Programs stopped working
Muff
Hi all i need serious help.
All of a sudden some of my programs stopped working, for example catalysst control center is suposed to start as soon as vista starts, but now it gives me an error like:
"CCC.exe has stopped working"
Same with some others...
Yes i ran AVG, i ran malware, and superantispyware, none of them finds anything.
I cant even load daemon tools now, it gives me some error: "Engine loading was failed", cant uninstall it, it gives me another error, and some of the programs like netlimiter if i start them from my objectdock dock they automaticly stop working, only when i start them from the normal .exe they dont crash.
All this happened all of a sudden...anyone has any ideas??
Thx a lot in advance,
Muff
Mr Smiley
Hi Muff
What Firewall are you using? Have you configured your security software so that the Catalyst Control Centre is a trusted start-up program. Is Windows Defender or UAC blocking it from normal start-up. Did you run the Display Driver as an Administrator when you installed it?
Personally I found the Catalyst Control Centre lagging a little on start-up anyway so I only installed the Display Driver instead.
I'm assuming you are running the latest version of the ATI Driver?
I might be wrong, but it may well be a 'Permissions' issue.
One more thing, are you running 32Bit or 64Bit, and if 64, is ObjectDock compatible with it?
Kind Regards
Neil
    Intel Core i7-920
    Gigabyte GA-EX58-UD3R
    Gigabyte GV-N26OC-896H-B
    N/A - On Board via SPDIF
    BenQ 24" E2420HD
    1920 x 1080p Full HD
    Western Digital
    1 x TB Sata
    1 x 320GB Sata
    Zalman 1000 Watt
    Antec Twelve Hundred
    2 x Liteon DVD Burners Sata
Kernel
Vista User
Power User
Hi Muff,
The first step i would recommend here is system restore since you have multiple issues. if system restore is not your option then you need to get more information from "problem reports and solutions" about faulting module, most of the time it would be an dll or exe file. if it is a dll file you may have to download and extract it to system32 after renaming the old file (Needs to take ownership) or if it is exe (probram) then try uninstall and reinstall the latest version.
as Mr Smiley mention it could be issue (Conflict) with ObjectDock. Just verify follow this article How to troubleshoot a problem by performing a clean boot in Windows Vista and find whether it is issue with the service or just the startup item (Could be ObjectDock).
    AMD
    ASUS
    2GB
    Nvidia 256MB
    Creative 7.1
    19" Viewsonic and Sony 26" S Series TV
    1920x1080
    Sata (1 TB) and IDE (350GB)
    Optical (Wireless)
    Multimedia (Wireless)
    2MB
Muff
First of all thx a lot for both you responses, and sorry for the comeback i only woke up now.
@ Smiley:
Im using windows firewall, i tried disabling it to se if the problem resided theew but no luck, also i dont have UAC enabled but strangely some .exe files now appear with that colored shield above them, dont really know why...
As for object dock, and catalyst control center, the strange thing is that they have always worked fine, this laptop is rather recent, like 2 months and it stil has all the sony vaio configuratios and original vista install.
@ prasathkumar:
I already did a system restore, no luck there. Actually i had to do one, and i forgot to mention that somewhere in the middle of this i used all those anti spyware softwares i rebooted and i could no longer login into vista, cause it said my install was not original, and it actually is the original that came from sony vaio. About objectdock, like i said above it have always worked fine so no reason to all of a sudden stop working...
I cant say accuratly cause i really dont remember, but maybe, these problems started to happen once i installed AVG or something and i turned on some vista security options like UAC and used AVG (free version btw) as vista's protection against harmfull software, and maybe thats when the problems came up. All i know is that now stuff like daemon tools cant even boot on startup, some .exe from object dock cant load, stopped working (like daemon tools) as soon as they are executed, and others like ccc.exe and AML.exe stop working as soon as they are executed. Also strangely some .exe have that weird shield above them even though UAC is disabled.
Oh and i play starcraft online, i have the original CD and CD key ofcorse bue i use a image in my comp to play cause the CD has some problems cause its SOOOOOOOOO old, and now i installed alcoholl 120% (since dameon stopped working) and it even says now that my CD key is invalid...and that message appeared to me the first time i ran starcraft after installing AVG (stil with daemon tools, last use before stopped working), before that dramatic boot after wich everything stopped working propperly.
Sorry for the extensive writin i jus tried to be as specific as i can.
Thankyou so much for you opinions,
Sincerily,
Muff
Airbot
Hi Muff,
You can try a few other things. Make sure all your services are set as they should be. They may affect other programs from running. Here is a list that shows you the services default settings.Windows Vista Service Pack 1 Service Configurations by Black Viper
And also Brinks tutorial on it.
http://www.vistax64.com/tutorials/59910-services.html?ltr=S
You could also type msconfig in your start menu search and check for normal startup.
Also, check enable all if you have the option.
You could also run SFC and see if it can any system files that may have been damaged.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html?ltr=S
http://www.vistax64.com/software-tools/183170-system-file-check-tool.html
And there's always the consideration of doing a repair install if you had the Vista installation disk.
http://www.vistax64.com/tutorials/88236-repair-install-vista.html
    Airbot 2.0
    EVGA Nvidia GTX 480 -Fermi
    ASUS Xonar D2X
    [email protected]
    1 OCZ Vertex2 180GB SSD
    Pioneer DVD Burner DVR-S18M
    Corsair HX1000W
    Cooler Master HAF 932
    Logitech Wireless MK700
    Windows 7
    W.E.I final score= 7.7
    Windows Vista=5.9
Kernel
Vista User
Power User
Hi Muff,
Please let us know the result after you tried to use the computer in safe mode....need faulting module information as well (from "problem reports and solutions").
    AMD
    ASUS
    2GB
    Nvidia 256MB
    Creative 7.1
    1920x1080
    Optical (Wireless)
    2MB
Muff
Well did all that and stil have the same problems..
The SFC thing detected erros that could not be fixed, i guess that means i gotta reinstall vista, its not that big of a deal, only problem is that first, sony vaios dont come with the OS DVD/CD, and second, i have linux installed in another partition, and i think that if i reinstall vista ill have to reinstall linux as well, at least thats what ive been told.
If anyone has any sugestions on the best way to format this, or any good tips please feel free to post :) I will only format this on the weekend so...
Thx a lot for all your help and time
Muff
Airbot
    Airbot 2.0
    ASUS Xonar D2X
    [email protected]
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
Muff
Well, i just started into safe mode and no errors popped up, so i dont know exactly what you want me to do in safe mode or how you want me to give you the information on faulting module.
Please let me know how and i will do it now.
Thx in advance
Muff
Airbot
That is something I'm not sure of. Sorry.
    Airbot 2.0
    ASUS Xonar D2X
    [email protected]
    Corsair HX1000W
    Windows 7
    Windows Vista=5.9
Kernel
Vista User
Power User
@ muff
it is good that you are able to use your computer in safe mode and not getting any error messages while opening programs. i hope we can fix this without performing repair installation (you cannot perform repair installation with disc that has designed for different language).
as i mentioned in my previous post Please go through this article and find which startup item or service is trying triger the errors while opening programs.
let's find the item (startup or service) first then we will collect the faulting module information accordingly.
Note: Please do not disable any of the microsoft services (make a check mark on "hide all microsoft services" before you click on "disable all").
Just follow the article.
Good luck
    AMD
    ASUS
    2GB
    Nvidia 256MB
    Creative 7.1
    1920x1080
    Optical (Wireless)
    2MB
Muff
I figured out this is a problem in permissions or something, since i cant play any online game. Even if i try America's Army, i star the game, bue as soon as i join some server i get kicked cause im "blocking" punkbuster...but i have everything turned off...and i stil get that stupid shield on some aplications...
Any idea hot to remove this?
Thnkyou so much
Muff
Contactright
I've tried everything in this thread. Programs like CS4 and Ccleaner stopped working with the annoying windows prompt.
Systemrestore to my surprise has fixed it:D
