>>> Don't Panic!
D
David B.
Damnit, I'll shut up now, for some reason I thought I was in one of the XP
groups :(
> an OEM product key.
>> installation.
>> label.
>>> disc?
>>>>So I
>>>> and
>>>> saying that
>>>> times
>>>> Guy seeking help
>>>> "Malke" wrote:
>>>>> > and
>>>>> > Vista.
>>>>> see in
>>>>> generic
>>>>> OEM.
>>>>> situation,
>>>>> Malke
>>>>> MS-MVP
>>>>> Don't Panic!
M
Mark H
> groups :(
>> with an OEM product key.
>>> installation.
>>> manufacturer's volume PID typically tied to the BIOS. This will not be
>>> the PID on the label.
>>>> disc?
>>>>>So I
>>>>> numbers and
>>>>> saying that
>>>>> times
>>>>> Guy seeking help
>>>>> "Malke" wrote:
>>>>>> > and
>>>>>> > key
>>>>>> > Vista.
>>>>>> see in
>>>>>> generic
>>>>>> OEM.
>>>>>> situation,
>>>>>> Malke
>>>>>> MS-MVP
>>>>>> Don't Panic!
C
Curious
On My HP Vista Laptop the Key finder program returns the key on the HP label
on the bottom of the unit.
> installation.
> label.
>> disc?
>>>I
>>> and
>>> that
>>> times
>>> Guy seeking help
>>> "Malke" wrote:
>>>> > and
>>>> > Vista.
>>>> see in
>>>> OEM.
>>>> situation,
>>>> Malke
>>>> MS-MVP
>>>> Don't Panic!
D
David B.
See my above post on my Monday brainfart
"Richie Hardwick" <[email protected]> wrote in message
>>an OEM product key.
> Change "OEM" to "branded OEM" and you would be correct.
> Richie Hardwick
M
MarikaWaqavou
"The Patient" wrote:
> Hi,
> Help !
> Please show me my roduct key.
M
Manny Weisbord
>> Hi,
>> Help !
HUH?
What are you asking for? WHO are you asking? The person you quoted?
THAT person wrote what you replied to A YEAR AGO and then never came
back!
F
Father2010
i have the same problem except i did not reinstall anything. i never put
the product key in and now that i need it, i cant read it. i dont know
what OEM is and i dont know what to do. help?
windows vista Tm activation key
The laptop was xp and we changed it to vista ultimate we've used it for
some time and now need activation. help
Father2010
Father2010's Profile: http://forums.techarena.in/members/214615.htm
View this thread: http://forums.techarena.in/vista-setup-install/970216.htm
